Question about Ryobi Circular Saw W/Dual Laser
Ryobi circular saw --it keeps tripping my breaker
Every time I go to turn on my Ryobi circular saw it keeps tripping the circuit breaker - why?!
  • 48 Answers
I would inspect the cord before doing anything, checking the leads for signs of scarring which could be due to leakage/incorrect grounding due to damaged internal wiring. The saw could be dangerous to operate so take care and make sure you have continuity after all is said and done that way you don't have to take the saw back apart.
Posted on Apr 15, 2010
    Brigadier General:
  • 4,088 Answers
Possible bad circuit breaker. If on a ground fault sensing circuit, the saw may have electrical leakage from it's internal wiring/motor to case ground (a possible problem if you have been using a metal cutting blade)(test by using a 3-pin to 2-pin adapter [no ground pin]). The circuit breaker may not be rated for the starting load of the saw (check the saw load rating against the breaker current rating--the breaker rating should be at least 25% higher). Possible excess current draw in the saw if any of the motor windings have shorted together for whatever reason. Hope this helps!
Posted on Feb 06, 2010
  • drallim Feb 08, 2010
    You should also check the movement of the blade for excess friction in a bearing or gearing. This will cause excess current to flow when starting the saw.
How do I replace the fuse on a Ryobi 10 inch table saw (BTS16)?
Repair manual.
As I see it there is no fuse or circuit breaker. Some motors have self resetting thermal breakers but i see no mention of one.
The operators manual trouble shooting section mentions checkin fuse or circuit breaker but did they mean a fuse or breaker in the saw or supply line. If it has had much use I would check the motor brushes.
Repair Manual
http://www.ereplacementparts.com/images/ryobi/BTS16.pdf
Operators Manual
http://www.homedepot.com/catalog/pdfimages/09/09e90711-9fa6-414f-8a87-7392af29a48e.pdf
Sep 27, 2014 | Ryobi Saws
Ryobi 10 inch table saw trips breaker when he turns onRyobi 10 inch table saw trips breaker when you can it on
First of all the saw needs to be plugged in directly to a outlet . NO Extension CORD !!! If it is Right , then Check on the motor label and see how many AMPS the motor is ? You need to then check the Breaker box and make sure the breaker is big enough to handle the load of the motor on the saw . You may have to make sure that the saw is the only thing on that breaker . NO Refrigerator , A/C , ECT.
Also make sure that the motor is clean and not packed full of saw dust . This can over heat the motor and kick off circuit breaker fast .
Good Luck , Hope This Helps !!!!!!!!!!!!!!
Aug 22, 2014 | Saws
Bosch 71/4 wormdrive keeps flipping breaker
If the saw is tripping breakers, either you are trying to run the saw on a circuit that can't handle the amps the saw needs to run or something is wrong with the saw that is making it draw more amps than it should.
Power supply: You should be on a 15 amp circuit or higher for this saw. Popping breakers can also be caused by using long or low guage extension cords or a low guage power cord on the saw. The saw should have a 14 guage power cord on it and extension cords should not be lower than 12 guage if 50 feet long.
Saw: You've already replaced the cord & switch, if the brushes are OK, look to the mechanics of the saw. The blade should turn freely and smoothly by hand with the saw unplugged. Things to look for are a lack of lubrication in the transmission, binding or broken gears in the trans and binding or seized bearings on the armature or worm gear set. Also, a dull blade forced through wood will also cause the saw to be overworked and draw enough power to trip breakers.
Feb 18, 2013 | Bosch 7 - 1/4" Skilsaw Circular Saw
Ryobi 7-1/4 in. laser circular saw will not turn on when it is plugged in.
Same problem with mine but I.found a guy's blog on google and he had identical problem and found the "pre travel switch," that they saw fit to put in the saw was the culprit. It's not a typical switch and has issues making contact often times (Ryobi are you listening?) He was able to take it apart and make a adj/repair (instructions he provides on blog) but who knows how long it will last? Here's the link:)-> http://www.woodtalkonline.com/topic/9508-ryobi-circular-saw-broken-and-fixed/
Dec 17, 2011 | Ryobi 7 1/4 In. Circular Saw W/ Dual...
Ryobi TS-254 blade guard does not retract when blade is lowered
Probably something jammed up inside the body of the saw where the guard retracts, like a chip of wood. I once had the same problem with my circular saw guard not retracting. Turned out there was a screw that had somehow gotten trapped in there and once that was removed, guard functions perfectly now. Definitely sort it out as soon as possible because this is very dangerous--you could make a cut, rest the saw on your leg and... earn a quick trip to the emergency room.
Aug 11, 2011 | Ryobi Saws
My blade to my circular saw model number 5007nb was having trouble cutting through some wood which lead to it over heating how can i fix this thing and get it to start working tonight
Well you did not really say what is wrong?
Are you trying to stop the overheating, or did it get so bogged down from blade heat warpage, that the internal circuit breaker tripped?
If so, then look at the end of the motor, near the cooling vents, and press the little black circuit breaker reset. (not all have them)
Also check that the outlet still works, by plugging something else into it, because you may have tripped the circuit breaker for the outlet, or GFP.
Mar 12, 2011 | Makita K06 Switch 5007fk 5007nb 5007s...
My Delta radial saw motor keeps tripping the GFCI circuit. I've tried several separate circuits and they all trip as soon as I turn on the motor (even a 20 amp dedicated circuit). I took off the motor...
saws draw a lot of amps at start up and will normally blow any GFi circuit, if it does the same in a normal outlet,, you might have to disassemble your saw for a good cleaning and lube,,
Aug 03, 2010 | Ryobi Circular Saw W/Dual Laser
My DW384 circular saw keeps tripping the GFI receptacle
Most houses have all the outdoor GFI outlets on one breaker...perhaps you can try another power tool with a similar draw to check if it is your saw or the GFI causing your problem. I can't see bad brushes causing a breaker to trip... the saw would just stop working.
Jun 20, 2010 | Dewalt 814 Inch Circular Saw
12 inch compound miter saw wont turn on. was working earlier.
check fuse box/ circuit breaker,,make sure its plugged in,,,check cord, switch, and the connection of the cord to the switch,
Nov 30, 2009 | Ryobi Saws
Ryobi Circular Saw W/Dual Laser Logo
821 people viewed this question
Top Ryobi Saws Experts
enb54
Level 1 Expert
Jim Thurston
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
