Question about Refrigerators
No ice in my Hotpoint Side by Side Refrigerator/Freezer Model CSX22GRZ
Why can't I get water into my icecube maker?
The sticker on the inside says Type 7 20.5 -- 22.4
CAX22GRZ
the magnetic bar code sticker on the back says CSXGR
  • 3 more comments
  • Bernie64 Feb 21, 2008
    We have had this unit for about 10 years and it has always made ice in fact we have never had any kind of problem with it.
    Bernie
    the Unit is about 10 Years old and has always made ice.
    Bernie
    The 10 year old unit has always made ice.
    Bernie
    It has always made ice.
    Bernie
    The unit is a Hotpoint Model CSX22GRZ
    Genius:
  • 3,422 Answers
Do you mean that your icemaker is not able to make ice?
Waiting for your reply..
Posted on Feb 21, 2008
  • 3 more comments
  • Priya darshan Feb 21, 2008
    Can you tell me what is the brand and model no. of your refrigerator?
    Alright so the problem is only that you can't get water into the ice maker.Can you please tell me the brand and the model no.?
    Is there any leak in the ice maker?
    Also let me make one thing that the icemakers only last from 6 to 10 years.
    I mean the ice makers only last from 6 to 10 years.
    Scholar:
  • 110 Answers
Hiya Bernie!
Has your icecube maker worked before? If not, or if your Refridgerator is new, it may be that the water line isn't connected for the ice maker. A nice guide to installing the water line is located here:
Guide
  • Robert Swanson
    Robert Swanson Feb 21, 2008
    There are a few things to check in that case. Make sure that the overflow switch on the ice maker isn't tripped or broken (on most ice makers it is a shaped metal piece that hovers over the ice bucket). You can also check to make sure water is flowing at the connection to the fridge. To do this make sure that the valve connecting the water line to your main is shut off, then disconnect it from the back of the fridge. Put it in a bucket so it doesn't make a mess, then open the valve. If it flows fine, and if that switch isn't broken, it's likely that your ice make has just given up the ghost and needs replacement.
    Master:
  • 788 Answers
Probably frozen tubes, you would need to turn the fridge off for a few hours and the water should start flowing again. Turn the temperature up a little in the freezer to avoid this happening again.
  • Dean Joly
    Dean Joly Feb 21, 2008
    Weirder things have happened. Either it's frozen or clogged by dirt and grime.
Clicking sound from back of fridge
Its faulty capacitor or compressor relay or the timer.Its in the lower end back.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Hotpoint HSS25GFP Side by Side...
Inside my side by side freezer side (hss25gfta ww)
The ice maker water inlet valve has failed allowing water to pass when it is not supposed to pass. The water valve is item 800 of this link. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5203104&diagram_id=24933031#d24933031
Changing the water valve most always returns the ice maker operation back to normal.
Kelly
Mar 04, 2010 | Hotpoint HSS25GFP Side by Side...
Hotpoint side by side refrigerator freezer and ice maker in freezer is not getting water.Is there a simple fix?
need to verify that the water inlet valve on rear of refrigerator is good. take cord with aligator clips and put power to valve. if valve opens and sends water to ice maker then its good. your module on the ice maker might be bad.
Jun 24, 2009 | Kenmore 57029 Side by Side Refrigerator
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
It's likely the door was inadvertently left open, and the cold air passages from the freezer have built up enough ice that the cold air from the freezer has no way to enter the refrigerator. Check the cealing of the refrigerator. If you can see or feel ice in the passages between the freezer and fridge, you can probably solve the problem by finding a safe temporary home for your food, and leaving the refrigerator unplugged overnight.
May 25, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Ice tastes funny all of a sudden.
you need to throw out the ice. ice gets stale after a couple of weeks , so toss the old ice. also is there something like garlic or another food that has a strong oder uncovered in your refrigerator section? air flow covers all of the unit, both refrigerator and freezer sections. if your refrigerator is not smelly , put an open box of arm hammer baking soda on a shelf in both sections of the refrigerater. if water and ice still taste funny shut off water supply and check the filter at the rear in the lower part of the unit. take off connecter and visibly check the strainer in the water valve,clean it out by removing it and rinsing it under the sink faucet. make sure that water from other faucets taste ok . the only thing left is to flush out the water tank by filling up glasses of water until the water gets room temperature . that's about all you can do short of replacing the water line leading to the refrigerator, although i have never had to do that before. good luck
Jan 23, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
hi thanks for the question you problem could be a no defrost problem remove the floor of the freezer 4 screws lift from back to front remove foam if its all frosted up you have a defrost problem a bad fan motor also can cause this it could also be stuck in ice if so use hair blower and thaw dry it real good re assemble and try again thanks the appliance doc
Sep 22, 2008 | Hotpoint HSS25GFP Side by Side...
No Ice
Clogged filter?
On most ice makers, if the water pressure drops too low, the valve will not open to fill the ice maker.
Frozen water line?
On some units, the water line supplying the ice make can freeze up preventing water from getting to the ice maker.
Freezer cold enough?
Are you sure of the temp inside your freezer?
Place a small thermometer that can register temps around the freezing range. (example of a thermometers not to use are: a candy thermometer or a thermometer used to take a person's temp.) If you do not have one or do not want to purchase one, put a bowl of water in your freezer. If the water does not turn to ice in say 6 to 8 hours, your freezer is not cold enough.
Feb 21, 2008 | Refrigerators
Ice maker not filling & making ice cubes
First give me the entire model # on the sticker from the inside of the fridge and I can definitely help you with this.  Let's solve it before you rate it.
Oct 17, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
134 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
