Question about Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower
3.5 horse starts after primed runs for a coupe of seconds then dies.
  • 332 Answers
Your primer is sucking air and must be replaced
Posted on Mar 08, 2010
Why does my 445 husqvarna die after I start it in cold weather -17c
if the fresh air door is open to carb box, close it and you need to get a cold weather kit,which consists of air cleaner hood and a fly wheel suction reducer
Feb 22, 2015 | Husqvarna Garden
Car smells like gas and is hard to start
My Pontiac G5 Gt coupe did the same thing. There was a recall on the gas line and it was replaced.
Jul 14, 2012 | 2007 Pontiac G5 Gt Coupe
Mower starts and runs for 10 - 15 seconds, then dies. Will almost start again, but soon will not even kick over. After a while, it will start for a few seconds. This is a 15 horse Tecumseh that looks...
It sounds like a carburetor issue. The jets are probably gummed up from the old gas that was in it. Remove the carburetor and clean it out with a can of carb cleaner. Then reinstall.
May 22, 2011 | Tecumseh Enduro Vertical Engine 16 HP 1in...
Snow blower 1 year old, was using it ran out of gas , put in new gas, went to start, it ran for few seconds then dies,, prime it it runs few seconds dies, has NEW gas ans new plug, only runs for seconds...
If it has a fuel filter on it change it and that should get you going again. If not the dirt that was in the tank is prob in the carb cleaning the fuel bowl and jets should get you up to par. Hope that helps
Feb 02, 2011 | Sport & Outdoor - Others
Lawn mower will start when primed but will only run for few secon
It starts because of excess fuel from priming. It usually then gets it fuel from main jet in carb.
You need to find the main jet and run a fine piece of sturdy wire through it. That will restore fuel flow so your mower can continue running after the priming fuel is gone.
This is a good thing to learn. Main jets tend to clog a lot on mowers these days.
Jul 05, 2010 | Poulan "Poulan" Push Mower
When I start my 10hp mercury outboard after priming it will run for a few seconds and then die. IF I push the throttle only button and rev it up before priming or set the low idle up higher and then prime...
Be sure to run the recommended fuel mix. most modern 2 stroke outboard engines run on 100 to 1, some times the mix is on a decal inside the cowl.
Cheers, Timo.
Feb 27, 2010 | Light Outboard Motor Boat Bass Fishing...
1998 gmc 2500 wont keep running
The anti thieft system is keeping it from running.
Dec 13, 2009 | 2004 GMC Sierra 2500
I have a huskavarna leaf blower 140 back pac i run it for 5 min then it srarves for gas let off on the throtle for 10 seconds put on full it gos to full rpms the starves agian
Carburetor may need adjusting or rebuilding. I would try mixing up some fresh fuel mixture and try that first. Use gas from the station not from the can sitting in the garage.
Good Day.
Oct 28, 2009 | Husqvarna Backpack Blower, Model No. 356bt
My Mazda mx3 starts up idles for a couple seconds then dies.
Before you replace the fuel pump, I would check the cheaiper parts first. Such as fuel filter and injectors.
Jun 17, 2009 | 1992 Mazda MX-3
Tiller won't stay running
If you choke or prime the engine, it starts up for a second or two and dies, the carburetor need to be cleaned/repaired.
May 25, 2009 | Mtd Products Yard Machines 158CC Tiller
Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc  650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower Logo
559 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
