Question about Milwaukee 6520 21 12 Amp Orbital Sawzall Recip Saw
I have a sawzall 6527-27..it runs ok til i try to saw then the blade stops is there a safty clutch or a overload or ....
  • 2,176 Answers
There is a gear protection type of system in this tool, to check I would first remove the shoe, gearcase insulator and then you will see a black cap at the bottom, check to see if the hex nut is loose. If it is I would try and tighten first, if not remove the gearcase 4 T20 torx screws usually, after removal hold the gear in a vise with a piece of rubber or similar protection on the gear and remove the hex nut to get to the gearing. You can download a schematic for this tool at Milwaukeetool.com. Let me know if you need more assistance. Check the hex nut first it could have loosened up not forcing the clutch to work properly.
Posted on Feb 07, 2010
Does 6509-31 sawzall have thermal overloads
No the 6509 does not have a thermal overload.
Start by checking the brushes & brush springs then test the switch & cord
It is possible you burnt the armature out but brushes, switch, or cord is more likely.
Mar 07, 2015 | MILWAUKEE ELECTRIC TOOL CORP Milwaukee...
Broken blade in dewalt sawzall
Remove broken blade, install new one. These blades don't change themselves, unfortunately.
May 06, 2012 | Dewalt Dw938 18v Reciprocating Saw Sawzall...
Roybi sawzall blade wont go in
be sure it is rite type of blade some are pop in and some have a set screw there are several different blades for these couple different types of tools hope this helps
Mar 02, 2012 | Ryobi 18 V Cordless Reciprocating Saw
Milwaulkee sawzall quick release wont release.Cam turns ok but pin is holding blade.Tried prying blade out w/vise grips-no luck
try using WD-40 first to loosen up pin and if not you might have to replace the quick lock assembly. ot a tough job about 10 minutes or less.
Jan 17, 2011 | Milwaukee Tool 10 Amp Sawzall Plus with...
I have a delta 36-600 table saw that the clutch or drive has quit working . the motor was rebuilt about a year ago now the drive slips is there a simple or easy fix or adjustment to the clutch for this...
If you have a motor with the no.1313314 and the motor runs ,but the blade spindel does not turn try removing the backcover plate . With this removed you might find that the toothed gear belt has broken. If this ,in fact, is the problem the belt is a Bando syncro,link 100xl.
Hope this rectifies your problem as I am waiting for a new belt myself.
E
Oct 10, 2010 | Delta 10"Hybrid Tablesaw with 30"Unifence
Motor on my sawzall 6572 runs but blade does not move. Blade locked in tight. No reciprocating motion.
The gears are stripped internally in the saw...it will need to be repaired..
heatman101
Jul 27, 2010 | Milwaukee Tool Milwaukee 10 Amp...
Blade stuck in keyless chuck on sawzall. pin or spring must be broken. Any suggestions on how to get the blade out
Getting a broken blade our of the sawzall chuck can be difficult and require some ingenuity and patience...
Sometimes there be enough blade left so that you can grab it with a needle nose pliers... othertimes it is flush and that makes it more difficult... holding the chuck in the release position and rapping the saw against a table or with a hammer can jiggle the piece out....of course you have the chuck pointed down while you do that...
Also moving the piece around a bit with a stiff wire and also soaking the chuck and blade with WD-40 helps also....
Usually it will take a combination of these things and some persistance to get the job done...
heatman101
Jul 14, 2010 | Milwaukee 6520 21 12 Amp Orbital Sawzall...
Blade moves normal until you try to cut something then it just stops but motor still runs.
Your drive has become detached or loose, you need to disassemble and find out whats broken and replace.
Apr 15, 2010 | Milwaukee Tool 10 Amp Sawzall Plus with...
I have a Milwaukee sawzall 6509-22 with a quick loc cam. Blade went in fine, but now the saw wont release the blade to come out. How do I fix this problem. Note: locking cam is turning fine
K you used the saw after inserting blade?? If so couple ideas, hold collar open and put saw blade in a vise and try pulling back on saw, or you can remove the quik lok cam and release it that way, its not that hard, but I would try vise first. Let me know
Jul 29, 2009 | Milwaukee Tool 10 Amp Sawzall Plus with...
Milwaukee 6520 21 12 Amp Orbital Sawzall Recip Saw Logo
323 people viewed this question
Top Milwaukee Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Jim London
Jim London
Are you a Milwaukee Saw Expert? Answer questions, earn points and help others
