Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side refrigerator freezes food in the refrigerator. Set the refrigerator temperature control to 2 which means almost off and food is still freezing.
    Sergeant:
    Champion:
  • 263 Answers
Your fridge 100% works off the freezer. You need a new air damper, that lets cold air in from the freezer. It's a common problem.
GE refrigerator repair in orange county, ca
appliance repair orange county, ca
Posted on Feb 06, 2010
No cold air gos in to frig side
Posted on Feb 07, 2010
Ge gss25wgmd fresh food freezing
You will need to perform a refrigerator self diagnostic test found in the service manual found here=> GSS25WGMD Service Manual
Then go to page 48 of the service manual (Damper Door Not Opening or Not Closing) GE ARTICA PROFILE TECHNICAL INFORMATION This test will help you determine if the problem is the damper, temperature sensor or the control board. Doing these test are not for everyone and may require that you have someone that can perform diagnostics. If you have questions please let me know, Thanks Sea Breeze
Nov 29, 2012 | GE GSH22JFR Side by Side Refrigerator
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
GE ZIS420NX Refrigerator temp control not effective, food is freezing
you have a few things that could be wrong, a bad thermistor, a bad air defuser, or a bad main board. changing the thermistor could fix it but if not, i would call a pro that order the right part. lots of varibles.
Apr 08, 2012 | General Electric GE ZIS420NX (25.4 cu....
I have a GE(PSS26MSTSS) Profile refrigerator. The temperature in the all the bins is much cooler than the set temperature. The food is freezing in those drawers. Is the damper that controls the air from...
thats because when you open the door ALL the cold air rushes out.(the bins stop this effect)use a thermometer in the middle bin and adjust the running temp accordingly,this will also stop your lettuce from freezing.
Nov 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge fridge GSS25LFGww, fridge part freezing food
Hi, Change the controls back to normal settings. Make sure the freezer is getting 0 to 5 above. If the freezer is getting cold enough, try and turn the cold control to 1 and see if the refrigerator shuts off. It sounds like the cold control in not working properly and will need to be replaced. NOTE: The freezer temp has to be right temp or the fresh food side will not work proper.
I hope this helps. Please let me know if I can assist you further.
Vic
May 30, 2009 | GE GSS25JFM Side by Side Refrigerator
GE Profile Side by Side is getting too cold on the fridge side.
I have a GE refrigerator with the same problem of my food freezing in the refrigerator. I spoke to an appliance part person and they sold me a temperature sensor for 20 bucks. They said it would be located in the control panel, but I took the control panel off and can't find the sensor. I'm now looking on yahoo answers to find out where the sensor is located.
Mar 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE PSS26MGPWW
Yes the refrigerator knob is just a damper between the freezer and the refrigerator. All the heat removal is done in the freezer section. it just dumps air through to the refrigerator. So drop the thermostat down to about 5 and try that. If food is still freezing
drop the thermostat a little more. If food continues to freeze then your thermostat could be bad. Not sensing temp properly and allowing the refrigeration system to run to long.
Hope this helps
May 23, 2008 | GE PSS26MGPWW Side by Side Refrigerator
Water freezing at bottom of refrigerator/Temperature not right
thats a water tank holding water dfor the dispensor, if everything in refrig is freezing quite possible that the water in tank froze as well, which would explain no water,
Feb 24, 2008 | GE PSS26NSWSS Profile 25.5 Cu. Ft....
GE (PSS26MSRSS) Side by Side Refrigerator Logo
661 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
