Question about Panasonic PT-43LC14 43" Rear Projection HDTV
The lamp needs to be changed. can we still watch it without fatal injury to the tv?
Have a Samsung HLP6163wx problem
Hey friend:
most probably' 1) either your lamp was NOT installed correctly, or
2) lamp is bad - (it happened to me once, so no sweat!) - in this case you need to return the lamp in exchange for a new one.
Please watch any of the 'how to change the lamp on a dlp tv' video demo available on YouTube. Its not difficult. I already changed mine 3 or 4 times. Thanks
Jun 12, 2014 | Samsung HLN617W 61" Rear Projection HDTV
My Samsung plasma tv keeps messing up on me after a couple of hours watching it The screen loses all its color and the sound goes Any help
It wounds that the main digital processor board to your TV has the fault. Contact any service technician. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service center. To get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Screen-shots to defective plasma TVs are given.
Dec 12, 2013 | Televison & Video
Dead set no sound picture tube totally blackout. unit goes while watching tv program
If the unit has shut down during watching a program, there are mainly to reasons. The first one is its EHT section, and the second one is its main power regulator section circuits. Contact any service technician. Troubleshooting to this kind of fault is somewhat skilled one. If you wish to get some details, check the site linked here. Pull up older posts. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service center.
Dec 08, 2013 | Aiwa F2000 20" TV
TV FUSES
If fuse should blow, there should be a reason for that. Without locate it and rectify the same, if you replace an other fuse, it too will blow up. One main thing to remember is not to use fuse rated more than specified. A short circuited component/s at it main power supply regulator section might cause this. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Jul 30, 2013 | Televison & Video
Blown tv fuse
If main fuse should blow up, certainly there will be a reason for that. Your TV need a through checkup. Contact any service technician.Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Jul 21, 2013 | Panasonic VIERA Televison & Video
Tv turns off itself
Check its horizontal output section circuit, and replace damaged component/s. Contact any service technician. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Jul 17, 2013 | Sanyo Televison & Video
My projection tv display got really dark a few days ago. I didn't change any setting before it happened, but I tried to change them today in order to lighten the display, but it didn't help. Could a...
Yes,most likely the projection lamp life are ending.The tv projection lamp been inside the tv like 1 1/2 or 2 years?Daily tv watches like 4 or 5 hours regularly?Yes,than the projection lamp life are ending,tv do need a requirement of a new projection lamp.
Jan 06, 2011 | Samsung HC-P4752W 47" Rear Projection...
Need a lamp for my sony grand wega KFE50A10
Check this link to find the lamp for your TV. Since the lamp will come without the enclosure, watch the video from this link to assemble it in the enclosure.
Let me know if you require further assistance.
Jan 02, 2011 | Sony Grand WEGA KFE50A10 50" SDTV LCD...
Lost the lamp cover, changed light and tv wont come on
the lamp cover has a small tab that pushes the lamp switch..the tv will not turn on without..you need it :))
Dec 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Hi there
Yes the lamp light means change the lamp. If you have not changed one in this tv yet it is overdue.
Jul 05, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Panasonic PT-43LC14 43" Rear Projection HDTV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
