Question about Audiovox Xpress EZ XM Satellite Radio Receiver with Vehicle Kit
Starting problems? why does my diesel car take time to start in the morning?
  • 90 Answers
It could be a glow plug problem ,either the plugs themselves or the feed going to them.check to see if there is 12 volts at any of the plugs when the ignition is switched on,b u should also hear a click as the glow plug relay swithes off.
Posted on Feb 21, 2010
Car won't start first time each day but after the first start. It starts every time during the day
That is most likely a problem with your choke. If you have a diesel, it would be glow plugs. Also your fuel pressure can bleed off over night if you have even a small fuel system leak.
May 14, 2016 | Cars & Trucks
The car usually starts in the morning but after driving and then parking it for some time it will not start unless jump-started. But it starts again the following morning. Why is it behaving this way?
diesel is diesel and the quality will only affect performance
At this point from what you state I suspect that it is a starter motor
To remove it and have it pulled down and armature and fields properly tested would remove it from the list
have an accredited auto electrician check out the charging system
Mar 15, 2016 | Cars & Trucks
Terrano diesel 1996 auto transmission starts in the morning but stalls when put into gear. It won't work until after 5 minutes at idle after which time it seems to work. Have had the diesel injec
try a new fuel filter if you haven't replaced it already. you may have a weak injection pump; does it crank for a long time before it starts?
Apr 06, 2013 | Cars & Trucks
My bmw 318 diesel wont start when the engine is cold i have replaced the heater plugs and control unit bu i noticed this morning that the engine manage managment light does not come on straight away and...
i was having the same problem...then i got a diesel treatment its call diptaine mix it in with your fuel and let it do it work the next morning my car started no problem
Oct 06, 2012 | 2004 BMW 3 Series
My car will not start on a morning
if your mercedes is a diesel, your glow plugs are bad if it's not starting on cold mornings. either replace them or try cycling the key over 5 times, each time waiting for the wait to start light goes off, but that won't last forever. hope this helps and thank you for choosing fixya.com
Nov 13, 2010 | Mercedes-Benz CLK Cars & Trucks
I ahev a 2005 ford f350 with 6.0 diesel, i am
Bad Injectors most likely. I have a 2006 f-350 and was having the same problem. I ended up changing the fuel pump and 4 injectors.
Jan 11, 2010 | 2006 Ford F 350 Super Duty
How can i made maintenance for the injection part becuse when i start the car at morning i need to start it 5 or 6 times until it start without stop by it self
hi,if your engine is a diesel engine,you need to check the glow plug system,it is necessary special in morning,then you have another problem,seem vacuum is leaking for engine not stop by itself,you can visual check if there is loose vacuum connection,ty
Apr 02, 2009 | 1994 Mercedes-Benz C-Class
Isuzu 2001 diesel engine won't start
cant start deisel 3.0 lilter sounds like there is no fuel getting to the engine
Jan 19, 2009 | 2001 Isuzu Trooper
Audiovox Xpress EZ XM Satellite Radio Receiver with Vehicle Kit Logo
53 people viewed this question
Top Audiovox Audio Players & Recorders Experts
John
John
phil
Andrew Taylor
Andrew Taylor
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
