Question about Hotpoint HSS25GFP Side by Side Refrigerator
Liner inside doors and panel that splits the inside gets hot
Parts mentioned above are hot to the touch. Freezer not staying cold enough.
  • Hotpoint Master
  • 3,740 Answers
Hi and welcome to Fixya.
The doors being hot to the touch by design are part of the units anti moisture / anti-corrosion system that is not metioned in any manual for nearly all frost free mid to upper level units of any brand.
As for the unit not staying cold enough it sounds like you have a defrosting issue in that there is an unseen ice build up in the evaporator coils preventing the correct amount of cold airflow through your unit.
You can prove that it is a defrost problem by unplugging the unit, emptying the contents of the freexer section and using a fan to blow air into the freezer section for about 2 hours. Be prepaired with the rags and mop as it will make a mess if there is an ice build up in the freezer section. After the 2 hour fan time re-load the freezer section and plug the unit back in. If it works normal after about 4 hours then you have a defrosting problem and the unit will require service either by you or an appliance repair person.
The most typical failures in a defrost circuit are:
1. The defrost timer / motherboard (item 801)
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5239244&diagram_id=22454631#d22454631
2. The 60 Deg F bi-metal thermostat. Item 240 http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5239244&diagram_id=22454626#d22454626
3. The defrost element (Item 230)
4. Chassis wiring or terminals Link NA
There is one item not related to the defrost circuit that can also cause this problem.
5. A defective "evaporator fan" motor (Item 610)
There are more letters in your model number that you did not list as in the last 3 letters that can be AWW, CWW, DWW, EWW, HWW, JWW or MWW.
I used the Hotpoint HSS25GFPEWW as an example.
If you have further needs just repost here and I / we will reply, (Notified via email of your response) Thanks.
Posted on Feb 06, 2010
    Sergeant:
    Champion:
  • 265 Answers
Sounds like the fan that blows on the compressor gave out - so now all the heat is travelling through the fan instead of the air.
Pull it out and put a fan on the compressor while your remove the old, go to to the store, buy a new one and install it. it might be cheaper online - but you will have to wait a few days for delivery.
    Sergeant:
    Champion:
  • 263 Answers
Pull the fridge out, take the cover off in the back and vacuum it all out.
Hotpoint refrigerator repair in orange county, ca
appliance repair orange county, ca
Fridge not cold enough, freezer is. How to get the fridge colder?
If there is still ice in the freezer it will need to be completely defrosted for air to circulate through the coils. Make sure the fan is turning in the right direction. a generic fan motor may not be turning in the right direction and will need to be reversed by turning the armature around if this is possible with the replacement motor most universal motors are reversable and should show you how in the directions.
Oct 04, 2014 | Kenmore Refrigerators
The evaporator fan motor will run only when the compressor is running. If the temperature is too warm in the refrigerator, there may be something blocking the opening from the freezer to the refrigerator.
Misaligned door
By misaligned do you mean the door hits the inside liner of the
freezer? If so then loosen the three screws that secure the top hinge
and reposition the door so it clears the freezer liner, then retighten the screws. If by misaligned you mean the door is warped so that the door
dosn't fit tightly all the way around then you need to loosen all the screws under the door gasket and then twist the door so it seals evenly all the way around the door. (Hint loosen the screws just enough so
the door will stay aligned after you twist it). Good Luck
Aug 22, 2012 | KitchenAid Refrigerators
Not getting cold enough on the inside... the exterior too hot to touch.. why could this be?
Compressor relay could be fried. Feel the compressor. If it is too hot to touch then check your relay. The relays contacts could be welded together making bot windings stay powered up and overheating the compressor causing compressor shutdown on overload.
Sep 02, 2011 | Whirlpool 14.8 cu. ft. / 419 liter Chest...
Doesn't seem to stay cold enough and freezer not keeping food frozen
If the model number is correct above your post it always is most likely a defrost problem and the main part is the defrost heater. Look into rear on the back wall of the freezer section and if you see a frost line building on the panel, unplug. Remove rear panel and either use a hair dryer or a bucket of hot water and set on floor and shut door for a while. Tell me what you find and confirm your model number, Thanks Sea Breeze
Apr 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Side by side getting very hot on top left side of freezer and between the doors where the door liner touches the frame
Not quite sure about top left side, probably normal.
But the hot door liner is definetly normal, this is so the liner remains plyable and doesn't freeze to the frame.
Fuji
Aug 06, 2009 | Refrigerators
Kenmore elite 596 73503201 no cooling in top compartment
if the freezer is getting cold the problem is due to the cold air from the freezer not getting into the refrigerator. There are several things that can cause this problem. The coils in the freezer icing up and not defrosting properly is one of the things that can cause the refrigerator not to get cold enough. Another problem is the fan that blows the cold air from the freezer compartment into the refrigerator, not working. When the compressor is running open the refrigerator's door and push the switch that makes the light go out. You should hear the fan blowing the cold air from the freezer into the refrigerator, when this switch is pushed in. If the fan is working then you will need to find what is blocking the air flow. Iced up coils are a common problem. The icing problem can be due to a defective defrost timer or something defective in the defrost circuit. Click here for more information. Check for these problems and let me know what you have found.
REFRIGERATOR TROUBLESHOOTING
#1 Refrigerator side getting warm Freezer still cold
Evaporator fan motor not running.
Defective defrost timer. See Defrost Diagnosis Procedure
Defrost heater defective. See Defrost Diagnosis Procedure
Defrost thermostat defective. See Defrost Diagnosis Procedure
Airflow blocked from freezer compartment.
Freezer control turned to "coldest" setting blocking air flow to refrigerator side. On most refrigerator/freezers, the freezer control closes a baffle when turned to coldest setting, and this blocks off the air flow to the fresh food compartment.
Fan blade broken.
Defective door switch on older models.
Light staying on with door closed.
2 Refrigerator & freezer compartments both are getting warm
Make sure refrigerator is plugged in and has power.
Condenser fan motor on bottom under refrigerator not running.
Condenser coil clogged.
Defective defrost heater. See Defrost Diagnosis Procedure
Defective defrost thermostat. See Defrost Diagnosis Procedure
Cold control defective.
Compressor overload defective.
Compressor relay defective.
Compressor defective.
Low on refrigerant. #3 Freezer compartment getting hot.
Defrost timer stuck in defrost cycle.(replace)
Defrost thermostat stuck.(replace)
Ice maker stuck in harvest cycle
Light staying on with door closed. 4 Ice maker not making ice
Defective inlet water valve.
Freezer temperature not cold enough. (see problem # 2 & 3 above)
Defective thermostat in ice maker.
Defective drive motor.
Water inlet tube clogged with ice.
Defective module in newer style icemaker. 5 Refrigerator sweating around door edges
Door gaskets leaking air.
Defective case heaters.
Energy saver switch not set to reduce exterior moisture
also if require more help click the link http://www.applianceaid.com/refrigerator.html please do rate the solution .thanks in advance.thank you for using fixya.
Mar 27, 2009 | Refrigerators
Refrigerator getting hot!
There is a part of the condenser called the mullion loop that adds heat to keep moisture from building up and causing the door gaskets to stick. If it's too hot to the touch, first check your frige and freezer temps. You'll obviously know if the frige is too cold, but you may not know if the freezer is too cold. The freezer should be between 5-10 deg ABOVE zero. Any colder and the frige will have to work harder and would create more heat. Also check the condenser coils. If they are dirty it will prevent the frige from removing the heat properly. The condenser should be cleaned at least annually. Most friges have a condenser fan motor. Make sure the motor is running and the fan blades are clean. Most friges also have a cardboard type panel on the back at the bottom. That panel directs the air flow across the condenser and must be in place. If it's missing or damaged it will need replaced.
Jul 20, 2008 | Refrigerators
SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Sep 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
186 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
