Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
My PS3 is asking for my WPA key which is a 10 character code but when I put it in it goes down to 8 characters and therefore won't connect me to the internet due to incorrect key. What should I do?
  • 163 Answers
Try looking through the PS3's Wireless connection settings, or change your routers settings.
Posted on Feb 06, 2010
Hello, I'm trying to connect my wii wireless and it keeps giving me an error code 51330 "unable to connect to the Internet" could you tell me what it means? Thank you.
Error Code: 51330
This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
Are you using WEP or WPA security on your router?
  • Log into the router using the default IP (consult your router's manual for assistance)
  • Locate the "wireless security" section of your router settings and find the WEP or WPA key.
  • If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
  • If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
  • The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
  • If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
  • If you are using WPA, the Wii console is compatible with the following types:
  1. WPA - PSK (TKIP)
  2. WPA - PSK (AES)
  3. WPA2 - PSK (AES)
But if the above information doesn't help correct this problem, then give a call to Nintendo's 1-800-255-3700 (6 am ~ 7 pm Pacific, everyday)
Feb 27, 2011 | Nintendo Wii Console
Not able to connect the sons Nitendo DSi to the internet. They are asking for the WEP Key but on my home hub there is only a WPA Key. BT have told me to connect to you to ask for support.
If your using WPA and your Nintendo DS only supports WEP Encryption theres no way you can connect it to the internet. WEP encryption is different from WPA.
WEP key uses hexadecimal - using characters 0-9, A-F or ASCII format. The ASCII format is easier to remember. The ASCII string is converted to HEX over the network.
Example of WEP key encryption are:
*64-bit hexadecimal keys are exactly 10 characters in length. (12345678FA is a valid string of 10 characters for 64-bit encryption.)
*128-bit hexadecimal keys are exactly 26 characters in length. (456FBCDF123400122225271730 is a valid string of 26 characters for 128-bit encryption.)
*64-bit ASCII keys are exactly 5 characters in length (DMODE is a valid string of 5 characters for 64-bit encryption.)
*128-bit ASCII keys are exactly 13 characters in length (2002HALOSWIN1 is a valid string of 13 characters for 128-bit encryption.)
WPA Key is entered as a pass phrase between 8 to 63 alphanumeric characters in the ASCII format at both ends of the wireless connection. Although PSK accepts a minimum of eight characters, for proper security, it is a good idea to use ample length and should not use a commonly known phrase. This phrase is used to generate session keys that are unique for each wireless client.
To resolved the issue you have an option to change the WirelessSettings on your router to WEP instead of WPA since WEP is also a secured netwrok. however you need to keep in mind that if you change the encryption you need to configure all othere device connected to the router via WPA and change the settings to WEP.
Thanks for using Fixya
Aug 02, 2010 | Computers & Internet
Setting secured wireless connection
You can enable WEP on your router.
In the address bar of your browser, type 192.168.0.1 to access the setup page of the Dlink router.
By default the username is admin and leave the password blank.
On the Setup page, go to Wireless.
Security Mode should be WEP then click Next.
You can change the WEP KEY 1. Make sure you remember this because you will need to enter this on your wireless computer.
Save the settings.
I hope this helps!
Jul 19, 2010 | D-Link DIR-625 (790069292637) Wireless...
Problem connecting to Internet
I believe the Playstation 3 does not support WPA2. Try to use WPA instead.
Apr 07, 2010 | Sony Playstation 3 (PS3) Console
My archos 605 gen 5 cannot connect to internect
Try:- Menu Settings Language and Region WiFi Region.....set to "EUROPE" Followed by: Menu WiFi Status WIFi ...important that pasword format corresponds to that of your WiFI system eg WEP or WPA. The type of format will dictate the length of code. Generally WPA can accept a longer code than WEP format although a short code can be used for either. If your Archos is set to WEP and your WiFi network set to WPA (or vice versa) the format conflict will not allow the correct password to recognised It should be possible to use the
Dec 30, 2009 | Archos 605 WiFi Digital Media Player
I want to put a password on my D1-524 router
then you need to login on your router. connect to it with the routers ip address and login with usr: admin and pwd admin, then go to system and change password.
Oct 12, 2009 | D-Link AirPlus DI-524 Wireless Router
Can't connect with microsoft MN-510 using WPA
This means that you have to enter the network key into your computer in order to connect to the network,
If you enter the password as hexadecimal characters, you must type exactly 10 characters (5 bytes) for a 40-bit key (valid characters are 0-9 and a-f), or exactly 26 characters (13 bytes) for a 104-bit key.
If you typed any number of characters other than 10 or 26, or any character that is not a hexadecimal digit, this is interpreted as ascii string.
In this mode, each character is a byte by itself.
So, valid length of the string in this case is either 5 or 13 characters.
If this condition is not met, the string can't be accepted as a valid password.
Please check carefully what you type. (Letter O instead if zero, or small L instead of 1 etc.)
If you don't know the key, you have to connect to the router via a cable and copy the key from there - or ask your Dad to give you the information. He will have it, because he has a working connection.
If you have any more questions or this is not clear ot you, just come back here and leave a comment - I'm happy to help.
May 29, 2009 | Microsoft Broadband Networking MN-500...
HP laptop not recognizing Linksys Wireless B Security Key..
The WEP encryption is consist of 10 characters for 64 bit hex, 128 bit hex is 24 characters and WPA is 8 to 63 characters. So it seems that you have a vista computer? The compatible encryption for vista is WPA, sometime using WEP it is not working properly. So I might advise you to access the configuration of your router (192.168.1.1) and change the wireless settings of your router to WPA-Personal.
Mar 09, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Sir, i cant acces irles internet conection from my room,becuse i don't know pasword
Try accessing the configuration page of your router by typing 192.168.0.1 on the address bar of your browser and log-in to the dlink.
>Configure your wireless setting on this window.
>Under setup click on wireless setting
>Then click on manual wireless ....setup
>You will have the configuration of your wireless network.
>You may use WEP or WPA for your password on your security
>For WPA with pre shared key or passphrase the minimum character for your password is 8 characters
>For WEP with pre shared key of passphrase the minimum charactere for your password is exactly 10 characters.
>Once you have save your wireless network
>Go to your laptop and connect to your wireless network before
connecting to the Internet.
Jan 12, 2009 | D-Link Xtreme N DIR-655 Wireless Router
I am attempting to secure my network through this router which at this time is open for the whole neighborhood to see
Here are the diffenent types of Security Settings possible with a wireless router: (how to set this depends on the brand of router)
Security Mode: You may choose from Disable, WEP, WPA-Personal, WPA2-Personal, WPA-Enterprise, WPA2-Enterprise, or RADIUS. All devices on your network must use the same security mode in order to communicate.
Capture(wlansec.wpapersharekey) WPA Personal:
Capture(helpwpa.phase8) WPA Algorithm: You may choose from TKIP or AES.
Capture(helpwpa.phase9) WPA Pre-Shared Key: Choose a unique key to authenticate with other devices on your network. The Pre-Shared Key must be between 8 and 63 characters in length.
Capture(helpwpa.phase10) Group Key Renewal: This settings determines how often your group key changes.
Capture(wlansec.wpa2persharekey) WPA2 Personal:
Capture(helpwpa.phase11) WPA2 Algorithm: You may choose from AES or TKIP+AES. Choose TKIP+AES if you have both WPA and WPA2 devices on your network.
Capture(helpwpa.phase12) WPA2 Pre-Shared Key: Choose a unique key to authenticate with other devices on your network. The Pre-Shared Key must be between 8 and 63 characters in length.
Capture(helpwpa.phase13) Group Key Renewal: This settings determines how often your group key changes.
Capture(wlansec.wparadius) WPA Enterprise:
Capture(helpwpa.phase14) WPA Algorithm: You may choose from TKIP or AES.
Capture(helpwpa.phase15) RADIUS Server Address: The IP address of your RADIUS server.
Capture(helpwpa.phase16) RADIUS Server Port: The port your RADIUS server uses.
Capture(helpwpa.phase17) Shared Secret: The shared secret set on your RADIUS server.
Capture(helpwpa.phase18) Key Renewal Timeout: Determines how often your keys should be renewed.
Capture(wlansec.wpa2radius) WPA2 Enterprise:
Capture(helpwpa.phase19) WPA2 Algorithm: You may choose from AES or TKIP+AES. Choose TKIP+AES if you have both WPA and WPA2 devices on your network.
Capture(helpwpa.phase20) RADIUS Server Address: The IP address of your RADIUS server.
Capture(helpwpa.phase21) RADIUS Server Port: The port your RADIUS server uses.
Capture(helpwpa.phase22) Shared Secret: The shared secret set on your RADIUS server.
Capture(helpwpa.phase23) Key Renewal Timeout: Determines how often your keys should be renewed.
Capture(wlansec.wep) WEP:
Capture(helpwpa.phase24) Default Transmit Key: The key you would like to use for transmitting WEP keys.
Capture(helpwpa.phase25) WEP Key Bit: You may select from 64-Bit or 128-Bit encryption.
Capture(helpwpa.phase26) Passphrase: You may enter a passphrase consisting of any keyboard character to be used to generate a hex WEP key. Passphrase option is only supported when you are only using Linksys devices on your network.
Capture(helpwpa.phase27) Key 1-4: You may enter a WEP key manually. You must use only hex characters (0-9 and A-F). 64-Bit WEP requires 10 hex characters. 128-Bit WEP requires the use of 26 hex characters.
Capture(wlansec.radius) RADIUS:
Capture(helpwpa.phase28) RADIUS Server Address: The IP address of your RADIUS server.
Capture(helpwpa.phase29) RADIUS Server Port: The port your RADIUS server uses.
Capture(helpwpa.phase30) Shared Secret: The shared secret set on your RADIUS server.
Capture(helpwpa.phase31) Default Transmit Key: The key you would like to use for transmitting WEP keys.
Capture(helpwpa.phase32) WEP Key Bit: You may select from 64-Bit or 128-Bit encryption.
Capture(helpwpa.phase33) Passphrase: You may enter a passphrase consisting of any keyboard character to be used to generate a hex WEP key. Passphrase option is only supported when you are only using Linksys devices on your network.
Capture(helpwpa.phase34) Key 1-4: You may enter a WEP key manually. You must use only hex characters (0-9 and A-F). 64-Bit WEP requires 10 hex characters. 128-Bit WEP requires the use of 26 hex characters.
Jul 03, 2008 | Computers & Internet
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
323 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
