Question about GE SCA2001FSS Advantium Electric Single Oven
Our exhaust fan is insuffient, not enough draw,causes smoke alarm to go off, any suggestions?
  • 572 Answers
Clean ur vent
Posted on Feb 07, 2010
My Hotpoint BS22 electric fan oven timer alarm has gone really quiet. How do I turn the volume up??
You can't unfortunately. It sounds like the control board is starting to fail. I would suggest having it repaired before it completely fails. Therepairshack.com offers a service that can fix this for you.
Nov 29, 2015 | Hotpoint Ovens
How to repair exhaust fan rattle?
You can look at fan closely and see if there is a set screw holding the fan to the shaft. It could be loose causing the rattle. If that is not the problem then see if the shaft has a lot of play in it. It could be worn out and allowing the fan to rattle. If that is the case then replace the fan
Apr 26, 2014 | Bosch HBL 642AUC Electric Single Oven
I just used the self cleaning option for the first time and the entire house filled with hazy smoke and a very strong , almost chemical odor - what is wrong?
The self cleaning setting goes to a very high temperature ,it is this high temperature that cleans the oven ,the remains that was left in the oven.during the cleaning cycle would have likely caused the hazy smoke and strong odour . Recomendation : use your vent fan , remove heavy residue from the oven before starting the cleaning cycle.
Dec 03, 2010 | Frigidaire Ovens
Broken oven
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Jun 08, 2010 | Ovens
When cleaning my oven, the whole house fills with smoke.
sell cleaning on ovens just causes problems like this, it is normal. it cleans by burning everything inside at high temp. i always recommend cleaning the old fashioned way, once a year , with oven cleaner, or as req. roasting an oven itself to clean it is insane i think
Jul 23, 2009 | Ovens
NEFF OVEN PROBLEM - SMOKE AND FUMES COMING OUT OF OVEN
Take the cover off that is surrounding the fan and you will probably find food or something there or on the fan blades. If it is not a food smell, then there is probably some wiring that is burning. I suspect that there is food behind the housing of the fan.
Feb 02, 2009 | Ovens
Oven smokes
If it smoke smells of burnt food or grease you have something on the surface of the element which is burning off.
If it is an acrid smoke it could be the element itself is on the way out or the fan (if it is a fan oven).
You need to make a visual check of the element/fan to ascertain their condition and clean or replace as necessary.
Nov 30, 2008 | Ovens
Jenn air single wall oven model jjw8530BAB - exhaust fan not working properly
in not sure but i think that fan runs off a thrmistor that goes to the contol board.open the oven door and look on the right side of the oven see if theres a metal looking bulb.
Aug 19, 2007 | Jenn-Air JJW8530C Expressions Collection...
Hotpoint oven smokes after one minute
Sounds like build up of fat and grease on element.
Only thing to do is leave it on and it should burn all the fat off.
Sep 22, 2006 | Hotpoint DY46 Style Line Stainless Steel...
GE SCA2001FSS Advantium Electric Single Oven Logo
63 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
