Question about Nintendo Wii Console
My wii works but my controler dosent show up on the screen but the buttons work i need help
  • dssummerwave May 11, 2010
    Green - The Wii Console is on Yellow - You are connected to Wiiconnect24. It's harsh not to keep the "Yellow" light on because it could overheat the Wii Console. So if it's "Yellow", put your finger on the "Power" Button and keep it there for a long time. When you push it, it will start with Yellow then turn to Green then keep the finger there for a while then will turn to Red Red - The Wii Console is off Blue - You are connected to Wiiconnect24. When it turns Blue, It means you are getting a message from the Wii Console or on Standby Mode
    Black - The Wii Console is shut down & about to explode
    Pink - You are getting a message from an unknown user
    Brown - You have used the Wii Console to much & needs to be shut down
    White - The Wii Console is Frozen
    Red mix Blue - The Wii Console is in a Happy Mode
    Black mix Brown - The Wii Console is in a Unhappy Mode
  • 19 Answers
Usaully,
I don't know about the Wii but I know what happens with the light on the Wii
Posted on Mar 09, 2010
Wii system was has power etc. Handheld control has fresh batteries and lights on face of controller do light up when attempts at pressing various buttons. When Wii is turned on-screen on TV shows Wii is...
Press and hold the the red button under the flap on the wii for 30 seconds this will clear all pairings of controllers. Then press the red buton under the wii again and let go immediately now open the battery case of the controller and press that red button uner there and the controller will pair again and it will work the wii
Please vote if you found this info useful
Mar 11, 2011 | Nintendo Wii Console
My wii remote controller dosent work
Try this.Open your battery compartment on your controller and open the front large door on the console.Point the controller at the sensor bar and hold down the red sync button in the battery compartment.At the same time hold down the red sync button at the top of the console compartment.It may take a few seconds but that's how to do it.I don't remember if the game needs to be in or not,I don't think so.It may take a couple of tries too.Good luck and Game On!
Jul 19, 2010 | Nintendo Wii Remote Controller
Wii wont turn on
If there is no LED on, then the most likely reason is, that your wii isn't getting power. So the problem, is with the plugs, and the power adapter. If you have a friend who has a wii, try testing his power adapter on your wii. Make sure your cords are completely plugged in, on both sides, (the outlet and the wii) then press the power button on the wii. If that dosent work, try turning it on with one of your wiimotes. If that dosent work, that means your wiimote is not synchronized with your wii. To sync. it, open the sd card cover on the front of the wii, press the red button above the sd card slot. Then open the bottom of your wiimote, (where the batteries are) and press the small red button that should be beside the batteries. Then hold the wiimote close to the wii,then after its done flashing, press the power button on the wiimote and also, try plugging your power cord into another outlet. If it still won't work, you've got a broken wii, so you better send it to get replaced or fixed, again as suggested. DON'T OPEN IT! You could loose your warranty if you open it, so it's safest not to. Hope you get it to work
Thank you !!
May 20, 2010 | Nintendo Wii Console
Can't get tony hawk "ride" board to "connect" with wii console after following instructions
Still dosent work for me.
it just flashes and never shows player one or two.
Dec 25, 2009 | Nintendo Wii Console
Its Not Passing The "push A Button Screen"
Some gamecube controlers dont work
Aug 30, 2009 | Nintendo Wii Console
Guitar works but it dosen't when playing?
It could be that you just need to sync your video setting, possibly the audio too, although I have found that syncing the video alone is enough, which you can set up on the game. If you have a flat screen, they are notoriously known for processing induced lag. Just follow the syncing process they have you do (should be set in the upper 80's to lower 90's if you did it right), then you should be hitting notes in no time.
Aug 02, 2009 | Nintendo Guitar Hero Wireless Guitar - Wii...
To play Game Cube games in the wii
You need game cube controlers to play the game cube games on the wii. Hope this Helps you.
Please rate FixYa!
Mar 29, 2009 | Nintendo Wii Console
Second guitar for wii guitar heto will not sync
start the guitar hero game as you normally would. then take the remote that you are going to put into the first guitar and press the "home" button", this should bring up a screen that will allow you to connect another remote in the game, press the reconnect area and aim both remotes at the sensor and press the 1 and 2 button at the same time, exit this screen and then got multiplayer section of the game and you should be set. my 10 year old neighbor had to show me this. good luck..
Dec 28, 2008 | Nintendo Guitar Hero Wireless Guitar - Wii...
Cant add a controller
I had the same problem and called Nintendo support. They had us unplug the wii console for 30 seconds, plug it back in and start the system back up. BEFORE pressing the A button on the health and safety screen, we needed to take the battery cover off of one remote, press the red sync button, then quickly press the sync button on the front of the wii console (in the front - you have to open the flap). Once the single blue light was on at the bottom of the remote, do the same with the other remote (press the sync button on it and then on the wii console). Then the second blue light should be lit on the second remote. Hope that helps!
Nov 29, 2008 | Nintendo Mario Kart (Wii) for Wii
Controller
try wiping the sensor part on the wii mote. also don't have any interfering electronics
Apr 01, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
163 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
