Samson 40" TV, when power button is pushed it takes almost one and sometimes a full minute for teh TV to power on. the power on indicator comes on, then off, after the third try it stays on and TV works fine.
  • VicML Feb 16, 2010
    thanks for the info, Iafter doign all of that adn checking the Hz out put transistor (checked ok) I found the problem. It was a shorted high voltage diod. for other future ref.
    Thanks
  • 5,138 Answers
I need to know what the model number is it will be printed on back of TV.Also have you removed back to Look for Vented or puffed up on top capacitors 1000uf 10v /16v, 470uf 25v ,2200uf 16v ? If you see any that are vented they are bad, another thing is that you may just have poor solder connections and the boards need to be resolder.
Posted on Feb 15, 2010
  • ladywinn
    ladywinn Feb 16, 2010
    Mats Electronics is a good Part company if you need parts/supplies 1-800-628-1118
    or visit their website.
When turning on tv. screen will display Bravia image & then go blank. red light flashes SIX times
Power off the television. Wait a few minutes, then power it back on. If this does not correct the issue leave the power on, point your remote control towards the Sony television and hold the down arrow button. While holding the down arrow button press the "Power" button. Release the down arrow button and the Sony TVicon1.png will reset itself to factory settings. Once the television performs a scan on itself your problem should be gone.
Good Luck Ed Pinero
Read more: How to Troubleshoot the Standby Indicator Flashing on a Sony TV ' eHow.com http://www.ehow.com/how_5925008_troubleshoot-indicator-flashing-sony-tv.html#ixzz2KBk1cWbu
Feb 02, 2013 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Samsung LN-S4051D slow to turn on.
You are likely to have a module bad....part number BN94-00864A and if you take it out (unpluggs) you should inspect it for capacitors that may be domed or pooched up at the top. If so they should be replaced first before getting the module as the capacitors are about $1.00 each. Do a search for Samsung parts online if you need the module and call them toll free
Mar 16, 2008 | Samsung LN-S4051D 40 in. LCD Television
Tip
No picture, sound clicking
<span><span>TV</span> <span>can not be</span> <span>turned on</span><span>, the indicator light</span> <span>blinking</span> <span>followed by</span> <span>a clicking sound</span> <span>from</span> <span>behind</span> <span>the TV.</span><span> Sometimes</span>, TV w<span>on't power on until</span> <span>a few</span> <span>minutes</span> <span>or</span> <span>a long time</span><span>.</span><br /> <span>The problem</span> <span>is</span> <span>coming</span> <span>from</span> <span>the capacitors</span> <span>in the</span> <span>power</span> <span>pcb</span> <span>, it has been</span> <span>leaked</span> <span>and almost blew </span></span><span><span>physically.</span></span><span><span></span><span></span><br /> <span>The cause of</span> <span>the</span> <span>leaking</span> <span>capacitors </span>are <span>because of</span> <span>heat</span> <span>or</span> <span>indeed</span> <span>because of</span> <span>the</span> <span>life</span>time <span>or</span> <span>well</span> <span>of</span> <span>power</span> <span>that</span> <span>is often</span> <span>spotty</span><span>.</span><br /> <span>The solution</span> <span>is</span> <span>to</span> <span>replace</span> <span>the capacitors</span> <span>with a</span> <span>voltage</span> <span>value</span> <span>greater</span> <span>than</span> <span>the original</span> <span>(</span><span>16V</span> <span>-</span> <span>25</span> <span>V</span><span>)</span><span>.<br /><img src="mas_baz_4.jpg" /><br /><br /><br /></span></span>
on Mar 30, 2011 | Samsung LA40M81/BDX 40 in. LCD TV
TV does not show picture when turned on. Some times it does not come on. when it does it goes to a split Bright green screen, After that it will go to a lot of different screens with lines, full screens of...
It is possible that TV processor could have some garbage it do to a small voltage surge, and if you leave your set, unplug from the wall for 40 min,. that will reset it back to normal. If thgat don'rt work then remove the back and check for a couple of bulged electrolytic caps on the power supply nthat need change, or change out the power supply.
Nov 12, 2010 | Protron PLTV-26 26 in. HD-Ready LCD...
Aquos model LC46D64U...approx 2 years old..Won't power up and get the power light flashing 3 times then the OPC light once..which is repeated...Any ideas...I believe this is quite common with Sharp TV's
I have a Sharp LCD 46 in.tv do this often.Yes,it is.This problems,the tv Tuner signal board have problem,but the tv is still useable.The POWER and OPC light indications flashes.Just push the power switch again,wait see tv turn,not POWER and OPC flashes again,push the power switch agian and wait.Have to do this like 3 or 4 times sometimes,than the tv backlight will come on,tv will work.Don't know but,if u require to pushing power button more 10 or 12 times,the tv Tuner signal board don't take an turn on the tv backlight get the tv to work.The Tuner signal board is dead,time to replaced the tv Tuner signal board.
Oct 18, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Power light comes on for about 30 secs, something clicks and both power and ocp lights start blinking contineously. the screen does not light up
I have this model of the sharp tv.Happen to me very often the Power and OPC LED light indicators blink continueosly.Not the power supply board,it the Tuner board that take in the comming broscast signal that have the problems.You still can used this tv.Push the power button sometime the tv it will work right away.Not,each time POWER and OPC lights continueosly blinks.Just push the power button again each time the POWER and the OPC continueosly blinks.Just have push power button again about 4 times each time Power and OPC blinks recycles,it will finally show the backlight and picture come on.My guest,if u do this by pushing power button to recycles about 10-12 times each time the POWER and OPC blinks it time to change the Tuner signal board.
Jun 03, 2010 | Sharp LC-C4655U 46 in. LCD TV
TV Turns Off Automatically While Watching
Stop trying to turn on the set. You are causing more damage. The hissing sound you are hearing is either a High Voltage Transformer on the SMPS (Switched Mode Power Supply) indicating a short somewhere in the set or some capicitors that have shorted out. Also there can be a CRT that is leaking cooling fluid onto the Main bd or the Power/Deflection bd or both bds. Have a trained Samsung tech troubleshoot the set.
Jul 15, 2009 | Samsung HCM4215W 42" Rear Projection...
Conair steam cleaner sc20 - plugged in, pushed button, no steam
If you need instructions go to www.HandBookLive.com. There are videos for GS4 and GS10 under Appliances category. It says that steam is produced in about 5-6 minutes after you turn power on. Also there is a low water indicator light on GS10 that kills power to teh unit if the water level is low. Maybe that's the problem... Not sure if sc20 is similar
Apr 15, 2008 | Conair Compact Garment Steamer Iron
Sony FWD50PX2/S 50 in. Plasma Television power problem
It does sound like a power supply problem but that can be misleading because a problem somewhere else in the TV can be "holding down" the power supply. This can usually be determined by using some isolation techniques.
Aug 08, 2007 | Sony FWD50PX2/S 50 in. Plasma Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
