Question about RCA Televison & Video
I just got the new time warner hd cable box..the rca scenium 61 inch does not have a hdmi input so i ran the hdmi cable to a dvi converter and plug into the dvi output on tv ...i get a message...un usable signal....what am i doing wrong ?
  • 176 Answers
What manufacturer (scientific atlanta, motorola, etc.)and model of hd box?
Posted on Feb 06, 2010
I have a Rca scenium tv ...trying to connect to my hd reciver and can not get a picture ...tried hdmi cord ..adapter ..dvi cord ..and nothing at all
Easy to understand, hooking up RCA, HDMI, and othe ...
? 5:54
https://www.youtube.com/watch?v=m4jgK7Ws_6U
Jul 10, 2012 - Uploaded by kevintalkstech
A very easy to understand tutorial about what RCA, HDMI, coaxial and ... +kevintalkstech I am trying to learn ...
How To Connect: Tv + Component With Dvi Or Hdmi - Rca ...
www.manualslib.com > ... > User manual
RCA SCENIUM HDTV With DLP Technology High-Definition Television ... To connectyour TV to a component with a DVI jack, use an HDMI cable and an ... Note: You canset up the TV to automatically tune to the correct Video Input Channel. .... call me at 318-578-5198 I need help as soon as possible trying to get my tv to ...
Support - RCA Television
Dec 27, 2015 | RCA Televison & Video
My rca tv will not work
try another input like video one or DVD or whatever you have plugged in it directly through HDMI or component, if it works it one of two things, your tuner inside the TV is damaged, or the signal from your cable is not there, bad wire or lost service.
Tony
Nov 25, 2014 | RCA Scenium HDLP61W151 61 in. HD-Ready...
It seems has if the HDMI port on my Scenium is going bad. For quite a while, it would occasionally turn people's skin blue. Pulling out the HDMI cable and reinserting it would usually correct the...
hi,
Your TV didn't have any HDMI port. Do you mean the DVI port. do you use DVI cable or DVI to HDMI cable.
The only way to check whether the DVI port is working or not is by replacing the cable. purchase a new cable and try again.
ok
Jan 31, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
I have a 2002 Mitsubishi Medallion TV. The only input for HD is DTV (no DVI or HDMI inputs). Is there a converter box from HDMI to DTV that will allow for 1080i resolution?
From looking at the back panel of the TV, the DTV input can be configured as a component video. The M-Link/DVI-HD port is also a DVI with HDCP port and maximum signal handled is 1080i. The M-Link should work with an HDMI to DVI cable or adapter. For this to work, the source must not be a computer or another device using the default computer video output (computers give RGB output). The DTV port would need an HDMI to Component video converter. See this page for some examples: http://www.hdtvsupply.com/hdtocoad.html . The first one in the list (for Netflix and Boxee among others) will give 1080i out if the source is set correctly.
Most DVI-HDMI cables are single link. I've seen some examples where DVI-I (single link) and DVI-D (dual link) cables are not interchangeable. If you have video problems, check your cable. An HDMI to DVI adapters will let you run an HDMI cable up to the TV and then converter at the TV as a separate connection.
I hope this helps.
Nov 17, 2010 | Mitsubishi WS-65613 65" Rear Projection...
Hdmi cable connection
Your model has a DVI input which is at the top of component 1 section on the rear panel which is for HD input or you can use the RCA plug ins for HD inputs on the component 1 section as well. Either will allo HD to be hooked to your set.
Jan 04, 2010 | Hitachi 51S700 51" Rear Projection...
Connecting to HD TV
This TV has no HDMI input socket. It Has a DVI input socket. Therefore you will require an HDMI to DVI converter adapter or an HDMI to DVI cable. The DVI is video only so you will require audio cables from your Sky box (Audio L and R ) which will connect to the back left of your TV (Audio L/R sockets next to the s-video and component video connectors)
Nov 02, 2009 | LG RZ32LZ55 32 in. HD-Ready LCD Television
I have a computer with HDMI output and my Scenium has HDMI input but I get no picture when I play movies on my HP 9700 computer that I would like to have displayed on my RCA Scenium. All connections seem...
(No longer listed on Amazon.) The most likely reason for no display is not matching the scan rates. Your TV is either 1080i (1920x1080x30) HxVxrate or 720p (1280x720x60) high definition. That's its native display but it may accept both but not 1080p. The computer must be set to one of those. The TV will not accommodate, well it may accept 480i or 480p (720x480x30 or 60) for standard definition and that could be 640x480. Go to your computer display controls and see which resolutions are available and it may be different in mirrored versus extended mode. If the signal comes from a TV DVI source and is converted to HDMI, it will not include sound. There may also be a problem with copy protection (HDCP) as your computer may be fussier than the TV. -Ken
Jul 30, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
My 61 inch RCA Scenium, currently has sound but no picture appear
My exact same problem turned out to be the cable box not the TV. Try unplugging cable box for 5 minutes then power up! Solved my problem!
Apr 01, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Connection problem with HDMI cables on Denon AVR-589
I want to clairify you install, you sat you have I an HDMI cable running from the Time Warner Cable box to the AVR-589, going in to the TV/CBL input. From the Denon AVR-589, I have an HDMI cable running from the output to my Toshiba RV525U television.
Check the connection at the TV, if as you indicated above you have an HDMI cable from the HDMI out from the Denon to an HDMI output on the TV, if this is the case you need to have that HDMI cable plugged into an input on the TV not an output
Feb 27, 2009 | Denon AVR588 Receiver
Ps3 hook up
Yes, you can! But not straight out of the box. You need to purchase a DVI to HDMI cable adapter. It will convert it so your tv can use it. Here is a link to some:
http://www.connectworld.net/syscon/dvi-to-hdmi-adapters.html
Hope this helps! Please rate me!
Jan 20, 2008 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
