Question about Kenmore 16342 / 16344 / 16349 Built-in Dishwasher
Kenmore built in 16349
The dishwasher fills but it doesnt wash. Soap dispensers open too.
  • 185 Answers
Check your timer
Posted on Mar 26, 2008
How do you open the soap dispenser on a Kenmore Ultra Wash dishwasher?
Push the little lever sticking out of the dispenser.
Maybe you have some calcium or hardened soap that is holding the lid closed. some Lemi-Shine powder dissolved in hot water and use an old toothbrush to clean off the soap/hard-water deposits.
Jul 27, 2014 | Kenmore 24" Built-In Dishwasher with Ultra...
I have a Kenmore Quiet Guard 2 (model 16994400) and the soap door doesnt open during the washing cycle.
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
heatman101
Jan 05, 2011 | Kenmore 24 in. 15932 Built-in Dishwasher
Need instruction manual
Yes you put the dishwasher soap in the soap dispenser. Then you close the lid to it. then shut the door and start the dishwasher.
Apr 19, 2010 | Kenmore 24 in. 17602 / 17604 / 17609...
Dishwasher is leaving soap in dispenser and dishes aren't clean
Look for debris in the holes of the wash arms. Is the soap dispenser opening? If so you probably have either no water in the machine or no ciculation. Also be aware sometimes a fill valve will work for the first few fills and then not work once it is heated up a little. And the valve could be clogged causeing low or no water to enter the machine.
Aug 06, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
The soap isn't coming out of the soap dispenser during the wash cycle. when i open the dishwasher door the dispenser opens with all of its contents still sitting there!
I had the same problem once. Make sure nothing is stacked in front of the soap dispenser when you close the door. Slowly close the door and follow the soap dispenser to make sure it has enough clearance to open.
Let me know how it goes.
Regards,
Jul 19, 2009 | Electrolux Kenmore 24 in. Built-In...
Soap dispensing problems on a kenmore dishwasher elite 577-0
is your soap door open when this happens if it is then make sure there's no water or other liquids in the dispenser from loading the washer one tablespoon of water in there will clump up the soap and it won't drop when it pops open
Dec 25, 2008 | Kenmore 24 in. 15252 / 15254 / 15259...
Kenmore 16163 401 dishwasher
The dispenser flap should be spring loaded to spring open if the lock is released. If it doesn't spring open you should make sure that the spring is placed correctly on the hinge of the flap - if it doesn't spring open it won't get the detergent where it needs to go during the wash. We had the same thing.
Dec 17, 2008 | Kenmore 24 in. 16163 Built-in Dishwasher
I just bought a used Kenmore standalone dishwasher and ran it for the first time. The dishes on the top did not get clean and the soap did not come out of the closed soup dish. at one point I took a shower...
The inlet filter is probably clogged. Try letting it fill up. Open the door to stop it right after it starts to wash Pour a gallon or two of hot water in and see it it works better Stop and do this everytime it goes to fill up. If the door opens , soap is used and dishes are clean ,clean the filter in the fill valve and possibly replace it. or the whole valve. (around $25) The soap door may be a seperate problem. I don't remember if Kenmore uses a spring or a small heat element to open the soap dispenser. Try cleaning it really well, shut the dispenser, open the door and turn the timer very , very slowly and watch to see if the dispenser opens. (WIth the door open the dishwasher will not run, but leave it plugged in.) It should open sometime during the cycle.
Jun 29, 2008 | Dishwashers
Kenmore 16342 / 16344 / 16349 Built-in Dishwasher Logo
157 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
