Question about Mitsubishi VS-6043 60" Rear Projection Television
Moving vert white lines on my 6043 what can i do
  • 2 more comments
  • claslimo Feb 08, 2010
    i sorry it is the horizonal that has the juming white lines
    is this for the vert or horizonal c933 ps where is this part
    moving horizonal white lines not vert. sorry
    the lines are on the whole screen not just the center they are about three inches apart
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described if the lines are perfectly horizontal and in center of the screen then issue is with the vertical deflection of the unit. As there are over 100 serviceable parts in this section and it is not possible to know which one is failing until it is checked so it is only recommended a DIY Job if you have some electrical expertise and know how to solder/re-solder components & have some knowledge about the internal circuitry of the TV, if not then it is always better to have a service tech who can diagnose it. Also the Flyback should be checked. Also if the set is too old then I suspect that the CRTs are getting tired. The typical cost to get it fixed by a professional will be around $300-$500 depending on which parts have gone bad. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 08, 2010
  • Rylee Smith
    Rylee Smith Feb 08, 2010
    Still the solution remains same: issue is with the vertical deflection of the unit. As there are over 100 serviceable parts in this section and it is not possible to know which one is failing until it is checked so it is only recommended a DIY Job if you have some electrical expertise and know how to solder/re-solder components & have some knowledge about the internal circuitry of the TV, if not then it is always better to have a service tech who can diagnose it. Also the Flyback should be checked. Also if the set is too old then I suspect that the CRTs are getting tired. The typical cost to get it fixed by a professional will be around $300-$500 depending on which parts have gone bad. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
After 10 to 20 mins left half of screen goes to white vert lines
Sounds like power supply regulator board fault. Check all the electrolytic capacitors for any leaked or bulged one. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
Jul 01, 2014 | Samsung LN32D450G1D 32 LCD TV
2 wide vert line center of notebook screen,solved?
actually some of the panels of your laptop screen are damaged.only there is one way,you need to change the screen
Apr 03, 2012 | Computers & Internet
White lines on top of picture
Are you talking about hoizontal lines? Looks like vertis streched? If you are you need top check c27 100mfd 35 vdc /c28 100mfd 35 vdv and ic401 la78040. This is a vert retrace problem.
PLease leave feedback
Feb 21, 2011 | Toshiba MW20FN1 20 in. TV/VCR/DVD Combo
Monoscope signal how to get it Mitsubishi VS-6043 rear tring to adjust the picture its all warped looking got tv out of ditch tring to make it work
does the convergence align or move? how is the picture distorted? if the picture aligns but is just warped, use a jig or some string to have some straight lines to reference for your geometry and convergence. the monoscope signal is hard to find and mits had it on a vhs tape back in the day. it really just helped you get the horizontal and vertical size and get a round circle to fix the warp.. just try to make all the grid points about the same distance apart and make it an even grid.
May 26, 2010 | Mitsubishi VS-6043 60" Rear Projection...
The TV has a thin horizontal line across the screen. Sometimes the line has color and sometimes the line is white. Everything else seems to be working (i.e. sound, channel changing, game hookups)....
you have a vertical output problem,take something insulated and prod around board and see if pix starts to flutter,then you could have a "cold-solder" joint,otherwise its more than likely a capacitor between the vert driver circuit and the vert output circuitry,
Sep 12, 2009 | Televison & Video
Picture vertical output has reduced
TV has no cathode 200 volts supply.
If you have experience of CRT TV repair then let me know to guide you further or get help of near by TV tech person.
Nov 30, 2008 | Sony FD Trinitron WEGA KV-24FV300 24" TV
Tosjiba cn32g90 no picture or sound
Timm,What you have Is Vert Failure,Toshiba is Noted for Bad Conns On the Vert Ic,Pull the Back off and Gently tap with a NonConductive Inturment and watch the Sceen Look for Heatsinks and Tap on those,If you know,or you caqn solder do so ,Do run the tv for a long time with no Vert or it will Cause BURN IN in the Phophurus
Jul 15, 2007 | Toshiba CN32G90 TV
SONY KV-27FV310: UPPER HALF OF SCREEN IS BLACK
You have a vert sweep problem and unless you know how to trouble shoot this cuircit bring it to a pro. I found out mostly in these sets that the vert output IC is bad.. Also sometimes the b+ filter cap off the fly is leaky and made the IC to fail. Another thing is Im surprised to hear you got a pic with the vert failure and a bright line in the pic!! This could be a big problem when the sets fixed so dont run it too long like this. It could burn a line all the way across the screen and you will see a dark faint line in your pic because of this. BE CAREFULL!!
Mar 25, 2006 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Televison & Video Logo
44 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
