Question about Brother MFC-8220 Fax
Scanner not working
I discovered the problem when trying to scan from the document feeder today. It would pull the paper in, but stop once the paper got to the scan head. Next I tried to scan from the flatbed and I noted the scan head did not seem to be moving... same deal with copying. I finally received a "Machine Error A6" code and a message to call Brother support... they were of no help and said to take it to a service center... so is anyone familiar with what might be my issue? My deduction is the scanner bar/head is not moving. Called the service center, they connected me to the Philippines, walked me through a host of different options, told me to clean the scanner head with alcohol- twice- no success. Probably not worth fixing, probably get a new.
  • Anonymous Feb 06, 2009
    I had the same problem and all indications were that it was terminal. I bought another Brother MFC which I use JUST for faxing and copying. My "bad" printer has been working for months as a PRINTER, so that is what I am using it for. Ironically that functionality is on it's way out too since it is making ungodly noises, but I extended the life almost a year.
  • 286 Answers
A6 is a scan failure detection.
This sounds to me like the motor running the scanner is not working. However, there are three or four causes of this error. The home position sensor, the motor, the CCD, the main board and the engine board.
You should be able to find the sensor that detects the scanner lid. Fool it with a piece of tape or a finger. Look at the scanner after pressing copy to see what is happening.
You could open up the scanner and check the movement to make sure it's smoth, but this is a lot of work. The best option is to pick up a used scanner from a Brother service centre. Install it and see if it solves your problem. Of course, you wouldn't be able to return it if it did not solve the fault. This is why Brother recommended you take it to a service centre, the troubleshooting is very in-depth for a fault of this nature.
Posted on Feb 06, 2009
Canon imageclass D1120 printer says: feeder paper jam,
Hi Try this method
To "Settings/Registration Table"
You can specify the method for restarting scanning of documents when a paper jam occurs in the feeder.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
  1. Press b_in_add.gif(Settings/Registration) ? [Function Settings] ? [Common] ? [Scan Settings] ? [Feeder Jam Recovery Method].
  1. Select [From 1st Page] or [From Stopped Original] ? press [OK].
Details of each item are shown below.
[From 1st Page]: If a paper jam occurs in the feeder, scanning starts again from the first page of the document. [From Stopped Original]: If a paper jam occurs in the feeder, scanning starts again from the page of the document scanning was interrupted.
Jun 10, 2011 | Canon ImageCLASS D1120 All-In-One Laser...
Automatic document feeder pulls paper through only part way
You need to replace the document feeder motor the gears on the motor shaft are split and slipping. New motor is 12.72 at http://www.compassmicro.com/parts2.cfm
Jun 03, 2010 | Epson Artisan 800 All-In-One InkJet...
Will not scan from glass but feeder will?
Using your scanner program such as PaperPort, you really have to pay attention on where the document/photo is located for scanning.
Steps
1. Click on Start, Programs, Paperport
2. Right above the Word "SCAN", you will have several options on;
a. Document or Photo
b. Flatbed or Feeder
3. Once step 2b has been selected, the M20i will scan your document per your instructions.
Note:#1
If you place your document on Flatbed but your selection on your screen says "Feeder" where do you think the scanner will look for your document? The answer is --> Feeder!!!
Note #2
Make sure that you click Accept,& DONE, other wise M20i will just sit and wait for your next command.
I hope this resolves the confusion between GLASS and FEEDER scanning.
Jun 29, 2009 | Xerox WorkCentre M20i All-In-One Laser...
ADF paper jam, when there is none
If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
  1. Close the scanning application (such as PaperPort)
  2. Turn off the scanner and the computer
  3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
  4. Plug the ADF cable back in
  5. Turn on the scanner power
  6. Turn on the computer
  7. Try scanning again
For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
To clear a paper jam:
  1. Open the Automatic Document Feeder cover.
  2. Remove the jammed paper and close the cover.
If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
  2. Look for the small black plastic arm
  3. When you press on this arm, it should move freely up and down
  4. If the arm is stuck down, please contact Technical Support for troubleshooting options
  5. Close the ADF cover.
May 26, 2009 | HP Scanjet 8350 Flatbed Scanner
DOCUMENT FEEDER IS JAMMING
Try and clean the rubber rollers with Isopropyl alcohol. Do not use any solvents.
S. Mohan, Chennai, India
Dec 30, 2008 | HP Scanjet 5590 Flatbed Scanner
E9 code
E9 code means there is a paper jam.
Clearing Paper Jams
Document Feeder, a warning dialog box opens after a few
moments.
1. Press the ADF cover release on the top-left of the scanner
body to open the Automatic Document Feeder cover.
To reduce the number of paper jams, smooth and straighten the
paper before scanning and adjust the guides to the paper size.
This should help. Please let me know if it does. Thank you, Binary Bob
Dec 04, 2008 | Xerox DocuMate 252 Path-Through Scanner
HP LaserJet 2840 Scanner problem
Have you looked to see if there is any paper at all in the trays. That are getting hung up.?? I can help
Feb 10, 2008 | HP LaserJet 2840 Printer
Scanning does not stops
please check all sensor arms in the document feeder. The sensor arm in the middle just below the separation pad is called 'paper end sensor'. If this sensor arm is blocked or broken the scanner don't stop the feeder.
Another possibility is a driver error.
Jan 08, 2008 | Fujitsu M4097D IPC Path-Through Flatbed...
Scanner not working
I work at a brother authorized repair center, the bad thing is that there is no specified A6 error, in any manual and when you call brother and tell them that you are calling from an Authorized repair center and that you need help with an A6 they*gasp* tell you to call an authorized repair center. Sorry about the rant.
The A6 is a general error relating to the scandeck on most MFC machines(9700/8440/8640) etc...
try changing the main PCB, it can be a little costly, however it generally doesn't take long, that is the general cause of the error. However, sometimes that doesn't work, so to save yourself a little time and money, just go buy another printer.
Sep 25, 2007 | Brother MFC-8640D Printer
Document feeder will not Operate
Try cleaning the rubber rollers onder the cover where the documents feed in, using a rag and some rubbing alcohol.
Jun 18, 2007 | Ricoh IS 330DC Flatbed Scanner
Brother MFC-8220 Fax Logo
679 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
