Question about HP LaserJet 1320 Printer
My HP Laserjet 1320 won't print even modest sized PDF files. The Printer Window says "Error-Printing" I've had this problem for years. How can I get my printer to print PDF files? I increased the memory in the printer, but it didn't help at all. Dave E.
  • 41 Answers
If you are using a PS (post script) print driver, delete it and install the PCL driver (PCL5 or PCL6 if available). May help, not positive. I have seen lots of pdf printing problems with PS or incorrect model drivers.
These drivers are free to download at "support.hp.com"
Posted on Feb 06, 2010
My hp laserjet 1320 printing is printing too slow
If you're running a Mac, when you try to install the LaserJet 1320, it may suggest that you use the driver set for "HP LaserJet 1320 Foomatic/pxlmono." Do not use those settings. I had to reinstall my 1320 recently and since it said that was the recommended choice, I selected it. If I printed just text, it worked fine, but even a tiny 50KB image would take 5 minutes to print. When I reinstalled it again, I selected the option "HP LaserJet 1320 series," and everything works just fine now.
Apr 12, 2012 | HP LaserJet 1320 Printer
Maximum file size for printing on the hp color laserjet 5500n - having issues with pdf files
If you are getting 49.XXXX error codes while printing PDF files, you can try upgrading the machines firmware.
This seems to be a common "PDF file printing" problem with the LaserJet 4250.
Oct 25, 2010 | HP Color LaserJet 5500 Printer
Hello,my hp laser jet 1320 does not work correctly,I work under an office network, some time it prints and some time does not print specially about pdf files or high size files, the alert is: fail to...
Is there a typical application you are using? I noticed that file size (especially in adobe) can be an issue. If you go to printer settings (start / settings / printers / right click on the 1320 and select properties) choose device settings and the very bottom item is printer memory. I would increase this to like 80mb.... hope this helps
Jul 19, 2009 | HP LaserJet 1320 Printer
Hp 1320 prints blank pages
My HP 1320 printer is printing blank pages and it will not even print test pages etc
Nov 03, 2008 | HP LaserJet 1320 Printer
HP Printer 1320 PCL XL error
hi,
I'd suggest downloading and installing the PS (PostScript) driver from HP here: http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=410624&prodTypeId=18972&prodSeriesId=410622&swLang=8&taskId=135&swEnvOID=228
Then use the PS driver when you're printing .pdf files. Use your existing PCL driver when printing all other types.
i hope it would help you...
Oct 13, 2008 | HP LaserJet 1320 Printer
My hp laserjet 4 plus printer cannot print excel files
wherer are you printing this, A4 is european, north america would use letter, etc..
if you go to control panel, open the printers and faxes folder, right click the printer in question, a window will pop up, click on properties.. a new window should open. click on "Printing Defaults" or "Printing Preferences" then click on "Advanced" ( I believe it should be to the lower left) that will open another window, in paper size make it Letter if your in N America, A4 for Euro.. this will set the deafult print..
Click ok, then print a test page from the general tab..
The reason you getting this LOAD LETTER message. your excel page setup is set to print to letter, your machine is set to print top A4
If you open Excel then go to Print then a window should pop up where you select the printer you want to use, click on Properties, then Lay out, then Advanced, and input the correct paper size before you print.
does this happen with all excels files, or one particular?
Create a new Excel file, and try printing it.. possibly could be in that particular file. I have seen this happen alott particulary with PDF files.. Where the incorrect paper size is in the file..
Sep 23, 2008 | HP LaserJet 4 plus Printer
Re: HP 1320 won't take the tray designation for 2 and 3 Help
Hello classygirl,
I had this exact same problem and resolved it by downloading the HP LaserJet 1160/LaserJet 1320 North American and Western European Full Printing Solution which can be downloaded from support.hp.com.
Because the 1320 does not have a built-in interface, installing the basic drivers will not work. You must download and install the full 400+mb package.
Hope this helps!
Aug 28, 2008 | HP Laser Jet 1320 Printer
Not working on window 2003 server as a network printer
I have had a similar issue with both laserjet 3005N and 1320N machines setup as network printers on a windows 2003 print server. Both machines install correctly and print test pages but once you push to much of a print job to it (in my case it was a 12mb pdf file) the printer stops printing and never prints again for some reason. After a quick reboot a test page will print but what gives?? Buffer issues? Not enough ram? None of this makes sense since the printer displays nothing and just stops printNo test pages or anything. I tried re-installing it and rebooting it. Nothing.
Jul 12, 2008 | HP LaserJet 1320 Printer
HP Laserjet 1320 - Acrobat problem in XP
please reinstall the printer driver and also reinstall your window
Sep 19, 2007 | HP LaserJet 1320 Printer
Pale print on PDF files
It sounds like a driver problem. Try replacing the driver for this printer on the printers folder, using the HP LaserJet Series II. With this driver, try again the PDF file and see if it prints correctly.
Jul 25, 2007 | HP LaserJet 4345mfp Printer
HP LaserJet 1320 Printer Logo
649 people viewed this question
Seeker5211
Seeker5211
