Question about GE Profile JGB900 Gas Kitchen Range
Front burners-GE LP range with electrodes
GE Lp range. Front (right) large burner lights, but flame is too high from 6 to 9 o'clock and hardly any flame from 9 to 6 o'clock. If I put it on low the flame goes out completely. I have checked and cleaned all parts and it didn't solve the problem.
The front( left) burner lights but only if cooled off. I have to relight with match if burner is hot.
The back burners work just fine. No problems with oven.
Master_Tech
  • 770 Answers
SOURCE: JGBP28SEM1SS LP GE Range
have you tighen it down until it wont turn anymore this needs to be done on a LP gas model going from Natual gas
Posted on May 11, 2008
SOURCE: GE Spectra JBP64BB front right large burner won't work anymore
how are you the GE Spectra JBP78 Electric... Problem: Subject: the proble is that i had a shortge of power and i have the ""lockdoor"" showing
Posted on Aug 01, 2008
jumptrout51
  • 3361 Answers
SOURCE: oven burner makes a popping or whistling sound during baking cycl
STOP>>>>STOP{>>>STOP>>>
You have a gas leak in the oven.
Get this fixed immediately.
Posted on Feb 21, 2009
jumptrout51
  • 3361 Answers
SOURCE: Sooty burning in oven after Natural-LP gas conversion
The conversion was not done correctly.
Either wrong parts or incorrect adjustments to air flow.
SolutionGuy
  • 331 Answers
SOURCE: I have a new ge range. When I turn on the left
mvek,
If you could see through the glass, you'd see "temperature sensors" located near the elements. They're very sensitive little guys, and rightly so! Their job is to detect temps and energize the warning light on the cooktop so users won't get burned.
To answer your question... It appears that there is an issue with the front left sensor (and possibly the right as well). The temp warning lamps should NEVER go off immediately. Please call for warranty repair (1-800-GE-CARES). This is an unsafe condition for you and your Family. The warning indicators are there for a reason and should indicate high temp's as long as high temp's are present.
SG
Posted on Apr 12, 2009
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
Converted HotPoint RGA720 to LP, burners and oven work fine, all pilots flames are still too high?
I have this model too and have had to replace two thermocouples because the pilot is so high it frys them. We replaced the whole modulator last time and it still goes out so I have to relight The pilot is at the lowest setting, it's a GE/Hotpoint issue that was not recalled. I do like the hot 125 degree oven for drying sun dried tomatoes and keeping plates warm.
Apr 13, 2013 | General Electric Hotpoint® RGA720PKWH Gas...
Yellow flame on front burners
remove your knob for tht burner and look inside the switch stem and there is a small flat head screw.. Turn tht with the burner on and you will see it adjust... ;)
Dec 12, 2012 | GE Cafe C2S980SEMSS Stainless Steel Dual...
GE Range - oven flames too high after regulator replacement and self clean
You need a Gas tech/plumber there urgently!!!!
If the gas jets in your oven had not been changed to accomodate LP gas then the orifice on your existing jets are still to large in diameter. In other words your using Natural Gas jets ( lower pressure jets) for Lp which has a much higher pressure than Nat. gas, this can be extremely dangerous, & could cause major problems.
Again I strongly suggest you contact a Gas tech/Plumber & do not use your oven until it has beeen checked by a professional.Good luck
Aug 18, 2012 | GE 30" Free Standing Electric Range
Flames are extremely uneven and high
okay, DO NOT USE THIS STOVE ON LP GAS.
It's not intended to be used with LP gas, because LP gas requires a smaller orifice than natural gas. Call your propane supplier IMMEDIATELY...DO NOT USE THIS STOVE UNTIL IT IS CONVERTED TO LP GAS (if it's even possible)...this is extremely dangerous and you could hurt yourself if you continue to use LP gas on a stove that was designed to run on natural gas.
Dec 06, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Oven Burner is giving a yellow flame
new ge range, converted to lp. oven flame is going up the sides of the oven and air shutter is all the way closed.
Nov 23, 2008 | Kitchen Ranges
Sf114pxsw1 lp conversion
On the regulator of the stove there is a knot tha you swich to propane it have the latters lp or nat.swich it to Lp. you most open the air vents on all the burners.
Nov 21, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
JGBP89SEMSS BURNER HEIGHT
Sounds right long as you did the conversion okay did you change the spring in the reg ? lp gas does burn lower than nat gas smaller blue flame . you could see if the aeration can be adjusted to the burners You could also check the pressure at the burners lp working pressure is 14in wg .
You could check the reg outside . That's all I got .
Mar 17, 2017 | GE JGBP88SEKSS Gas Kitchen Range
Yellow flame
lp burners dirty.clean out the orfice and burner and this should solve your problem.
Dec 11, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Lp flames to top of oven
You need to tighten down the orifice spud for the bake burner. Remove drawer in bottom of oven. Look for bottom of burner tube, where the shutter adjustment is. Right below it is the orifice spud. Usually a goldish color. Take 1/2 inch open end wrench and tighten until it stops. Do-not overtighten! Try it now. If flames are still to high, tighten a little more. Repeat if needed.
Nov 18, 2007 | Kitchen Ranges
GE Profile JGB900 Gas Kitchen Range Logo
53 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
