Question about Stanley Hand Tools
How do you remove the belt from a H493 sander, I can't seem to locate the release :-(
Belt is released by pressing backwards VERY firmly on the front roller to force it backwards until it 'clicks' into place. (Basically, brute strength) The belt is then easily removed and the replacement installed. Following installation you must push the front roller forward until it returns to the starting position
Posted on Feb 07, 2010
Towel caught in front roller
Well, it sounds like you have a belt sander. I would start by sacrificing the towel and the belt. Even if you tried all day and were able to save them they would probably look like they got caught in a sander. Get a utility knife and change the blade, you will want a brand new sharp blade for this. Start by cutting as much of the exposed towel off as you can. Remember, at this point the only thing you might be able to save is the sander. Cutting off the belt will relieve the tension. When you cut the belt give yourself enough belt on ether side to get a good grip. You might need to pull the belt back and forth as you remove small pieces of the towel. A good pair of pliers might help grip the towel fragments. When you finally do remove all the towel and the belt, take some time to look around the drum for fibers that might be stuck in the bearings and pull them out. You may need needle knows pliers for this. Keep the towel shreds for sating rags to finish the project you're working on so it will not be a total waist.
Good Luck
Ray
Apr 28, 2014 | Makita Tools & Hardware - Others
Where to buy 55-3554-4 drive belt
Applied Industrial Technologies Brampton they also have several other location just google the name
May 05, 2012 | Ryobi Mastercraft Belt/disc Sander Belt...
HOW DO I REPLACE A TIMING BELT ON A 3" X 18" BELT SANDER
On the side of the sander there is a black triangle shaped cover with 3 screws holding it in place. Remove the screws and you will see the drive belt and 2 pullies or gears. The belt will be attached to the gears. Remove and replace the belt. Typically the belt is broken so the only thing you will need is to locate a new belt and slip in over the gears with the side with the teeth facing the gears. This keeps the belt from slipping. Reinstall the cover and you are ready to go back to work. The hardest part may be finding a supplier for the belt.
Aug 06, 2011 | Black & Decker BR300 3''x18'' Belt Sander
I have a Black & Decker sander, model # 7447 and am having problems changing the sand paper.
The 7447 does not have a release lever. To change the belt, you must release tension of the rollers by pushing the front roller straight back until you hear it click and lock in position to change paper. Remove old paper and replace with new paper. Make sure if new paper has directional arrows to install properly.
Now you must release the front roller to put tension on paper. To do this push the front roller from the side that has the adjustment screw. This will release the front roller and allow it to go back into position. Be careful as it pops back quickly and with some force.
Turn on sander and adjust centering of paper with adjustment screw found near the front and side of sander.
Jun 13, 2011 | Black & Decker Garden
How do I change the sanding belt on my 7447 belt sander
Aug 27, 2010 | Black & Decker 3"x21"HD Vs Belt Sander
Porter Cable 362 belt sander - the paper slips off
there might be a buildup of sawdust in the tensioning mechanism or the yoke might be bent. I would look at excess buildup in the mechanism first. there are 3 screws on the outside of the tool so you can remove the assembly as a whole. try and clean as thoroughly as possible. the mechanism should move freely and "snap" when lever released.
Jul 18, 2010 | Porter Cable Tools & Hardware - Others
Sand paper not tight
it could be a dirt buildup in front of the yoke not allowing it to fully extend. could also be the rear roller is worn down, I would recommend going to Makitatools.com and downloading a breakdown to see how to remove the mechanism to clean . the yoke should snap when the lever is released to install the belt.
Mar 19, 2010 | Makita 9404 4'' x 24'' Belt Sander
How do I release the lock on my Craftsman belt sander to lighten the belt. It's an old Model # 315.1172
I checked Searspartsdirect.com for that model number and they listed that number, but with an extra 0 at the right end. I couldn't find a belt release lever illustrated anywhere like that on my old Craftsman belt sander. On mine, you just flipped the lever either forward or back to release and tighten the belt. (still works great) There is a spring that pushes the front roller assembly forward when the lever is operated.
Dec 03, 2009 | Cars & Trucks
Installing belt on sander
Remove table assembly.
Remove pointer and then slide cover up and out from dust reflector.
Release belt tension by pushing tension lever toward idler drums.
Note: there may be an arrow on the inside of the belt.
The arrow should point in the direction of belt travel to ensure that the splice in the belt will not come apart.
Slide new belt over the drive and idler drums; center belt on drums.
Push tension lever towards drive drum to tension belt.
Hope this helps.
Oct 04, 2009 | Tools & Hardware - Others
How do you replace the drive belt on a Porter Cable Belt Sander
There is a lever on the side at the front right near the roller that you can use to release the spring tension on that roller (moving it slightly to the rear).  Once the tension is released you can slip the sanding belt onto both rollers from the side.  Release the lever and the spring will put tension on the belt to hold it in place.  Use the knob on the left side to center the belt on the roller if it starts to slip sideways when in use.
May 28, 2009 | Porter Cable 361 3" X 24" Sander
Hand Tools Logo
127 people viewed this question
Top Stanley Hand Tools Experts
Jim Thurston
Ivan
Ivan
Level 1 Expert
Don Numinen
Don Numinen
Are you a Stanley Hand Tool Expert? Answer questions, earn points and help others
