Question about RCA P52960 52" Rear Projection Television
RCA 52
RCA 52" TV will not turn on makes clicking noise. Never had any problems with it before this happened? Just won't turn on. worked one night and now it doesnt? i am pretty handy so is there a way to fix this myself?
  • 518 Answers
SOURCE: RCA P52937 52 in. Rear Projection Television
It almost has to be a power supply problem, probably in the high voltage stages... Regulator, Horiz. Output.
Geno
Posted on Mar 04, 2008
SOURCE: rca P52921 52 in. projection made apopping noise
sounds like possibly the high voltage amplifier' just a guesas
Posted on May 08, 2009
fillmore85
  • 62 Answers
SOURCE: why does my 52 rca tv keep turning itself off and making a hiss?
Unplug the tv, take off the back cover and feel the top of 3 capacitors. On my d52w20, CP150 (rated at 2200uf 16V) was blown and the top was bulged out. You should also check CP120 and CP114 to see if either are blown. I don't have a clear picture of where it's located, but I have a picture of what you should see after you take off the back cover.
http://i265.photobucket.com/albums/ii209/fillmore85welder/KodakMoment003-1.jpg
In the middle of the picture you see an aluminum heatsink in the shape of a 'C' with the opening facing away from you. That is where CP150 is located. CP120 and CP114 should be located nearby, but if you can feel a bulge on any of the tops of those 3 capacitors replacing them should fix your problem. Replace the existing capacitors with a higher voltage rating of either 25v or 35v.
"4 capacitors on the power/deflection board. CP110 220uf 200v. CP120 220uf 35 Volts. CP114 220uf 35 volts. CP150 2200 16 volt. also check entire delfection board for cold solder especially around flyback. bad connections here can cause problems like some of the fp fuses blowing and cutting off convergence supply"
Posted on Jun 22, 2009
  • 47 Answers
SOURCE: 52" rear projection tv has no power and fuse is ok
The clicking noise that you are hearing is actually the power relay. Normal operation by either the remote or the power button on the front panel, you would normally hear a soft click just after the press of the power buttons to turn the unit on or off. When you initially plug the unit in to power, you will hear the same click noise. Being that you are hearing it all the time indicates a failed relay. TV's now a days, or at least ones built during the last 15 - 20 years have different Printed Circuit Boards (PCB). There are PCB's for power (which youre dealing with now), sound,video and so on. The PCB that you need to repair your clicking issue will run you about 80 U.S. dollars for the part plus the average going rate for repair from a qualified service tech. You could purchase the part from Thompson Consumer Products repair and fix it yourself, but be aware, there will be no warranty on the part itself unless an authorized tech does the work. Located on this PCB is the power on/off relay, fuse, usually 4-5 connectors for power to different PCB's (depending on model and features). Now depending on how old the TV actually is, you may want to invest in a newr set, the reason why I say that is, is because the new power unit may and can overload the other boards and cause damage to them and now you have a new problem to deal with( along with more money being tossed down a hole.
Good luck
Posted on Sep 19, 2009
  • 4090 Answers
SOURCE: tv tries to turn on but turns back off with
The clicking noise is caused by the relay. This is a fail safe to prevent possible fire in the unit. It is heat sensitive and detects some overheating component or short circuit. You may find damage on one of the Sustain or power boards is causing this to occur. It is NOT a DIY unless you can rtead a circuit diagram and understand electronics. It is not a case of being a board swap jockey like working on a PC. Any change of boards or components requires aq retuning using a cross pattern generator ( sometimes buoilt in to the TV in the service access area) Many on here try and do it on the cheap and end up spending much more than the service call in an attempt to save a few $. Very few succeed and if they do the fix is short lived..
Conservative estimate for fiz is $3-400. Unless its a warranty claim.
Please rate my help++++ Thanks for using FIXYA
Posted on Feb 07, 2010
Tv won't turn on makes clicking noise
that click is the power relay, but i have seen several diferent ways this can happen, is it clicking so fast it kinda resembles a buzz noise or do you just hear one loud click when you turn it on? email me maxtek73@yahoo.com.
Sep 08, 2013 | RCA P52960 52" Rear Projection Television
I shut the tv off last night and now it won't turn
If total dead (no lights on blinking etc) follow power cord into the set and find and check the main fuse--in this set it usually is a glass 5 amp fuse.
Dec 19, 2012 | RCA P52926 52" Rear Projection Television
Have 52" projection TV model
Deflection board has issues most likley the flyack transformer or CL031 has fried. Replacing the deflection board will usually solve the issue. Replacement deflection boards are available from www.tvrepairworld.com
Aug 09, 2011 | RCA Televison & Video
We have a 52 inch RCA projection HDTV and today it just stopped working. It doesn't turn on at all. There is no power light or sounds or anything coming out of it. It was fine the night before and when I...
I had the same problem which got fixed today. It was a loose connection to the power supply unit that required some soldering by a technician and cost me 56$. My TV works after 2 months.
Aug 28, 2010 | RCA D52W23 52" HDTV CRT TV
My rca d52w19 makes a noise when turned on.no picturet henshutsof
what kind of noise? is it like an electrical buzzing?
a rapid clicking?
Apr 29, 2010 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52 in When my set is Immed, turned
WHAT ISTHAT WHEN MY TV MAKE NOISES THEN STOP FOR AMINUTE ONCE THE PICTURE IS THER THEN 10 MINUTES IS CUTOFF LIKE ITS TRYING TO COME BACK ON WITH THE SAME NOISES
Jul 15, 2009 | RCA D52W19 52" Rear Projection Television
52" plasma tv - turns on - and I hear something reset inside
i hear a clicking noise- the clicking noise is most likely you ballast trying to power the lamp, but failing. this may indicate a defective ballast if you have recenty purchased a new lamp.I recomend you have your lamp tested to help narrow down the cause of the defect. It's highly unlikely for a new lamp to be dead on arrival
Dec 04, 2008 | Dell Televison & Video
RCA 52" D52w20 problem
My goes off a few seconds after turning it on. It does make a funny sound, like static on the tv.
Aug 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Will not turn on
Does the set make any sounds. DOes the front green led light or flash when you try to turn it on.. if not then it could be as simple as a fuse, if it does flash then it can be many problems
Jan 06, 2008 | RCA D52W19 52" Rear Projection Television
Tv not working
Probable bad HV divider block, part # 205064 ?
Need accurate info = Model / Chassis # 's........T.
Oct 28, 2007 | RCA P52926 52" Rear Projection Television
RCA P52960 52" Rear Projection Television Logo
12 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
