Question about HP Computers & Internet
Hello, my name is Toby, and I have an hp notebook pc. The problem i am having, is that my e drive is missing, when I click on computer, to go to where my drives are. I am also not able to burn cds or videos, because I have an icon that says to connect a burner and restart the windows media player. The computer is not recognizing that I have a drive for the cd/dvd application. I don't know if this has anything to do with the problem, but when I go into my device manager, the optiarc dvd rw ad-7561sata device has a yellow triangle with an exclamation mark inside of it. I believe that all of these problems are tied into my e drive missing. Can you offer any solutions? Thank you.
    President:
  • 1,015 Answers
Try doing this. Go back into the device manager and click on the optiarc drive and remove it. Then re-boot the computer. Windows should detect the drive when it reboots and re-install the driver. Hopefully this gets the drive working again. When you go back into the device manager the exclamation mark should not be there. If it is then there might be a problem with the drive itself. Let me know if you have any more questions or if this works.
Posted on Feb 06, 2010
Tray App msi repair
When you get the error for missing trayapp.Download full feature software and drivers from hp.com. After extracting the downloaded file. Go to your my document's folder. Click tools, go to folder options and make sure to enable "show hidden folders". On the missing trayapp error message, click browse, go to my computer, go to disk drive C:, go to user and document settings, open the folder that has your login name, look for application data > local > temp > open a folder named 7z345 or any folder that has 7z for a file name.. open setup > open trayapp > then click trayapp.msi and click open.. a long process but that should solve your missing trayapp problem.. if you need help, i suggest you call hp
Dec 28, 2013 | Acer Aspire 5735 Notebook
DVD drive of my HP DV6000 is not showing in My Computer. Kindly help sushantkumar_k@yahoo.co.in
try to go to control panel and click device manager. click scan comp and you will see your dvd drive with unknown sign click update driver if required den if your dvd driver is missing click brows in internet it automaticaly download the driver of your dvd rome.
Aug 01, 2010 | HP Pavilion dv6000z Notebook
The NTLDR is missing and I don't know the administrator password. Help!
1. Restart computer
2. Tap the F8 key
3. Arrow up to safe mode
4. Go into the Administrator account
5. If asked user name type in Administrator
6. Once windows open, go into the Control Panel
7. Double click on user accounts, click on your name
8. Select remove password
9. Restart computer.
Feb 22, 2010 | HP Pavilion dv1000 Notebook
Hp pavilion dv9000 does not recognized DVD in vesta
From your description I understand that the DVD drive is not working .
Do not worry, run the following fix on the pc and then restart the notebook.
http://www.techiesspot.com/filez/cddvdfix.reg
Dec 28, 2009 | HP Pavilion dv9000z Notebook
Boot mgr Is missing on a tobisha laptop
Method 1:
Use the following procedure to repair the file system on the hard drive:
  1. Turn off the computer and wait at least 5 seconds with the computer in a full off state.
  2. Turn on the computer and press the F8 key repeatedly as the computer starts. An "Advanced Boot Options" screen opens.
  3. Select Repair Your Computer and press Enter.
  4. Select a keyboard layout that matches your country/region and click Next.
  5. When the login prompt appears, select the user name with Administrator rights (not Administrator) from the User Name drop down. The user name with Admistrator rights is most likely the first user name that was entered during the initial computer setup.
  6. Type the logon password into the Password field and then click OK.
  7. A System Recovery Options window opens.
  8. Click Startup Repair.
A Startup Repair window opens and automatically scans for startup problems.
  1. Perform the actions suggested by Startup Repair: system restore, correct damaged or missing files, or other action.
  2. After Startup Repair has been used, try to open Windows.
    • If Windows Vista opens, you are done.
    • If Windows Vista does not open, perform the first portion of this section again to open the Startup Recovery Options window and continue.
  3. From the Starup Recovery Options window, click Command Prompt.
  1. Enter the following at the command prompt:
bootrec /fixboot
bootrec /fixmbr
  1. After the bootrec tool has been used, close all open Windows to restart the computer and open Windows.
    • If Windows Vista does not open, continue using these steps.
  2. Perform a full system recovery using recovery discs. For more information refer to the HP support document Performing an HP System Recovery in Windows Vista .
If the recovery cannot be completed from recovery discs, replace the hard drive.
Sep 13, 2009 | IBM ThinkPad T43 Notebook
My cd/dvd driver is not working on my hp notebook
Go to HP's support website, find your laptop, and get the missing driver, or find out what brand your cd/dvd drive is and go to the manufacturers website to get the driver. I hope this helps!
Jul 24, 2009 | HP Pavilion dv9000z Notebook
Drivers missing
www1.hp.com/wwpc/uk/en/sm/WF05a/5043-5343-5347-5347-5427-7414095.html - 43k -
Nov 01, 2008 | HP Compaq nc6000 Notebook
HP DV1000 notebook
email me if you still need drivers <i have them princesaazul2000(at)hotmail(dot)com
Aug 03, 2008 | HP Pavilion dv1000 Notebook
HP DV2000 DVD CD ROM ejects
Check the system hardware properties.
right click on my computer icon --> choose Properties
System properties will pop up. go to Hardware tab --> click on Device manager. there all the hardware install on yr machine will display choose your DVD drive and check the property of drive.
if it is working file.
you just update your dvd drive. iether from web or from a driver cd came with your machine
Dec 25, 2007 | Acer Aspire One PC Notebook
Computers & Internet Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
