Question about Dell Precision M60 Notebook
Dell Precision M60 won't boot up
I'm wondering if my computer is done for. When I push the power button nothing happens except that the caps lock light lights blinks ten times. Is there anything I can do?
Katlyn
  • 2 more comments
  • Anonymous Mar 03, 2008
    I am having the exact same problem... I have tried powering up from the standard power supply and the docking station power supply and have the same results. There has got to be a Dell trouble shooting manual of some kind that decodes the blinking light.
    Help Please!!!
  • Anonymous Mar 15, 2008
    yes i have the same problem i cant
  • Anonymous May 14, 2008
    I also have a Dell M60 and my problem is as follows:
    If I connect to a docking station, I can power on from the dock station and my laptop powers up fine.
    Without the dock station, AC and/or battery I cannot power up my laptop.
    If I power up initially on the dock station, and eject from the dock station, I can restart my laptop without a problem. However, once I shut it down, it will not power back up until i connect to the dock station.
  • burfboy Oct 21, 2008
    I have the same problem with my M60. I cannot get it to fire up at all. I've taken the cover plate off that hoses the on/off button and checked that the connections are complete. I have also bought a new memory unit but to no avail. When I press the on button, the green power light on the hinge stays on for about 4 seconds then just goes off. This happens whether it's on battery or AC power supply. Any other suggestions???
This is a memory problem, most likely. Try swapping the SIMs or putting them in one a time.
If you only have the one SIM, see if you can borrow someone elses
Posted on Mar 10, 2008
I had same problem with my M60, tried solution #2 "pushing down on the right side of the solver bar" to the right of the power button and bingo! my dead machine booted up.
As the guy says it must be a loosce connection.
Crazy but it worked, a bit like doing CPR on your laptop!! many thanks
Posted on Aug 19, 2010
Solution 1 works. Thanks a lot.
Posted on Aug 13, 2008
I had this problem with my laptop. I figured that some of the connections were loose. I cant tighten them but I figured that if you push down on the right of the silver bar and press the power then it should work.
Hope I've helped.
Sean Ross
Posted on Jun 25, 2008
I had the same problem and solution one is the fix. I remove one of the memory modules and the system boots up fine.
Posted on Apr 02, 2008
  • 97 Answers
Itd gertting power of some kind but the boot post is not happening so it could be curtains but check the output at the plug to see if the mains adapter is pushing out the correct voltage
Posted on Feb 21, 2008
3 Suggested Answers
  • 90 Answers
SOURCE: Dell Precision M60 won't start up
Without battery connected it wont work. Better buy a new batterry connect it and plug it for charging for 8Hrs conitnuosly without switching on the laptop.
Posted on Apr 20, 2009
  • 4961 Answers
SOURCE: I have a dell d600 laptop. it won't boot up at all. if you push power button, the caps lock light blinks a few times and then it shuts off
Your power supply is probably dying. You can bring it in to a pc shop and have them test it or you can test it yourself with a psu tester like one of these:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=-1&IsNodeId=1&Description=psu%20tester&bop=And&Order=REVIEWS&PageSize=20
Posted on Aug 19, 2012
I have an hp G42 notebook when i hit the power button i hear it turn on but nothing happens only the caps lock key light begins to blink
hp blink error code:
caps lock blink once: cpu error
caps lock blink twice: bios problem
etc,,,,
please, what is the numer of the blink ?
Feb 14, 2014 | Computers & Internet
No power button light loops blinking light on caps lock and chrg light
Here is a link to a other forum that has a view links for Toshiba laptop error codes if your laptop is not under these just tel me what your laptop model number is.
http://www.hardwareanalysis.com/content/topic/51345/
Dec 30, 2013 | Toshiba Satellite Computers & Internet
G62 won't boot up
Take out the battery and wait a minute, then put it back and try again.
Mar 03, 2017 | HEWLETT-PACKARD HP Laptop / AMD Turion II...
Can't use old laptop computer Dell Precision M60; Windows XP password lost-no way to open to gain access to computer. Would like to reset password.
Boot computer Into safe mode. Open command prompt type this.
Net user *
PRESS ENTER
net user (your user name) *
ENTER NEW PASSWORD
ENTER NEW PASSWORD AGAIN
DONE
Apr 28, 2012 | Dell Precision M60 Notebook
I have a fujitsu e8410 which will not start up properly, when i push the start button it shows power but then the fan comes on and the cap num and shift lock leds flash and nothing else. can you help?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 31, 2012 | Computers & Internet
Lg 47lc7df tv blinks green light, no picture or sound
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jun 27, 2017 | LG 47LC7DF 47 in. LCD HDTV
I have a Dell Precision M60 laptop and the charger adapter's led light is on when i plug it in, but the laptop won't turn on.I've replaced the battery and tried a different charger but that...
Unfortunately it sounds like you have an issue with your motherboard. If you remove the battery and just try to power on the laptop using the AC adapter and it still won't power on then it's probably the motherboard. The power supply circuit (where the AC adapter plugs into) for the motherboard is integrated into the motherboard.
Sorry. If it's still under warranty Dell will replace the motherboard.
Sep 10, 2011 | Dell Precision M60 Notebook
Precision m60 power not staying on
hi first check addopter if power work fine then check ram if ok check proccessor if ok press main chip on board then check shortage may bee any fet or capceters shorts
Jul 18, 2010 | Dell Precision M60 Notebook
Dell precision m60 press the power button the screen blinks for a second the lights next to the power button stay lite for about 3-4 seconds then the entire laptop turns off. ANy ideas guys?
You could have a bad peice of memory or a bad memory slot. Pull the memory out and try one peice at a time in each of the two slots. If you only have 1 peice you will need to either borrow a peice of the same memory or buy it. You also could have a shorted battery so pull the battery out if the ram is ok and try to boot. Another idea is the cd rom may have a problem so pull it if the ram and battery are ok. After doing all this if the system will still not boot the motherboard must have a short and needs replacement. This model also had an issue with the power board where the power button is. The connector on the motherboard was poorly designed and very sloppy. Over time it gets worn and causes a similar issue. The temporary cure is to press very hard on the power button to see if it will boot and then leave it running. You can also put pressure on the underneath side around the docking port and press the power button. This issue however requires a new motherboard. The M60 is almost the same as the D800 infact most parts are interchangeable. You could switch out the motherboard to a D800. I refurbish the D600 AND D800'S daily so I am fimilar to this issue. Let me know how you make out. Phil pmgibs1@verizon.net
Feb 23, 2010 | Dell Precision M60 Notebook
Dell Precision M60 Notebook Logo
1,918 people viewed this question
Alun Cox
