Question about Kenmore Washing Machines
Washing machine coupler replaced still not spinning
My husband replaed the lid switch and now the coupler, but our Kenmore washing machine will not spin to drain. What is the problem with it?? Thank you.
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Although you've replaced the Lid Switch, I'd test it by bypassing it to verify that it is OK.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Feb 07, 2010
Kenmore washing machine model 20712990 wont spin
If you don't hear a click when you close lid, replace lid switch. If when in spin, you hear motor but does not spin, replace motor coupler.
Sep 02, 2014 | Kenmore Washing Machines
Have a 110.22642100 Kenmore washing macihne that has a metal clang on the spin cycle that occurs every second or less. The tub does not rotate much. I replaced the motor coupling since it was split but is...
Hello Jye,
It does sound like either the clutch is bad or the Motor coupler is bad. I have included a video showing how to replace the coupler Kenmore Washing Machine Model 110 22642100 11022642100 110 22642100 Parts
The coupler is about $18 and the Clutch is about $48
Good Luck!
Rich Lilja
May 19, 2017 | Kenmore 22642 Top Load Washer
My husband replaced the coupling on our kenmore
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
I'd verify that the Motor Coupler is installed correctly first.
I'd also verify that the Lid Switch was re-connected after replacing the coupler. (A common oops that I've done myself)
If it was, I'd test the Lid Switch by jumping the two outermost contacts with a short piece of insulated wire.
See the Whirlpool Service manual for their top load, direct drive washers for how to bypass the switch.
Apr 27, 2010 | Kenmore Washing Machines
Washer not draining or spinning
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Jan 01, 2010 | Kenmore 22422 Top Load Washer
Kenmore 70 Series Washing Machine Drains, But Won't Spin
Yes sir, a bad motor coupler could cause the machine not to spin. You did the right thing in checking out the lid switch and the pump first. It sounds as if the motor coupling is worn and may be slipping. I will attach a link to a video that may assist you. Hope this helps and best wishes.
http://www.youtube.com/watch?v=WLPGs2UMUJc
Aug 27, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
How do we fix a washing machine that does not spin?
Is it agitating? If so you may have a bad lid switch if it's not spinning or agitating you may have a bad drive coupler.
Mar 17, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series will not drain or spin
It sounds like the lid switch. If it ws the coupler the water would drain. Check to see if the lid switch is clicking when you put the lid down. replace the lid switch. You have a great washer. Fairly cheap fix.
Nov 20, 2008 | Kenmore 20722
Washing machine won't spin
Sounds like you a broken coupler. This is what makes the washer spin. You can check this by leaning the machine back and feeling for a rubber coupler between the motor and transmission. if this part wiggles or is missing replace it, its broke. Another sign of it being broke is rubber under the machine when you tilt it back.
Nov 19, 2008 | Kenmore 24032\24036 Top Load Washer
Agitate/Spin Issues (again)
if your coupler is good change your agitator dogs that will fix slow wash and clutch on top of transmission or lid switch for no spin
Nov 05, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer will not spin
KENMORE 80 SERIES 110.92582110 - NOT SPINNING. I REPLACED THE TRANI, CLUTCH, COUPLER BUT I FORGOT TO PUT BACK IN THE AGITATOR WASHER. IT STILL WON'T SPIN SO WHAT NEXT
Jun 12, 2008 | Kenmore 23822 Top Load Washer
Washing Machines Logo
65 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
