Question about Nokia N76 Cellular Phone
Web icon not opening
My N76 cell has devoloped a problem from few days . the web application is not opening when cliicked on the key pad but the same functions smoothly on the pc. kindly suggest the remedy and help.
thanx , waiting for the reply
  • kagy Aug 19, 2008
    yes my friend , i had tried it some weeks before and it worked. thanx for the suggestion and help ................gud bye
  • ayneekeek Dec 23, 2008
    The web icon not opening when I click it. and even I have done master reset, this problem still occurs.
    Brigadier General:
  • 7,752 Answers
Try doing a master reset of the phone or a reflash of the firmware on the phone.
Posted on Aug 19, 2008
My phone says it has the max amount of windiws open, so I it wont let me see nothing. How do I close windows?
long press the center button or menu key,all task/icons comes out,open each application and properly exit the program.
Good day...
Jul 09, 2011 | Samsung Galaxy S GTI9000 Smartphone
My n76 is hung and shutdown
Hi there! If your N76 hungged and shutdown automatically, it could either be that many application is opened and the phone wasn't able to handle it. Try to remove the battery and put it back in again then turn on your phone. Usually, by doing that your phone should have no problem opening. If it doesn't worked, remove the casing and then manually press the switch to on. Make sure that the battery is charged. If again it doesn't work, bring now your phone to the nearest Nokia center for them to diagnose what went wrong with your product. Hope I had helped you on your problem!
Mar 25, 2011 | Nokia N76 Cellular Phone
My battery dies half way through the day without even using it, is there something running on the phone draining the battery?
Hi
BBM ( blackberry messenger) could be a drain, especially with that many contacts pinging you all day long. Is your brightness on high? That is another big power drag. What apps are you running?
What themes have you installed? You can try reinstalling the OS. Check what applications are running on your device in the background, press the Menu key then choose Switch Applications. You will see the icons of each application there.
There are commonly four or five applications that will always be running (Messages, Call Logs/Phone, BlackBerry Messenger, Home screen, and the Browser; there are other third party applications such as Bee Jive, and BlackBerry Alerts which will also run in the background which you cannot close if you want them to operate). Make certain that the browser is NOT on an active webpage (open the browser and choose Menu > Close). Close any other applications that do not need to be running (the camera or a game you were playing or Google Maps).Also make certain BlackBerry Maps is not running in the background.
Do a simple reboot: With the BlackBerry device powered ON, remove the battery a few seconds and then reinsert the battery to reboot.
Now, watch your battery use the next few days again and see how it goes. Make sure you close or exit ALL applications properly: If you just hit the red "end call" key to go back to the home screen the application actually stays open and running in the background. If you do this repeatedly you will have lots of apps open and consequently your memory will get used up. Lack of memory is the biggest reason your BlackBerry slows to a crawl or locks up. If you get into the habit of actually using the menu key to close the applications this will at least slow down this battery drain and memory-clogging process.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Mar 19, 2011 | RIM BlackBerry? Tour 9630 Smartphone
Change language'
Press the center button... that is the menu button.. the highlighted one would be the gallery.. Gallery is the one that looks like a reel with a music note... from there press the left direction key once... this should be settings... this icon looks like a spanner.. press center key to select this...now from this new menu scroll down n select the one that looks like a phone with a spanner... use the down key to scroll.... on the 'Phone with the spanner' icon perss the center key.. The first option is always Language menu so press the center key on the first option... if all was correct you will get another menu in which again press the center key at the first option... Now if luck supports you, you will see a list of languages from which select ENGLISH {It will be in English :-)}...n voila
Lemme know how it works out mate
Feb 12, 2009 | Nokia N76 Cellular Phone
Change language
How to install themes w/ nokia N76
you should take the phone and have the firmware reflash or updated on the phone.
Aug 08, 2008 | Nokia N76 Cellular Phone
Keypad problems
it's all about between key pad papper scrape i hope you will understand
Dec 17, 2007 | Nokia 6600
Nokia N76 Cellular Phone Logo
Top Nokia Cell Phones Experts
270rexton
270rexton
