Question about Motorola Mobility H375 Bluetooth Headset
Cant use as a headset for a computer no drivers i could find....
Cant get computer to recognize wireless headset
Wireless ? i supposed that is Bluetooth.
First solution.
Go to : Control Panel\All Control Panel Items\System
Than Device manager under Bluetooth drivers right click and update driver software.
Second solution.
Than Device manager under Bluetooth uninstall all drivers you see and thick box Delete the driver software for this device. Restart and try headset.
Oct 14, 2015 | Lenovo Wireless Headset W770 - headset
I have problem in plantronics dsp 400..regarding mike..i cab hear the incoming calls but i cant hav any conversation in mike..the end user cannot hear..so kindly rectify this problem..as it would be of...
<span style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: navy; FONT-SIZE: 10pt; mso-fareast-font-family: Calibri; mso-fareast-theme-font: minor-latin; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">The first thing you need to check is your audio settings and make sure that both sound recording and playback are set to the same device. If you
Aug 19, 2010 | Plantronics DSP-400 Headset
Can hear thru head set but cant speak thru mic why?
Hi there, you have to be sure that your mic is connected well and (the right place in the computer) there must be several wholes there, be sure you have choise the right one for the mic and the driver to the sound card is the right one, you can find the driver in the Start- Control Panel -Administration
Hope that solve your mic problem, please check your mic on another computer for see if it is well there.
You are welcome to return here
Have a nice time over there
Please rate my answer
Jul 30, 2010 | Logitech 250 Headset
Cyber Acoustics AC-201 Micrphone Problem
i have cyber acoustics headset and i cant hear anything but my Mic works, my sound is all fine, when i plug my headset out i can hear but when its plugged in, i cant hear anything.
Mar 09, 2010 | Cyber Acoustics AC-201 Consumer Headset
How do i connect the mad catz 8860 bluetooth head to a computer.
For all Bluetooth headsets for computers you need the drivers most Bluetooth headsets don't install them for you, here is a website with the drivers and instructions. Just follow them and your headset will work. :) Hope that helps everyone!
http://blog.komeil.com/2009/05/installing-bluetooth-headset-in-windows.html
Jan 03, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
I try to connect my Sony Ericsson HBH-DS205
Hullo Tillgustaf
I understand you need an A2PD compliant bluetooth adaptor. I’ve just installed one on my PC at work, asked Windows to look for updated drivers on the internet and it has installed correctly.
You can get an A2PD adaptor from Amazon for £1.50 here
Best wishes,
Phil
Dec 29, 2009 | Sony Ericsson HBH-DS205 Bluetooth Earset -...
Cant play music
What software are you using to pair the headphones?  Are you using the software from the CD that came with the headset?  Or are you using Windows built-in software?
If you are using Windows' software, then you need to download the correct driver from the link below.  Although the Windows software will pair with any bluetooth device, it does not support audio.
http://drivers.anycom.com/bluetooth/usb-200-250/anycom-bluetooth-usb200-250-windows-v5-1-0-4200.exe
If you are using the CD that came with the headset, try uninstalling then re-installing.
Feb 06, 2009 | Insignia Bluetooth Wireless Headphones...
I cant use my USB conector in PC
you just need to find a free driver to download for the computer to be able to read the device. After the driver is downloaded and installed, it should read automatically. At least that's how it works with windows vista. IF you have XP, you might need to run the wizard after the driver is installed
Feb 04, 2009 | Sony Ericsson HBV-100 Bluetooth VoIP Kit...
Blue tooth adapter and hs850 headset on my computer
Yes, you need the blue tooth driver. The one that comes with your blue tooth "toggle". Although my laptop said "blue tooth compatible" I still needed a toggle. They are fairly cheap to buy and go into a USB port.
Sep 17, 2007 | Motorola Mobility HS850 Consumer Headset
Cant talk at all
maybe you should try unmuting it lol or v+++
Dec 21, 2006 | Cyber Acoustics AC-201 Consumer Headset
Motorola Mobility H375 Bluetooth Headset Logo
390 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
