Question about KitchenAid KGRI801PBS Gas Kitchen Range
Stove top difficult to light
When I try to light my Kitchenaid stove the stove top just clicks for several minutes trying to ignite. It usaually starts off with a small flame even on high and as it warms up the flame gets to where it should be. After it runs for a few minutes I can turn it on and relight it or turn on another burner with no problem.
  • marshakurt Mar 29, 2008
    We are having the same problem and the house stinks like gas because of it. did you find a solution yet? We are going to try blowing compressed air into the injectors to see if there is any debris in it. I hope it works. Good luck.
  • 25 Answers
Your gas jets are dirty.. clean them with a toothbrush (after everything is cooled down).. you can use the selfclean to clean the iron pieces that cover the burners..
be careful with kitchen aid self cleaning.. there is a known issue with the thermal fuses blowing quite easily on most self cleaning cycles..
good luck
tpug
Posted on Jul 22, 2009
When I turn on the oven the bake burner does not ignite but one of the top burners tries to ignite. Neither the bake or broiler oven will ignite. KitchenAid Model:KGRS807SSS00
you don't have a regular igniter in this stove you have stick igniters it sounds like you have a bad spark module part WPW10331686 all the igniters are plugged into it,the spark module is up in the top console on the left side or on the back wall but it's easier if you pull out the stove to get behind it,make sure you unplug the stove before you work on it,go here to see picture of module
https://www.repairclinic.com/PartDetail/Control-Module/WPW10331686/1937904
also you can go here to sears site,put your model number in and see all parts,go to control panel to see spark module
https://www.searspartsdirect.com/model-number/KGRS807SSS00/0593/0124002.html?searchType=modelSearch&q=KGRS807SSS00&searchTerm=KGRS807SSS00
Jan 26, 2018 | KitchenAid Kitchen Ranges
The igniters on my gas stove keeps clicking? What should I do and is it still safe for me to use the stove
Hello -
This blog written on behalf of an appliance repair business located in Ohio may prove instructive regarding your igniter clicking concerns:
https://1stsourceservall.wordpress.com/2015/08/07/why-does-my-stove-keep-clicking-troubleshooting-a-gas-stove-ignitor/
If, after going through the troubleshooting tips, you still have the constant clicking, then, you may wish to arrange for a repair technician who is manufacturer authorized to service your stove, a KitchenAid, right?
Best wishes.
Jan 21, 2018 | Kitchen Ranges
Constant clicking from electric pilot connection. won't stop after leaving for long time, unplugging overnight, cleaning all burners, running gas by lighting with match and letting the flame run. ...
Hi nancypp,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 04, 2011 | KitchenAid Cooktops
How do you light the oven? We turn the dial and
I take it the range is electric ignition because you say the top burners have a clicking(igniter) noise. If the top burners are electric ignition then the oven is also. The oven probably uses a hot surface igniter and that is why you do not hear any clicking. Turn the oven on and open the broiler compartment. You should see a bright glow from the hot surface igniter. If you do not see any glow there may be a grounding issue or the igniter could be bad. If you do see a glow but the burner does not come on in a few minutes then give the gas valve a tap with a wrench and see if the burner comes on. Shut it off and then back on several times. If the burner continues to light after this you may have fixed the problem. If it does not come on gas valve could be sticking or igniter is weak.
Sep 10, 2009 | Magic Chef 31000 Gas Kitchen Range
Kitchenaid gas stove left back burner won't light. hear clicking
I have one of the kitchenaide gas ranges and if the burner cap is not set on PERFECTLY straight, the gas doesn't flow properly and will not ignite. Try lifting and replacing the cap back down on the burner and see if this solves it.
Mar 05, 2009 | KitchenAid Kitchen Ranges
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
There is nothing fancy about how the gas controls work on this unit. Do all burners give you the same problem? If so, it could be a kinked service hose or a service valve that has been partly shut. If it is limited to a single burner or two, the valve may be gummed up and should be replaced.
Nov 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Ketchen aid kgst 307
There are several screws under the front lip of top of the range. You will have to open the oven door to see them. Once the screws are removed, the top should just lift up. Of course, if it has been a couple of years, grease and oil can creep into the seams along the sides and cause the top to stick. If this is the case, carefully take a putty knife along the side seams and lift up at the same time on the front. The top should open. Now, if ALL your burners are not lighting, that sounds like a bad spark module. Do you hear a clicking noise when you try to light any of the top burners? If not, the spark module not the igniters, is the likely suspect. The spark module provides a voltage to ALL the igniters simultaneously. Removing the top will not be necessary if this is the case. The spark module is usually located in the back of the oven cavity under bottom pan of the oven. Or, it may be located behind the panel in the rear of the stove. Let me know if this helps you.
Jul 29, 2007 | KitchenAid KGST307 Gas Kitchen Range
KitchenAid KGRI801PBS Gas Kitchen Range Logo
307 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
