Question about Freezers
My subzero 601 F freezer door gets hard to open unless you wait 4 minutes. While investigating this I discovered that there is a buildup of ice in the trough behind the icemaker. It appears that the drain line is stopped up with ice. There is a wire in the drain. Is it supposed to be heated to keep the drain clear? Perhaps it's not functioning? By the way, I do not have water run to the freezer and do not use the ice maker in the freezer. Once I thaw it out the door works just fine until the ice builds up. It takes a year or two to build up.
  • 4,793 Answers
Switch off machine. open doors an manually defrost.clean any filters/drain holes(wire is not heated,pull/push to clean pipe)dry as best you can.switch on again.it is best to manually defrost any unit every 6 months and if temp edjustable adjust to -20c for optimum economy.water to icemaker is not important on 601f but is on some others.be carefull
Posted on Feb 11, 2010
Why is my top shelf freezing up so easily
When opening the freezer door on a hot humid day, you allow this hot humid air inside that freezes on very cold surfaces. Cool your home with AC, it will get rid of the excessive humidity to reduce your freezer problem. The less time the freezer door is opened also helps to reduce the ice buildup.
Sep 06, 2015 | Freezers
The ice maker makes a loud racket unless the freezer door is open.
You have an object jammed in ice makers path. The freezer door has something on it that is pushing into the ice maker perhaps.
Feb 08, 2013 | Samsung RS261MDBP Side by Side...
Kenmore upright freezer, about 16 cu ft. Buildup
symptoms you are describing are faulty door seals, try putting a thin piece of paper between door and frame to make sure doors are sealing,also when did you do a full manual defrost??(once a year even with auto defrost)
Apr 07, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Our subzero freezer has a new problem. The cubes
Ice cubes WILL BE slightly moist when they land in the ice bucket. they've just been slightly melted in order to eject from the ice maker. Stop playing with the settings, for starters. put them back to normal, i.e., middle setting, place thermometer in center of freezer, and if you can, one in center of fresh food. monitor after 24 hours, and for the next three days thereafter. freezer temps should be in the -5 - +5°F, sometimes up to 10°, fresh food should be 35-40, sometimes up to 44°at the normal settings. If you are not having temperature issues, see if you notice any frozen drips of water on the underside of icemaker, indicating a possible crack in the ice maker mold, or a faulty water valve. You didnt include your model and serial number, so not knowing the path of the ice shoot, some go out the freezer door, some slide over and get dispensed from the fresh food side. Its possible you may have a problem instead with the flapping door that opens to allow ice cubes to be dispensed, or similar type mechanism. If this door does not seat completely when its closed, it will leak warm air directly into the ice bucket, which would make them slightly moist, also too, this warm air can cause frost and ice to buildup near the warm air source...look for any unusual forms of ice and or frost leading up from the flapping door to the ice bucket. Also look for any gaps in the door gasket when closed, this warm air leak can also cause similar problems, but its most likely with the ice door. could be the door, the spring, the solenoid, or something else i wouldn't know without personal refrigerator inspection.
Mar 27, 2010 | Freezers
Have a subzero set - fridge and freezer. The
First, check the compressor fan. Make sure it is turning. If this fan is not working properly, the refrigerant will be be cooled adequately. This lowers the efficiency of the refrigerator and causes it to run more.
The fan is probably located in the back of the bottom of the refrigerator. It pulls air across the coils and blows the heat out the back of the unit.
If the fan is not turning, the fan motor will need to be replaced.
Oct 14, 2009 | Freezers
Subzero Freezer ice keeps building behind coils
in 601 model. really common problem is the drain hater. watch close the ice maker for a BIG long ice. on the cotton psrt of the back wall. some models have 1 some 2 depends in the serial num. ask you tech for replace the DRAIN TUBE HEATER. that way your cover. really helps a lot the code number...................good luck................. leave a comment...........thanks
Sep 28, 2009 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
My son got into my fridge lastnight-left open, now won't cool
evaporator coils is probably frosted from condinsation.shut door set at normal setting and give some time.
Jul 26, 2009 | Frigidaire Freezer Refrigeration White...
Self defrosting deep freeze not defrosting
The excess frost in those areas is probably caused by leaky door gasket seals. They should be tight enough to hold a dollar bill securely all the way around. A defrost problem would start on the coils behind the back cover inside the freezer and would also appear on the back wall before it did on the door edges.
Jul 13, 2009 | Amana 19.6 cu. ft. / 555 liter Upright...
Top & middle shelves COVERED with frost/ice, not middle
That is normal. The refrigerant runs through those shelves. They are the evaporator side of the unit.That is where the freezing effect comes from.
Check door seals for leaking air.
Keep door openings to a minimum.
Get in there and get out.
Those things will help prolong frost/ice buildup.
Mar 12, 2009 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Roper--ice buildup on one freezer shelf
The reason for ice buildup is an air leak. Recheck all around the gasket by taking a dollar bill and closing the door on it and pulling it out. If you don't have resistance, you found your leak. Heat that area with a blow dryer to relax the gasket and close the door to let the magnet and seal set. Also, rub some vasoline on the hinge side gasket to keep it from dragging.
Dec 07, 2007 | Freezers
Freezers Logo
530 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
