Sony 36'' No raster or sound, stand by light blinks twice.
  • 8 more comments
  • VicML Feb 06, 2010
    The model number is KV-36fs100.
    yes I have the tools to unsolder or sorder parts in the circuit board and a Multi meter for any diod, transistor or voltage testing.
    I am sorry, I sould have told you that i have replaced the horizontal out put transistor, it was hard to test since it has a damper diod, so I replaced it with a new one but it did nothing, the proble is till the same.
    I have also checked the both rectifier diods in the power board, both seems ok. have also check for cold soder joints, low ohms resistace and the all seem good. that's how far I've gone.
    Thanks for the help you can provide for this problem.
    VML
    is that IC 702 the RGP amp?
    Ok, I will proceed as you instructed, I will take that chip out (IC 702, RGB amp).
    But would you clarified this for me again, did you say that If this chip is bad the TV will come on or will it go to stand by and the LED will bink five times?
    thanks again welcomjee
    Ok welcomejee, no good news.
    I took the chip out and it the symtom is the same, stanby LED blinks twice and that all is doing.
    where do we go from here?
    As in my previous reply, when the chip is out stand by LED blicks twice as before, the tv doesn't come on, not even for a for a second.
    Welcomjee, unly if I had the schematic!!
    I don't have the schematic, but I did a hot voltage check on the B line and I am not getting any voltage in it, the whole Fly back is not getting any voltage (not 15 or - 15 v, nothing).
    Since I don't have the schematic I can't go far to see where I loose the voltage, so I am suspecting that my problem is some where in the power supply, what is your expect opinion on that?
    Again thanks
    -V
  • VicML Feb 07, 2010
    I thought that's why I joined you guys, because not only you have the schematic but also the knowledge.
    Should I try another guy and see if some one else might had similar problem and somewhat knows what component in the powe suply might be causing my problem? either way I do apreciate your help this far.
    Thanks, Welcomjee, I actually wasn't expecting for you to provide me with the schematic but for you to walk me thru some parts of the power supply just as you did with RGB board.
    Thanks
    -v
  • VicML Feb 16, 2010
    Welcomjee, I found the problem and fixed the TV. The problem was not in the power supply, but in the main board, a sorted high voltage swttching diod. Keep that in mind for some body else who might have similar problem.
    Thanks for all your subggestions.
    -Vic
  • 10,594 Answers
I need model number of your Sony 36" to provide you info about problem and its possible solution.
Can you test and replace parts in circuit board with proper tools?
Thanks.
Posted on Feb 06, 2010
  • 11 more comments
  • Shahid Electronics
    Shahid Electronics Feb 06, 2010
    Good,
    2 times standby red light blinking means problem in deflection circuit and most probably horizontal out transistor is shorted.
    Please check it and let me know.
    Thanks.
    OK, 2 times blink is over current protection that means +B volt line is got shorted some where, please check RGB drive chip mounted on CRT neck board, simple test is to take chip out from circuit board and turn on tv, if tv turns on that means chip is bad.
    Without that chip, tv will go to standby and led will blink 5 times (if I remember correctly)
    That is IK error because chip is out.
    Yes, located on RGB board on CRT base.
    It is test to clear +b line, if RGB amp chip got shorted it also prevents TV to turn ON
    Regarding 5 times blink, it is an error code of IK (incorrect white balance) as TV wont show any picture because RGB amp chip is out so no cathode drive pulses will return to main board and that will be sensed by protection circuit thus tv shuts down with 5 times blinking led.
    I missed one point here,
    TV will turn on for moment, green light will blink as tv is getting ready in normal, then will shut down and 5 times blinking led code will start.
    Unplug tv, take ohms reading between collector and emitter pins, if you get very less ohms like 1 or 2 ohms that means some part (other then H-out) is short on +b line, might be any diode, electrolytic capacitor, flyback transformer etc
    You need to follow +b line in schematics of tv
    I got it, RGB chip is not causing any problem. Put it back please and follow +b line to find out any bad part.
    Shahid Electronics Feb 07, 2010
    Again thanks
    Thats true, problem seems now in power supply section as nothing is available in deflection section.
    You can download service manual of KV-36FS100 from HERE for small fee, schematics are necessary to repair tv on component level.
    You need to have schematics of tv, I gave you idea where to look in tv, I do have schematics but can not supply you.
    Thanks.
    Thanks
    -v
    OK, let me make list of suspected parts of this tv.
    Get back to you shortly.
    Check R592 0.33 ohms 2Watt on A Board (could be open or devalued)
    Check Q003 (2SD601A) on A Board, its part of protection circuit, open its collector and check does tv turn on?
    Shahid Electronics Feb 16, 2010
    Good to know that tv is fixed. Great job.
    What is circuit code of that diode? I mean Dxxx
    Thanks for sharing info.
My sony trinitron television will not turn on. it will click and the stand by light blinks, but there is no picture. can I fix this?
It sounds that there is a direct short circuit in anywhere in circuit board. Most probably, it might be to vertical sweep output section, in Sony TVs. Here you noted that the standby light blinks. Blinking of standby light to Sony TVs are fault indications. Count it, and check this.
Dec 31, 2012 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony trnitron tv won't turn on. stand by light blinks. Any ideas?
watch the blinking light---if a specific sequence like 7 blinks a pause and repeated endlessly that is a error code. It will not point to a specific part but will indicate where the issue might be.
Dec 19, 2012 | Sony FD Trinitron WEGA KV-36FS120 36" TV
6 light flashing power problem
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
Apr 30, 2012 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony 40xbr800 wont turn on, sounds like it wants to fire up but the stand by light comes on and blinks about 6 times
Six blinks points to No Horizontal or raster. The uProcessor detects a problem and enters the self test function shutting down the main power supply.
Feb 17, 2011 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Sony wega KV-36FS13 standby light blinking 5 times. no pic.
non of the blinks are good but here is yours
\5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
also not a DIY
Please rate my help++++Thankis for using FIXYA
May 19, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
I have a Sony ' Wega " about 6 years old 36 HD.. I turned it on and the stand by light blinks NO PICTURE.. OR SOUND AT FIRST IT MADE SOUND AND I THOUGHT PICTURE WAS GOING TO GO ON IT SHUT OFF...CAN YOU...
Please intimate exact model of Sony TV and how many times LED blinks as there would be 3 second pause between blinks so count blinks and let me know. This LED blink is an error code that will tell me problem section in TV.
Thanks.
Sep 07, 2009 | Sony Televison & Video
Stand by light blinks 6 times, wont power on
Here you find sony blinking codes
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
Aug 10, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
KV-36FS10 - No picture or sound Stand By Light blinks
5 Blinks usually means the horozontal circuit has problems and parts need to be replaced. unplug power to reset
Jun 15, 2008 | Sony KV-36FS100 36" TV
Black screen
The blinking light is an error code. you need to count how many times it blinks, and check a service manual to see what the problem is, or ask a service person.
Feb 21, 2008 | Sony FD Trinitron KD-36XS955 36" TV
SONY 36 XBR SOUND BUT NO PICTURE
posible solution is adjust the screen to low.also check the trimer if it is working.check the resistor in the heater line...weng
Oct 30, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
