Question about Toshiba TN50V71 50" Rear Projection Television
TOSHIBA TN50V71 POWER LED COMES ON BUT NO SOUND, NO PICTURE
When power bottuon is depressed, your hear the normal on clicking sound of a relay ,however no picture or sound comes on.could this be a horiz deflection circuitary probs? if yes how can i get a copy of the schematic to find the transistor?
techman
  • 3130 Answers
SOURCE: Power on but no picture or sound
Your problem is from the power regulator IC . Its an str type and has to be an original from tosiba or its parts distributors. Now you may have caused more problems as alot of peeps do trying the set over and over again thinking Oh the set will rest its self.. Nope sorry sir if a set goes bad and you try it once , and it dosent come back on . Its time to seek a repair person to repair and troubleshoot the set for you UNless your a technician? If your not Dont try to repair a tv as these have non serviceable parts for the consumer to replace! And can bite ya in the butt, if your not carefull. We techs cannot teach ya overnight how to fix something. Only assit and to point ya in the right direction. Good Luck
Posted on Jun 24, 2006
snakehead
  • 1074 Answers
SOURCE: Toshiba 50A61..power comes on but no picture or sound
my friend your tv got hit before you did the disconnections storm hit sets are a piece of work to fix, it is left with the circuit board burned.my advise is to buy a new tv.good luck
Posted on Jun 23, 2007
ctf1800
  • 4402 Answers
SOURCE: Toshiba 43A61 - No Picture, no sound
If your set all of a sudden won't come on, e.g., the screen is blank, but the LED on the under the screen next to the on/off switch keeps flashing, then there may be an internal fault on the set that needs to be reset.
To force the reset, try this:
  • Unplug the set and wait a few seconds
  • Replug and see if the video returns
Whenever the set senses an internal fault through its monitoring circuitry, it essentially shuts down the set. The flashing LED provides the indication that a fault has been detected. Removing power to the set resets the monitoring circuitry. When plugged back in, the circuitry again does a check of the system. If it finds that there truly is a problem, then the set is shut down and the LED will again flash. In this case, you need to call a service tech. Most of the time, however, the unplug/replug routine is enough to get the set up and running.
Posted on Dec 11, 2007
Slinteriors
  • 8617 Answers
SOURCE: tz61v61 toshiba 61 rptv theaterview
If the relay clicks you most likely have a leaky diode or bad transistor in the stand by or start up circuit. There is a manual available for that model called. Toshiba Power Supply and Shutdown circuit Troubleshooter. Its available at the following link. It gives step by step instructions so you can figure out exactly whats wrong with your set. The site emails it too you after you place your order and they also provide free unlimited tech support so you will have a resource for help if you need it. I am one of their on line support techs. I highly reccomend that Manual to any one with a toshiba that will not power up. Here is the link.
http://servicemanuals.vstore.ca/
Posted on Apr 12, 2008
SOURCE: TOSHIBA TV NO SOUND NO PICTURE, POWER LIGHT IS ON
I have a problem
Posted on Aug 11, 2008
My tv will not come on but I hear a clicking sound when I turn it on and of does anyone no why
this is normal for most tvs . the click you hear is a relay that turns power on / off to parts of your power supply
please post your make / model and exact fault taking note of any flashing led's these normally flash out refrence codes that tell you what fault is on the tv
May 15, 2012 | Toshiba Televison & Video
I recently picked up a Toshiba TN50V71 & am not sure where to start in troubleshooting it. There is no picture, & the led power light is steadily red.
Rear projection TV is made up of a TV, optical lens and a screen. So picture projection problems are from the small TV tube. Take off the back to reveal the TV and see what could be replaced?
Aug 16, 2010 | Toshiba TN50V71 50" Rear Projection...
I have a Toshiba 51h84.I push the power button and I get a solid red power light. There is a click from inside, kind of like a relay clicking on. No picture, no sound. If I leave it on I get an occasional...
Tv have "LAMP" indication LED light blinking?The tv projection lamp is dead,require changing.Hearing alot of clickings sound too?Mean the board,call the Ballast board is dead.Require change the Ballast too.The Ballast board,the board that help to ignite the projection lamp.
Aug 06, 2010 | Toshiba 51H84 51" Rear Projection...
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
NO PICTURE, NO SOUND On My Plasma TV.
Should have been 3300 UF 10V caps that were bad? Shouls have been replaced with 3300UF 18V. 50V is huge. If it was replaced with a 50 the polarity may be wrong or the cap it too big to be seated property. Sometimes the caps just dry out and even a normal looking one will be the culprit of no OSD. Are you getting an LED fault code blinking? That should be a red led. Do you hear the relay clicking.? When you replaced the caps did you charge them? Just plugging in the set without trying to power it on for about 20-30 mins. I may be able to help you
gysgt2u1@yahoo
Mar 05, 2009 | Philips 50MF231D 50 in. Plasma Television
Toshiba TN50V71
Shorted horz. output transistor
Feb 09, 2009 | Toshiba TN50V71 50" Rear Projection...
Startup Problem with my 42pf7321d/37 Phillips plasma TV
I need to know how long do you have the tv?In the other word,approx. how many hours you have put into it?
Secondly,did you wall mounted the tv or setting it close the the area which there is not much room for the back of your tv to breath?
solutiondoct
Nov 06, 2008 | Televison & Video
Toshiba cf32c50 tv will not turn on
This is a typical condition if the power supply has failed or a power-consuming circuit the supply services has exceeded a predetermined current draw. The relay you hear is preventing further damage or even fire.
You will need local tech help with this.
Sep 29, 2008 | Toshiba CF32F50 TV
I have a 40" Toshiba rear projection TV that has just lost sound & picture. The red power LED is still illuminated and you can hear something like a relay occasionally click at the back of the TV....
You are probably hearing a relay that is connecting, then disconnecting power because of a fault in the power supply.
Most modern sets try to control damage when a serious fault occurs by shutting down instead of allowing something to burst into flame.
You need on-site help with this one.
May 05, 2008 | Televison & Video
Toshiba TN50V71 50" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
