Question about Samsung LN40A330J LCD TV
Samsung LN40A330 will not turn on. I believe this is a capacitor issue. I need to know which capacitors to use.
  • megstubel Feb 06, 2010
    Wow, Rylee, thank you so much for the thorough response!
    We opened up the television's back and noticed parts CM 852 and CM 853 are slightly bulged at the top. These are 1000uF 10V capacitors. We purchased 1000uF 35V capacitors from the electronics store and are going to attempt to solder these in, but worry they might be too large.
    Any tips on this particular fix or soldering suggestions please? I could use anything right now!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems the issue is with the power board or the main board we’ll need to check few things. When you open the unit up; take a look at the power board-the board where, the power cords/plugs goes into. You might see some filter capacitors a little bulged up in the top-If this is the case-this is your defective part(you can try to replace them-but some soldering equipment is needed). If not, then probably the main board has gone bad. This is the other board-where all he inputs are going into. Also check for the Backlight Inverter Board if the sound is coming fine from the TV however as its shutting off so it should be either the power board or the main board. All this is only recommended if you have electrical expertise and know how to solder/re-solder components.
. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 06, 2010
  • Rylee Smith
    Rylee Smith Feb 06, 2010
    Yes you are right that 1000uF 35V capacitors might be too large and should be replaced only with 1000uF 10V capacitors. Thanks for accepting the solution.
    Rylee
I have model # LN46B750U1FXZA tv and it would not turn on. The power button just flashes with no picture coming on
Bad capacitors, well know issue on certain models of Samsung TV. Cost me less than $200 to fix or you can try yourself with a kit from ebay or amazon. Search for Samsung capacitors kit.
Oct 19, 2015 | Samsung Televison & Video
Which capacitor replacement for Samsung LNT4069FX/XAA
My Laptop HP computer. New. When Ever A Click On Youtube to view A Artist and Song, It sometimes tells me an Error has Occurred and can't play the Video. Why?? I've tried every thing I know how to do. I am Older man and not well versed on all this computer Jargon. All I want to do is listen to music. Can you help me with this I believe is not A big Problem,
Mar 04, 2014 | Samsung LN-T4665F 46 in. LCD Television
Monitor wont turn on
Usually the capacitors are 1500uF/25V and 470uF/25V, but I suggest to use 35V capacitors. This will make your power supply to last forever. Also, you better open the monitor and see by yourself what kind are the capacitors. Mind the polarity or the capacitors will blow out with lot of smoke. You can buy them from local parts store like Conrad.com or online.
Apr 07, 2012 | Samsung Computers & Internet
My LCD TV Series 530 keeps on blinking and would not turn on. why does it keep doing that?
I've experienced similar issues with a 42" Samsung LCD TV. From what I've read online, I believe it could be a problem in the circuitry of the power supply. Apparently, Samsung used under rated capacitors in the power supply and the result is a turn on delay or blinking on and off. If this is the case, then the capacitors would need to be replaced to fix the issue.
Aug 07, 2011 | Samsung Televison & Video
Ok I have a Samsung SPK4215 42 in. Plasma TV, what happening is when I turn it on it won't come on, just green light come for 3 second and turn to flashing red light, then i use the Remote control, to turn...
The most common issue with these are the power supplies that were made with bad capacitors. All makes and most models are effected by this. Here is something to read on this issue.
http://www.ccl-la.com/blog/index.php/capacitors/
They can be fixed or replaced, but if you don't replace all the capacitors with a newer better type you will be repairing this again.
Apr 01, 2011 | Samsung SPK4215 42 in. Plasma Television
Can't turn on tv with remote or manually
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Mar 21, 2011 | Samsung LN19B360 19 in. TV
The TV does not turn on right away. when turned on, the screen stays blank and it clicks.
You've got bad capacitors in the power supply. This is a know issue, unacknowledged by Samsung. Get the capacitors off Ebay for five buck. View the youtube video on how to do it. I did mine and it works fine.
Dec 17, 2010 | Samsung LNT5265F 52 in. LCD HDTV
Samsung LN-T4661F - When I turn the T.V. on, it makes the clicking noise like it wants to turn on - it keeps clicking and finally comes on after about 2 minutes - it seems the time for it to come on keeps...
In this case, I believe it is the power supply board; more specifically the capacitors are failing. When you have the clicking problem and the long boot up times this has generally been the issue.
When you have video display problems such as shadows and lines that go away after warming up it is usually the LVDS cable and T CONN board going bad.
I had the shadow and line problem and replaced both the cable and board for $120 and that fixed my problem. Since I had the TV apart, I went ahead and replaced the capacitors so I wouldn't run into that later. You can find the parts numbers for the LNT4661F cable and board below. You can find links to you tube ( Part 1 & 2) to show how to replace the capacitors. Good luck.
Samsung A/S-T CON BOARD BN81-01312A
Samsung Lead Connector LVDS BN39-00883A
YouTube (Part 1) http://www.youtube.com/watch?v=Mm51C_RDIZE
YouTube (Part 2) http://www.youtube.com/watch?v=BNHHrgX_6cs
Dec 10, 2009 | Samsung LN-T4661F 46 in. LCD HDTV
Samsung LN40A330J LCD TV Logo
258 people viewed this question
Henry  Thomas
Henry Thomas
