Question about Car Audio & Video
How to hook up a kenwood car sterio in a 1992 saturn sl2 car.my radio was stolen and a bought a kenwood and we dont have the color codes for wiring them together
  • 171 Answers
1992 Saturn SL2 Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange
Car Radio Ignition Switched 12V+ Wire: Yellow
Car Radio Ground Wire: Black
Car Stereo Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amplifier Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Posted on Feb 07, 2010
What colors are the power wire that i hook up in a 2002 saturn sl2
What power wires and what are you hooking up?
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Apr 06, 2013 | Saturn SL2 Cars & Trucks
I have a pioneer DEH 525-W car sterio harness and colors do not match to that of the Saturn L2 1999. How do I connect this car sterio?
Just go to Best Buy and buy the Saturn L2 1999 Harness . then it will match. Harness cost like 20 bucks.
1st STEP
Things to get from BEST BUYor RADIO SHACK.
1. Black electrical tape
2. (Optional) for quality connection Solder & Solder gun
3. GM (General Motors) Antenna Adapters
4. GM 1999 Car Harness
5. GM Saturn L2 1999 Car Kit
STEP 2 = Match the colors of the car harness you just bought to the harness of the radio (DONT PLUG IT INTO THE CAR YET CAUSE YOU MAY SHORT OUT THE POWER WIRE TO GROUND) twist the same color wires together and then tape them so it wont be exposed to get shorted out and damage your radio or blow fuses in the car.
STEP 3= plug in the complete harness to the radio and the car and also plug in the Antenna adapter to the small antenna jack of the car that converts it to a larger jack so you can plug it in the back of the new pioneer radio that has a larger antenna hole. Now test the radio it should work unless you had blown your radio fuse in the car already which is easy to replace.
STEP 4 Unplug everything from the radio and install your CAR KIT. Then slide your radio sleeve in the rectangular hole all the way flush and use a flat head screw driver and bend the tabs of the sleeve(Radio Cage) so that the sleeve wont move.
STEP 5 make sure your harness & antenna is sticking out of the sleeve so you dont have to fish it out later when you have finished mounting the car kit to your car. Put your car dash back together and you will see only a rectangular hole with a harness and antenna adapter sticking out only.
STEP 6 plug in the harness and antenna back into the radio and slide it in halfway only and test the radio again making sure everything works. If it does then move it all the way in till it locks into place. last snap in the face trim ring into place to cover the silver cage lining.
THERE YOU ARE FINISHED
Apr 09, 2010 | Car Audio & Video
Code 84 for 92 saturn sl2 check engine code
go to autozone they will give you a print out wile the thing to check. bobg22
Nov 12, 2009 | 1992 Saturn SL2
I Need the Wiring guide
May 21, 2009 | 1992 Saturn SL2
Need wiring color code for a 2000 saturn SL2 for hooking up a trailer light four pin connector
The trailer wires are left turn, right turn, running lights(the smaller elements on both tail-lights and any side lights) and ground. Energise the corresponding lights and connect the wires accordingly. Find a good ground. A piercing test probe will find the correct wire for you if you can't track it to the bulb.
May 06, 2009 | Saturn SL2 Cars & Trucks
Sterio wireing
you will need to get a cord that connects to the sterio and then you need to match them up with these wires
the colors for the radio that are hooked up to the car are
  • orange is power
  • red is egnition
  • blue is power antena
  • black is ground
other ones will most likely be the sterio wires you just need to find colors that look a like and they will most likely match
hope this helps
Apr 07, 2009 | 2000 Ford Focus
After market stereo install
  • orange is power
  • red is egnition
  • black is ground
hope this helps
Dec 12, 2008 | Pie Hon03 F/Mm Car Stereo Wiring Harness...
When i hook up my ipod to my kenwood kdc mp728 i cant figure out how to play it through the radio
it should be in aux try to press source buton and see if that is an option if not an alternative is to hook it up on the back of the cd player in the audio in or aux or aux 2 using a wire adapter from walmart in the car sterio section
Sep 14, 2008 | Kenwood Car Audio & Video
Swapping out a factory radio in a 2005 ford taurus
I don't know about the air bag but you need a special fit kit and wiring harness due to the climate controls being built in with the radio as one unit. The new kit separates the climate controls from the radio, and leaves a hole for the radio of your choice to fit into. These kits are expensive and I suggest you try to get one from ebay. Sorry, thats the downside of a Taurus.
Dec 07, 2007 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Car Audio & Video Logo
483 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
