Washing machine will not spin. No special noise leading up to this problem. Local repair is several days out. They guessed it was a failed sensor based on the model and systems. Looking for any help on location of and relative ease of replacing it myself, if I can get a sensor, part #.
  • 714 Answers
It doesn't spin If your washer won't spin, check these: It doesn't pump or spin It pumps, but doesn't spin It spins only with the lid closed It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician. need parts? try Repairclinic.com
Posted on Feb 07, 2010
Testimonial: "Still troubleshooting, so no testimonial as yet. The general discussion of the attached is very helpful in logically laying out if-then scenarios"
  • Roger Miller Feb 10, 2010
    what type of washer is it? is it a direct drive unit? (have a transmission) my washer wasn't spinning and found out the clip that holds the clutch arm on the basket drive tube had ground off the bottom of the tube and the arm fell down breaking the two little fingers off thus no spin, guess i'll be buying a new one! also does it pump the water out but not spin?
Does not spin?
I can only guess that the drive belt has finally broken .call your local repairman
Sep 22, 2015 | Washing Machines
My machine is making a loud noise and getting hot when spinning, any idea if repairable?
well it would be helpful to know exactly what is getting hot but guessing the problem its perhaps the drum bearing failed and needs replacing.
Oct 08, 2014 | Haier Washing Machines
My LG Front Load washing machine is making a grinding noise on spin cycle I believe it is coming from the motor
Hello. The noise you are hearing on spin is a failed basket support bearing. Depending on the model, you are looking at a cost of a professional to repair it of around $400+. If you do it yourself, around $200. This is a common failure on LG washers.
Apr 28, 2014 | LG WM2487H Front Load Washer
Service manual need
I have a malber washing machine and it is broken. One day, a loud noise came from the machine then, the machine would not spin out nor did the water drain from the machine. I would like to find a repair place who could fix my machine. I live in Providence, Rhode Island and would like to locate someone local. Can you please help me?
Apr 26, 2013 | Malber P21 Front Load Washer
My built in smeg wd16ba ( I think ) washer dryer failed to drain. This has happenned before so i manually drained it and checked filter. I then found the usual spare pennies and hair grip. When I tried a...
Repeat what you have done and see if any wires were accidentely removved specially of the water level sensor. If so connect them once again . remove the plug from the power and reset the machine holding down pause with power plug in..
Checck tthe drain valve once again if the wires have shorted
Sep 17, 2010 | Smeg WD16BA Front Load Washer / Dryer
LOUD CLATTERING NOISE DURING LAST MINUTE OF FINAL SPIN CYCLE
the loud clattering noise you hear is the main bearing it needs replaced.the main reason for the repair men doing a runner is its not an easy job and takes time and know how.if i was you i would get some estimates on this job,i would guess they will be high because no one wants to do it.Would you not consider a new machine???????anyway good luck.adrian,,,,
Jul 09, 2010 | GE Profile WPRE6100G Top Load Washer
Hi my hotpoint washing machine is near 3 years old the last few weeks it is making a terrible noise when on spin only. \r\nthe noise is really loud but everything is washing and drying the same its just...
Sounds loike the main drum bearings have failed.
Spin the drum by hand from the front, and if it feels rough, or is rumbling or grating, then the main bearigs have failed.
Quite an expensive repair, unless it is covered by the Hotpoint 5 year parts guarantee, check with Hotpoint.
Jun 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
My whirl pool washing machine no longer spins. I just stopped on day. I can hear the motor trying to turn the drum but it doesnt.
Hi. This is a possible broken belt. You will need to access the drive assembly to confirm. The symptoms you have posted will often lead to a separated belt.
NOTE(IF this is a top loader, and you are hearing noise during the spin attempt, this will lead to failed motor coupler. Please disregard this note if the unit is a front-loader)
Oct 08, 2009 | Whirlpool Washing Machines
Washing Machines Logo
76 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
