Question about Liquid Video Computers & Internet
Cycles on and off
The monitor cycles on and off uncontrollably.
    Scholar:
  • 62 Answers
Check the power cables and make sure about power fluctuation issues on your eletric system. the power cable may be loose of cut from inside-out. if it's a malcontact issue, try to use something to keep the power cable in place. duct-tape may help. that's the solution i can give you by your description. try to solve this as fast as you can, since this power-on and power-off cycles reduce considerably the monitor's lifespan.
Posted on Feb 06, 2010
Why is menu scrolling uncontrollably when turning on?
Vizio L32 32 in. LCD HDTV Scroll stuck - Questions - Fixya
www.fixya.com > ... > Vizio > Vizio L32 32 in. LCD HDTV
Question about Gateway Flat Panel Televisions. 2 Answers · Menu stuck on andscrolling. menu stuck on and scrolling The TV remote control will not operate the TV, and now the ... Menu Scrolls Uncontrollably ... To turn off the TV, I have to .
Vizio LCD 37 Inch Turns Off Randomly - Fixya
www.fixya.com/support/t354860-vizio_lcd_37_inch_turns_off_randomly
Flat Panel Televisions question. ... I have a 2006 Vizio 37 inch LCD that has started to turn itself off randomly. ..... Why is menu scrolling uncontrollably when turning on? will stop randomly on one input, but will scroll uncontrollably when any ...
Vizio E470VL 47 in. HD-Ready LCD TV Scrolling menu ...
www.fixya.com > ... > Vizio > Vizio E470VL 47 in. HD-Ready LCD TV
Question about Gateway Flat Panel Televisions ... menu stuck on and scrolling TheTV remote control will not operate the TV, and now the menu is stuck ... How to activate the menu choices? try turning tv off and ... Menu Scrolls Uncontrollably.
Dec 25, 2015 | Vizio Televison & Video
At power up, tv scrolls uncontrolably through channels, power light flickers
1. Take remote control far away from tv - 3rd or fourth room. Then switch on tv. If uncontrollable scrolling stops , then cause may be remote button (Ch+ or Ch-) has got dirt inside and its shorting.
2. If taking remote far away doesn't stop scrolling then (Ch+ or Ch-) button on front pannel has shorted. Take a cutter plier and care fully remove button from its circuit board. ( If you know desoldering, it is far better than cutting). If scrolling stops then you can operate channel change with remote.
Jan 27, 2014 | Samsung LN46C600F3FXZA 46in Lcd Tv 1080p...
Stephen king
It barked, seemingly uncontrollably for three hours after midnight.
It my anger I threw my computer monitor at it. The problem with computer monitors used as weapons is that their targets see them coming.
Nov 12, 2013 | Computers & Internet
The washer shakes uncontrollably during the spin cycle also a loud banging noise is heard during the spin cycle.....
If front load check the inner drum If it is loose at all you have a lot of problem . Very expensive.
Nov 17, 2010 | GE Washing Machines
I pet the new machine on quick cycle it takes more then 1 1/2 hrs styed forever on spin then i had to unplug it. also shakes uncontrollably
You will need to make sure it is level. With the machine off rotate the plugs till the washing machine is level. If that doesn't work, you will need vibratins pads under the feet to stop the vibration and allow it to cycle normally.
Aug 16, 2010 | Malber P25 Front Load Washer
OSD Main Menu appears randomly and uncontrollably /flashing. Power Button does not always work. Need to keep clicking unti works.
hello..the problem is just sticky tack switch's so try to clean or re-align the frame/body of LCD..Thanks.Good Luck..^_^
May 08, 2009 | Dell E207WFP LCD Monitor
LG Front Load Washer Problem
The washer is not leveled correctly.  You will need to adjust the front feet to level the machine.  Run a load of clothes in the washer.  When it gets to the spin mode, check the level of the machine by pushing the front left corner and the front right corner.  If the noise quiets down on either corner of the machine, adjust the legs on that side.
Jul 22, 2008 | LG WM-1832C Front Load Washer
Philips 104E width uncontrollable
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Jan 16, 2008 | Computers & Internet
Blank screen (led indicator is orange)
it could be the cable from the monitor to the pc it is defactive try a new one cuz if the monitor works then it is the cable that is makeing your screen go blank
Oct 10, 2007 | IBM E74 17" CRT Monitor
Computers & Internet Logo
149 people viewed this question
Top Liquid Video Computers & Internet Experts
Rommel Balcita
Marcin
Are you a Liquid Video Computer and Internet Expert? Answer questions, earn points and help others
