Cant fi external speakers
Cant figure out how to connect external speakers . i have tried through the monitor output but nothng seems to work and i find the internal speaker system very poor
Slinteriors
  • 8617 Answers
SOURCE: no sound from internal or
Defective audio output ic is most likely the problem
Posted on May 04, 2008
  • 124 Answers
SOURCE: need to turn external speakers on (ilo tv)
What is the model of the DVD player and the Television.
Posted on Nov 12, 2008
  • 26 Answers
SOURCE: hooking up external speakers
Do you have a headphone jack ?
You can hook up there that would be the easiest way.
Posted on Feb 27, 2009
SOURCE: Connecting SRS-BTM30 bluetooth speakers to my vista laptop
This has also been sending me around the bend. I resolved it by disabling the speakers on my laptop. To do this go into control panel, then hardware and sound, then change system sound. Select your speakers and disable them. This allowed me to play music through the speakers. You can also re-enable the laptop speakers after this.
Posted on Mar 28, 2009
SOURCE: No sound from external speakers system
Look into your monitor settings and computer settings and see if you can reverse the "input" and "output". If both are set to line in or line out then they pretty much cancell themselves out.
Posted on May 23, 2009
Is there a way to hook up external speekers to my dp32642 tv Ive tried the digital output with powered speakers etc. no luck getting any sound
I guess you tried it in a coacial out female tulip output your spreakers can not decode digital audio you use active speakers this means they got an Amp inside
to get digital out you need a reciever that supports digital in
Dec 12, 2014 | Sanyo DP32642 32" LCD TV 1366x768, 60 Hz,...
Our projector shows a blue background and does not seem to be connecting to the computer
Several things to check.
Make sure both the input selection on the projector is for PC and make sure the PC output selection is for the external output, as in an external monitor. The PC does not care or need to know that the external output is a monitor or projector.
If none of these works, try a different cable and output on both the laptop and projector ie, Switch from PC output to a DVI or HDMI.
Nov 22, 2014 | ASK Proxima Office Equipment & Supplies
The speakers on my monitor dont work but if i plug headphones in th back of my computer i have sound.had sound in the eveningbut in the morning had nothing is my moniter dead??
First try wiggling and twisting the the mini jack in the socket, that feeds the monitor speakers signal.
Both ends.. at the PC and at the monitor. Hopefully it's that simple.
The other thing to check is - Do you have a seperate power supply for the speakers? Ck it's still plugged in, to the power, and to the speaker feed.
Test the output with a meter to see if it failed. This can be replaced. (Would be cheaper to buy new speakers)
IF no joy at this point, it possible the speaker circuit in the monitor has failed, or the internal power feed to the speakers (if no external one)
Replacement external speakers are not at all expensive, unless you really need Hi Fidelity. That seems unlikely, as you are using monitor speakers which are as poor fidelity as most come.
I'll bet a $25 set of external speakers will sound 10 time better than the monitor ones.
Feb 10, 2011 | Computers & Internet
My monitor doesnt work while my cpu does
Try connecting the monitor to another desktop/laptop, to see if the monitor still works.
Try connecting another monitor to your computer,
to see if the video-card on your computer is producing any output.
Feb 02, 2010 | Fujitsu Siemens SCENIC P300 PC Desktop
Speaker connection for LG W2053TX monitor
This model of monitor does not come with speakers. In fact very monitors have speakers. You will need separate speakers for sound. Some monitors do come with external speakers which hook onto the monitor at the sides but they are still connected to the PC via a lead with a 2.5mm stereo plug into the sound output..
Dec 12, 2009 | Computers & Internet
My new monitor w/HDMI cable replaced my old one which had a serial cable and now my external speakers do not work ever since. Also, i have 1 onboard sound card and 1 external card. Could they be...
I doubt that there is a "conflict" between the new monitor and your audio-system.
Check that Windows has not "muted" the audio-output,
or that the slider is not set to "minimum" volume.
Check that the audio-connector from the speakers is connected to the GREEN socket on (one of) your audio-cards.
Try connecting the speakers to the headphone-output of an iPod,
to see if the speakers work (they might be quite quiet) at all.
Dec 02, 2009 | Intel Motherboard
I have a Sceptre X7G Komodo II 17" LCD monitor/built-in speakers
You would need to connect the speakers to your computer. There should be a little jack on the back of the monitor marked audio. This will need to be connected to your soundcard jack for front speakers. Once this cable is connected you should have sound from your speakers. Hope this helps.
Aug 15, 2009 | Sceptre X7G Komodo II 17 in. Flat Panel...
Nonworking speakers
For your monitor with built in speakers, there should be a cable usually the plug is green in color, coming from the monitor which needs to be plugged to the back of the computer for the speakers to work. If you don't see a cable, then there is a plug on the monitor where a cable would go.
Yes you can connect external speakers. They plug into the back of the computer. There are usually round ports on the back colored blue, pink, and green. Figure: http://www.ultimatepcrepair.com/files/bsound.jpg (sometimes there is more, depending on your computer) The speaker cable plugs into the Green color one.
If you need more help just comment.
Aug 14, 2008 | Proview PS 776 Monitor
New moniter old computer
does monitor have speakers if yes it will have a speaker connection with the video lead connect it to speaker output on computer.
If monitor does not have speakers you will need to buy or use external ones
Jul 15, 2008 | Computers & Internet
Pc hook-up/sound issues
on the bottom of the monitor there is a audio input. you must connect you pc output(green) to the monitor input with a male to male audio cord. you can also use a rca cord with two adapters.
Oct 24, 2006 | ViewSonic N2750w 27 in. HD-Ready LCD...
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
