Question about LG WM-2277HW Front Load Washer
Lg tromm wm2277hw code de
I turn on my lg tromm wm 2277 hw and it makes a clicking noise then the code on the scren blinks de.
  • 1 more comment
  • Anonymous Mar 04, 2008
    i have the same problem
  • Anonymous May 11, 2008
    Same problem here. Try to start washer and the control panel blinks saying the door is locked - then error code de. Can't reset it or fix it. Tried to the diagnostics and get the same message.
  • Anonymous Mar 24, 2014
    changed boot the door wont close. fixed latch now wont stay on. comes on makes noise then cuts right off
    New Friend:
In our case, this problem was fixed by removing the switch (see you tube videos), separating the two halves of the switch and with a small piece of emery cloth smoothing out the pits on the switch contacts. Also lubricated the shiny metal slide on the outside of the switch with graphite. Don't know if it was the poor sliding motion of this piece or the dirty contacts but the problem seems to have been resolved. Also, you don't need the special spring clamp removal pliers, just grab one end of the spring with a pair of needle nose and stretch the spring out so the hoop can be pulled out of the groove in the 'boot'.
Posted on Dec 26, 2012
I have a piece of money in my pump.... How can i remove it.
Posted on Jun 24, 2012
Error Code "de" is for "door switch assembly faulty".
You can down load the service manual from this site:
http://136.166.4.200/contents/Laundry/WM2277.htm
Have fun!
Posted on Mar 06, 2008
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
LG Tromm WM2277HW
Does spin only work well?
Apr 11, 2017 | LG WM-2277HW Front Load Washer
My LG tromm wm2277hw front loader just turned off, can it be a switch, there's power in the outlet, no lights, circuit board is off, no water underneath, dryer is ok plugged in the same outlet,
That could very well be the line voltage suppressor (called a noise filter) that is built into the washer. Take the top off and follow the power cord into the machine. It connects to this component. themobilian_17.png
PAGE 22
Feb 06, 2011 | LG WM-2277HW Front Load Washer
I have a tromm washer (model wm2277hw) that sometimes will drain and sometimes not. when it doesn't i get error message OE. all connections seem to be good. when it doesn't drain there is no noise like...
An OE error presents if the washing machine has not successfully drained the water in ten minutes. Follow this link for step by step instructions for correcting the OE error code.
The FixYa Team
Dec 27, 2010 | LG WM-2277HW Front Load Washer
LG Washer Model #wm2277hw
It is a motor error
• The connector in the LEAD WIRE ASSEMBLY is not connected to the connnector of STATOR ASSEMBLY Reconnect or repair the connector • The hall sensor is out of order/defective. Replace the STATOR ASSEMBLY
Apr 19, 2010 | LG WM-2277HW Front Load Washer
I need the user manual for my lg tromm wm2277hw because I don't know how to get it to spin without going through the whole wash cycle
for a drain and spin : turn unit on hit spin Button 1 time then start/pause button
this a drain and spin only..
Jun 15, 2009 | LG WM-2277HW Front Load Washer
TROMM LG WM-2277HW
You may have a broken door latch switch that doesn't tell the computer that the door is actually closed.  Before you actually replace the latch switch, make sure the wire connectors are securely attached to the latch assembly.
Sep 14, 2008 | LG WM-2277HW Front Load Washer
Lg 2277h won't spin
More than likely, you have a problem with the balance ball sensor in the back of the unit if it so equipped.  It is located in the back of the unit and will require an LG qualified tech to see what's going on.
Apr 24, 2008 | LG WM-2277HW Front Load Washer
Tromm Washer Model # WM2277HW by LG
will it spin after it washes if it does not then your belt might be broke
Feb 12, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
4,347 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
