Need wiring diagram for front panel of Asus cm5570. Wire colors going to switches and LEDs.
  • 3 more comments
  • RAY MULKEY Feb 06, 2010
    I know where to connect to the mother board. Needed to know the wire colors to LED's so not to destroy them. Hard to get to LED inside of switch assembly.
    Thanks, Ray
  • RAY MULKEY Feb 07, 2010
    A user manual came with the board "P5QL-VM DO" It has pictures showing pinout of the connectors. Thanks for your help. I found the board at Overstock.com.
    Thanks, Ray
  • joecoolvette
    joecoolvette May 11, 2010
    You're welcome Ray, and also Thank You! I now know what mobo an Asus CM5570 Desktop PC uses, and I have that P5QL-VM DO Motherboard Manual saved.
  • joecoolvette
    The Positive side of an LED is an Anode, the Negative side is a Cathode. If you hook the polarity backwards the LED will be dim. Reverse the connection. May I ask how you have the motherboard wiring diagram? Were you just an intelligent person, and made notes, and drawings before you disassembled, and/or is there a source for the motherboard manual? Would be interested in this information. Thanks, joecoolvette.
  • joecoolvette
    Isn't one available to my knowledge. If the computer was operable, there is a chance you could use the free, tiny, program CPU-Z to see what the motherboard manufacturer, and model is inside that Asus. Since it isn't operable look at the motherboard, and see if there is any manufacturer identifying number/letter code. With an Asus motherboard, the code usually starts out with a letter, followed by a number, then a letter. A few examples: A7N8X-E, P5LD2, P5PE-VM, K8V-MX. This manufacturer code would be printed on the motherboard in the middle, towards one edge, or possibly in-between the expansion slots. (Such as the white PCI slots) If this code is available, post it in a comment to me. From there I can try to see if a Motherboard Manual is available, and we'll know where the connections from The Front Panel go. Then it's just a simple matter to trace the wires on the Front Panel as to where they go. Power On switch, Power On LED, HarDDrive activity light, Reset switch, and so on. Barring that there IS no Asus manufacturer code on that motherboard, then you have to 'wing it'. You'll be looking for the Front Panel header on the motherboard, and there may be two of them. (Connector on a motherboard is a Header) Generally located on the edge of the motherboard. Should be one long rectangular Header with 2 rows of pins, or two Headers that have 2 rows of pins, and 10 pins total. (Usually has a missing pin in one corner of the Header, but this is not always the case) Most of the time for the older Asus motherboards, the Front Panel header is one long rectangular header. Location: Processor at the top, Ram Memory slots to the right, the FRT PNL header is located in the very bottom right corner. May, or may not have an abbreviation printed next to it. (Panel?) The header's length is parallel to the edge of the motherboard. In relation to the position of the ram slots, it sits perpendicular to the ram slots, or would be like an upside down T, with the ram slots being the middle of the T. The pins are in 2 rows going horizontally. Top row, with a bottom row underneath. There may be an tiny abbreviation of PWR next to the Power On switch pins. Usually located in the middle of the header. The pins will be stacked vertically. One in the top row, one in the bottom row. I await to see if you have the Asus motherboard manufacturer code, and also if you see the Front Panel header, and any possible abbreviations next to this header. Post in a comment. (Believe top right of your page)
4 Suggested Answers
cdhardy
  • 111 Answers
SOURCE: connecting front panel leads of generic case to 4600 motherboard
let take the last first the trial-and-error method will fry the board
for the rest i got ya coverd.
The TAD Connector is The TAD (Telephone Answering Device) connector is for connecting a voice modem and sound card If both your audio card and voice modem have the TAD connector
And for your motherboards first the 460 http://support.dell.com/support/edocs/systems/dim4600/en/4600i/index.htm#online_documentation & for the 170L http://www.fixya.com/support/p349168-dell_optiplex_170l_170l3ry9r41_pc/manual-14438
Posted on Mar 29, 2008
Mark_Webber
  • 472 Answers
SOURCE: My ASUS P4T533-C Manual is
This is the bit your after I believe...
Posted on Apr 18, 2008
mukexh
  • 20 Answers
SOURCE: need front panel connection diagram power switch lrf connectipns on 9 pin connector on motherboard
Hi u can easily solve this problem.
open your computer cover and and see the motherboard front panel connectors. a use of screw driver touch any two front panel connectors if any led or switch working this condition you can note this and connect successfully. one by one touch all penal connections and u will be solve ur problem thanks mukesh kumar
mukesh_ibm@yahoo.com
Posted on May 13, 2009
I need the radio wiring color diagram for my delco radio, 1998 corvette
1998 Chevrolet Corvette Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Orange
Radio Switched 12V+ Wire: Yellow
Radio Ground Wire: Black
Radio Illumination Wire: Gray
Radio Dimmer Wire: Brown
Radio Power Antenna Trigger Wire: Pink
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 4? Speakers
Front Speakers Location: Kick Panels
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6?
Rear Speakers Location: Rear Sides
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Dec 22, 2016 | Cars & Trucks
2007 Ford F150 STX, I need the Wiring Diagram for Lights (Headlights, Running/Parking/Turn-Signal)
Go to either Autozone.com and register your vehicle for free, or alldatadiy.com for the same wiring diagrams. Powerbox layouts are also provided.
Now I want to add that if the new lights are like the HID factory type, you may need 2 Relays and heavier wiring to the lamps. Now sure if the Alternators are the same either.
I hope my solution helps.
Sep 18, 2012 | Ford F-150 Cars & Trucks
Looking for wiring diagram
The information you need is in the pdf below. Look at page 1-26 in particular.
http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8V-MX/E2335_K8V-MX_h.pdf
Jun 05, 2012 | ASUS K8V-MX Motherboard
Front panel pinout connections for ASUS A8M2N-LA (NodusM3
The Asus A8M2N-LA motherboard was made SPECIAL for HP.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00757531&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3339286
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00820191&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3339286
As such Asus has no info on it.
Looking at the second link posted (Motherboard Specifications), scroll down to the bottom, and click right on - Motherboard Layout
Motherboard layout shown (Direction), is the same as is installed in your computer; Processor to the Top, white PCI slots to the Bottom, Ram Memory to the Right.
The plastic front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the cables (Wires) go to from the Front Panel, is the Front Panel header.
Abbreviated F_PANEL 1, at the bottom right corner of the motherboard, is the Front Panel header.
There are 9 contact pins. Two rows.
Across the Top row they are numbered ODD.
Across the Bottom row they are numbered EVEN.
Coming from the Left side of the motherboard towards the right side, on the Top row;
Pins 1, 3, 5, and 7
Coming from the Left side of the motherboard towards the right side, on the Bottom row;
Pins 2, 4, 6, 8, and 10.
A) Pins 1 and 3 are for the HarDDrive activity LED light.
Pin 1 is for the Positive wire. ( + )
If the HDD LED is dim when operating, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pins 2 and 4 are for the Power On LED light.
Pin 2 is for the Positive wire.
D) Pins 6 and 8 are for the Power On switch.
Regards,
joecoolvette
Apr 10, 2012 | Gigabyte Computers & Internet
I have purchased a Thermaltake V3 black case and am trying to install my M2N68-LA motherboard. The motherboard has a combined 9 pin header for power switch, power l.e.d. and hdd l.e.d. which was one plug...
1) The 9-pin header you are referring to, is the Front Panel header.
(Processor to the top, Ram Memory slots to the right, the Front Panel header is at the bottom right corner on the motherboard)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00906129&lc=en&cc=de&dlc=&product=3397528
The plastic piece on the front of your computer is the Front Panel.
(Sometimes referred to as a Bezel)
Make a drawing, and notes as to where the individual wires go from that Front Panel header plug, (One-piece plug), to the Front Panel.
Follow the wires from the plug to the Front Panel.
Mark down where Each wire goes.
You may have to take components off of the Front Panel, in order to see exactly where Each wire goes.
For example:
You may have to remove the Power On button/switch assembly from the Front Panel.
It may have the Power On LED light, Power On button, (Switch), and perhaps the HarDDrive LED activity light, in this assembly.
The wires are color coded.
Generally, but not always, when two wires are used in conjunction with each other, (Example, Power On switch, or Power On LED light), the wires will be twisted together.
One wires insulation may be of a solid color, and the other wire may be white, with a stripe in the color of the solid wire.
Example: Wire with Red color, and wire twisted with it may be White, with a Red stripe.
See if these two wires go to the Power On switch.
End of example.
Follow each twisted pair of wires back down to the Front Panel header plug.
(One-piece plug)
See which socket holes the individual wires go to.
Mark it down in your drawing, and notes.
Mark where the individual socket holes plug onto each pin, in that Front Panel header. (9-pin header)
When you are finished, you will have a pinout for the Front Panel header on the Asus M2N68-LA motherboard, and will know where the individual wires go from your ThermalTake V3 computer case.
For the LED lights there is a Positive pin, ( + ), and a Ground pin. (Power On LED, and Harddrive activity LED, for example)
(Ground. Also referred to as the Negative pin. ( - )
This is DC Voltage)
If you have the polarity backwards, (Positive wire of the LED light is going to the Ground pin, Ground wire of the LED light is going to the Positive pin), the LED light will be dim.
(When operating)
Switch the wires around.
If you have questions, or need clarification of what I have stated above, simply state in a Comment.
(Believe upper right of your page)
Jul 01, 2010 | ASUS Computers & Internet
Front panel power switch & led'S pinout
asus web site download manual for a p5pe-vm thats all you need
Apr 30, 2010 | ASUS P5PE-VM Motherboard
Audio wiring problem
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: White/Red
Radio Illumination Wire: n/a
Radio Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Rear Glass
Front Speakers Size and Location: 6 1/2′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size and Location: 6′ x 9′ Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Apr 05, 2009 | 1998 Honda Accord
Need connecton diagram for ASUS P4S-LA motherboard.
if colours don,t match up. your main connectors hdd/pwr/reset remove the front panel on the computer. and check from the switches located on the front panel. or you could use a multimeter and test for continuity. if you have one.
you should have green/white red/white orange/white Or blue white.
Mike @ Compurepair.
Mar 15, 2009 | ASUS P4S800-MX Motherboard
Wire diagram
I took care of the problem. The wire colors were by next to each post with the color of the wires on the front panel.
Sep 26, 2008 | Kenmore Refrigerators
Need to get wiring diagrams
1988 Dodge Ram Charger Car Audio Wire Color Codes
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Orange
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6′ x 9′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Purple/Yellow
Car Audio Rear Speakers Size: 5 1/4′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Blue/White
pls rate
Jun 23, 2008 | 1988 Dodge D-Series Pickups
Computers & Internet Logo
677 people viewed this question
David Payne
David Payne
