Question about Samsung HT-HDP40 System
I am looking for the clips that goes onto the raw speaker wire ends that clips into the back of the receiver
  • 2,019 Answers
Normally the speakers and receiver just have a hole that lines up when you push on the head, and a spring pushing back makes contact on the bare wire, when you let go. But if your receiver has jacks or screw terminals instead, then you will have to get them at Radio Shack. They just crimp onto the wire with a pliers or special crimping tool.
Posted on Feb 06, 2010
I have a yamaha RXSL100 receiver and when I turn on it shuts off
Could be simple, or you need to replace.
First the simple:
Check your speaker wire connections on the back. People tend to strip way too much of the insulation from the wire leaving exposed copper that may touch and short out against each other.
Here is a simple test.
Document how your speakers are connected paying attention to polarity. Make a chart, label with tape - whatever works for you - then disconnect all speaker wires.
Then do the same for any other connected wires.
With everything disconnected from the back of the receiver, turn it on again. If it stays on, then you probably had speaker wires shorted.
Reconnect all cables again, except the speaker wires and turn the unit on again. It should stay on.
Finally, reconnect the speakers, one pair at a time - being mindful to connect the bare ends cleanly onto the speaker terminal and that there are no stray strands that may touch anything. Turn the receiver on.
Repeat this will all speakers are connected. Your receiver should be find.
It is shutting off to protect itself because of a short on the speaker wire.
OR
It could have been damaged because of a short, or from lightning or you are hard of hearing and really like to crank it up - causing internal damage.
If so, you may need a new receiver.
May 03, 2014 | Audio Players & Recorders
Bose acoustimas double cube speaker
what the exact model # of the unit..?
Jun 17, 2008 | Bose Acoustimass 16 Speaker
Need help installing speakers to receiver
On the back of the receiver you will find the connections for the right and left speaker, OR if it is surround sound you will find, right front, right rear, left front, left rear, and center or bass. The connections can be RCA type jacks or they can be wire clip type.
Depending on the connections on the receiver and on the speakers, the wire will have to match the connections on each end. The wire needs to be large enough to handle the power output of the receiver. Wire can not be too large but it can be too small. Larger wire is more expensive, so there is no benefit in purchasing excessively large wire. Packaging should designate the power handling capability of the wire. The wire should not be much longer than is necessary to place the speakers where you want them. Too long wire unnecessarily cuts down on the power to the speakers. Don
Jun 21, 2011 | Yamaha DVX-C300 System
Looking for owners manual & how to connect to the speakers (6 each) HTP 100-SW sound system. Thanks
The front speakers go into the sub in the two bottom inputs from the receiver. the two upper are outputs to the actual speakers,SOYOU RUN RUN THE FRONT SPEAKER WIRES FROM THE RECEIVER TO THE INPUT OR LOWER CLIPS ON SUB,THEN RUN WIRES FROM THE OUTPUT OR UPPER CLIPS FROM SUB TO THE FRONT SPEAKERS.
Oct 08, 2010 | Pioneer VSX-305 Receiver
The Denopn avr 688 goes automatically into
The most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire2_bing.gif. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers2_bing.gif) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Jun 17, 2010 | Denon AVR-3300 Receiver
Circuit fault protection goes in every minute
The most common problem found on FixYa for Audio Video2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
May 31, 2010 | Denon AVR 3808Ci Receiver
Cant get the clips back on that hold back to top on kenmore s 70
Looking at the clip from the side there are two hooks. One goes into slots in the washer back and the other snaps into the cabinet.
Starting with both tabs on the clip facing up, the tab with the longer end hooks into the back. The shorter end lays on top of the holes in the cabinet.
Smacking the clip down seats it in the cabinet. It will only go in one way.
Sep 20, 2009 | Kenmore 22422 Top Load Washer
Philips DFR 1500 Service Manual or where to find parts!
how do i turn up the two rear surround speakers on my philips dfr 1500
Mar 16, 2009 | Philips Audio Players & Recorders
Insignia nsr2000 on/off problem.
had the same problem... turns out the copper on my red and black speaker wire (on the speaker, not receiver end) was touching - causing my receiver to go to standby (self-preservation probably lol). i pulled the wires further apart so the copper ends weren't touching and that solved it.
Jan 20, 2009 | Insignia 200W Stereo Receiver
My Kenwood KR-V5570 receiver powers off when I try to run a medium to high volume and the standby light blinks
i had exact problem.
the bare wire speaker cables that connect via a clip connecor in back of the receiver are pushed too far in. something inside is shorting out with the speaker cables. solve this issue by either tightly twistng or soldering the wire ends ( then clip the ends about 1/4 inch long). watch out for the same issue of electrical shorts at the speaker end of the cables.
Apr 27, 2008 | Audio Players & Recorders
Samsung HT-HDP40 System Logo
145 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
