Question about Kenmore Elite 45986 Front Load Washer
F 02 I reset it to drain and spin for the first load. already took the bottom panel off and cleaned out the white container. still not working for the second load, still flashing F02.
  • 56 Answers
F02 means long drain. something is stopping it from draining. takes the pump out and look in at the impeller, something could be caught in it
Posted on Feb 07, 2010
We keep getting an F 02 reading. We have tried using a shop vac to clear the machine and the hose, to no avail.
The drain filter is block and needs to be cleaned or the drain pump is broken. Unplug the machine or disconnect power then remove the three screws attaching the bottom of the lower front access panel and pull the panel down and off. Once the panel is off, you'll find the drain filter attached to the drain pump.
Place a container or a piece of towel underneath the filter to catch spillage. You may need to drain the water from the machine by putting the end of the drain hose over a container on the floor. Position the container as low as possible to extract as much water. Remove the filter by turning the knob counterclockwise and clean it.
Also take a moment to inspect the drain pump impeller by reaching it in with your finger and turning it. The impeller should turn freely. Otherwise, replace the drain pump.
Click on the link below if the problem persists after cleaning the filter.
Kenmore Elite and Whirlpool Duet Sud/F02 Error Code
Aug 27, 2011 | Kenmore Elite 45986 Front Load Washer
We have a load in....it is full of water....it wont drain and spin...the cancel button doesnt work and door wont open....I checked for kinks in drain hose...none. I took off top panel and front lower...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Nov 12, 2010 | Kenmore Washing Machines
Not working flashing code 02 f will not drain or spin and wash will not reset i have unplugged.
Disconnect from power. Make sure no clothes is in the washer and no water.Open bottom front panel. With bucket in hand remove filter lid and clean all smelly water and debries. Put everything back and try to start the wash again. That should do it. Good luck!!
May 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Received a F 02 error code which is a draining problem. Checked the hose and it was clear. Upon restart, drum won't spin. Can hear motor engaging. Recommendations?
Sounds like it's not draining the water so the load is too heavy for the drum to spin. Remove the lower panel (3 bolts facing outward on bottom of panel), unscrew the lint filter trap (right side), and clean it out. Also make sure hoses are okay, and that the drain pipe is not clogged.
Dec 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer flashes a 02 error during the final spin/drain cycle.
f02 is a fault indicating poor drainage, try removing hte front access panel and cleaning out the pump housing!
Feb 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer stops mid cycle and displays F 02 error code.
it means that your pump is clogged you need to take that bottom panel off the washer and twist the white cap slowly so it can drain put plenty of towels down once it is done draining pull the cap and clean the trap behind it
Dec 25, 2008 | Kenmore Elite 45986 Front Load Washer
HE4 front loading machine won't drain
Sounds like your pump is clogged. Take off the lower front panel via 3 ws on the bottom. Get a buch of towels, thiers gonna be water. Right in center front thier will be a white twist knob, about 3 inche in diamter. Unscrew it, this is when the water is gonna come out. If there is a secondary wall, pull it straight out with a pair of pliers. Clean out the pump, also check the little hole to the right leading into the impeller, make sure its clean. Finally put it back togther and try it out, If you get me a model # i can get you a schematic, should start with 110,thanks Dave www.washermd.com
Dec 17, 2008 | Kenmore Elite 45986 Front Load Washer
Won't drain
dip as much water as possible from tub..remove bottom panel remove clean out port on pump clean and reinstall
Aug 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
It stops with 12 minutes left , beeps and shows f 02
f02/ is an indicater of long/clogged drain. did you try removing the access panel(3)screws across bottom of unit, behind the panel youll see a large thumbsrew attached to the drain pump thats probalby clogged, with debris
Apr 09, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
309 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
