When turning tv on the sound comes on but there is no picture. We have reset it and still the same thing. The lamp indicator light is not on, and we just replaced the lamp 8 months ago. Any suggestions?? It is also shutting off within a minute of turning it on.
ctf1800
  • 4402 Answers
SOURCE: mitsubishi dlp does not get picture
the plug the connects underneath is not connecting right you have to get at the plug and seat it correctly
Posted on Dec 08, 2007
milmar
  • 50 Answers
SOURCE: Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Posted on Aug 11, 2008
fixityrsel is wrong.
1 The "Airflow message"is just a bad connection and very easily solved.Mitsubishi has a service bulletin out and will cover the repair for free. Your set may not even have the defective connectors.
Your set was manufactured in 2004..Call any authorized Mitsubishi
servicer.
Capacitors are very easy to find! Any (105 degree) PC mount 3300uf@ 16VDC will work fine..and not bulge again..Higher Working voltage than the stock 10 VDC is what caused the problem with the caps.
Mouser electronic is one of hundreds of suppliers for those caps
Order online if you know for sure they are bad in your set.
Dan
Posted on Aug 14, 2008
SOURCE: HELP
I had the same issue. Replaced the lamp and now mine is working. Normally this is a sign that the bulb is out, however - I would say now that either:
1. Your lamp is defective.  2. The balast in your TV is defective.
I would check out Discount-Merchant.com - they can help.
Posted on Sep 15, 2008
directcurent
  • 59 Answers
SOURCE: Rear Projection TV shuts down after a few minutes.
My science teacher had the same problem.
After, he replaced the lamp it stoped over heating.
witch is most likelywhy the tv is over heating
Posted on Jan 21, 2009
My Misubishi WD-52631 DLP TV is off sudenly. I turn it on again, but no picture, no sound, nothing happened. I reset it, nothing happends. the green power light blinks for a while, then shut off itself....
Tv LED "LAMP" light indication is blinking?And ur tv projection lamp inside ur tv been used like 1 1/2 or 2 years.Yes.The tv projection lamp require changing,tv projection lamp life are ended.
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
Same Thing Here
if your within 1yr, you can get a lamp replacement from mitsuparts.com or calling mitsu... make sure that you can get a redlight under the lamp and you already reset the TV.
Sep 12, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Panasonic PT50LC14 No Sound or Picture
unplug it, and let it set for a minute or 2, then try it again...if it does it again hit the power button again to turn it back on...also once the the tv turns on make sure you reset the counter for the bulb..that will also cause problems...to reset the counter press the (-) volume on the tv while holding down the (-) press spilt,pip on the reomte...the lamp will reset and the indicator will go out
Jan 20, 2009 | Panasonic PT-50LC14 50" Rear Projection...
I turn on the tv but I get no picture (black screen). A sound starts when I turn on the tv. The sound ( like a humming noise) fan perhaps which goes up and down for about a minute then the tv shuts off and...
Sounds like a problem with the color wheel. Unfortunately the color wheel is located inside the light engine. According to everything I have read, the only thing you can do is replace the light engine. You are better off replacing the TV. The light engines can run form $750 to $1400. Which is ridiculous!
Jan 02, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Aug 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blinking green reset light
Can you please supply us with the make and model as well as the blink count of the green light. That count should be indicating the problem circuit. Once that info is posted, we should be able to give you more details and possible solutions.
Dan
Jun 19, 2008 | Televison & Video
Mitsubishi 57" HDTV - has sound and timer light flashes
I had the same problem and my local repair guy soldered a defective sensor so that it goes around that problem. I also had to buy a new bulb. Now my picture is "cloudy" and the repairman has no idea why. I am waiting for them to call back on it.
Mar 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mits 62525
take the lamp back out and reset the lamp
Dec 27, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
