Question about Microsoft Xbox 360 Console
What can i do if there is no signal on the tv when the xbox 360 is on
  • 340 Answers
Are you using an hdmi cable or av cable?
Is the green light in the center of the ring lit but no ring?
Will your controllers sync with the console?
I f you comment with the answers to these questions I am sure we can help.
Posted on Feb 07, 2010
Cannot connect my xbox 360
This TV cannot accept signals from Xbox.
Dec 18, 2012 | Insignia NS-27RTV 27" TV
My xbox 360's wires are all plugged in the correct places and other people can see my xbox profile when i turn my xbox on but on my component source on my tv it says no signal so i can not get a...
If you have the AV cable that has the switch on the Xbox end, make sure that it's in the correct setting. Your cable could have shorted out if this does not work.
Aug 17, 2011 | Microsoft Xbox 360 Console
I have an xbox 360, but i have a ps3 connect to the tv via hdmi. i swapped the hdmi cable to the xbox and powered on. i had all the cables in the correct position, the correct av selected on the tv, but...
Have you tried disconnecting the HDMI cable from both the TV and the console and then trying to reconnect?
Y+RT does not reset controllers for the Xbox 360, so not sure what you are attempting there?
What type of TV do you have? It appears the issue is with either your cable or the TV seeing that you are having the same issue with both your PS3 and Xbox 360.
I still think your first step should be to disconnect all cables from both ends and reconnect. (with poer off of all sytems of course) If this doesn't solve your issue then submit further information on your setup such as TV make and model and I can research other possibilities.
Jul 16, 2011 | Microsoft Xbox 360 Elite Console - Black
When x box 360 is plugged in to tv,there is no signal
try reconnecting all the cables and make sure you have the right setting(normal tv or hd, theres a switch on the cable), if that doesnt work, you might have a faulty cable, or even worse your xbox has an interal problem(very hard to explain, read this if you cant connect to tv....(http://xbox-experts.com/e/errorcodes.php) and you'll need to send it to microsoft for repairs.
Nov 12, 2008 | Microsoft Xbox 360 Console
Xbox 360 will not send a picture signal to TV
sounds like you have a graphics card problem with the xbox 360. possibly loose/damaged electrical connections between the GPU and the motherboard which has caused the xbox to not display a picture. with this being a Hardware problem i would suggest calling the Xbox customer support, numbers can be found on http://www.xbox.com/support call up the support team and explain your problem.
I believe that microsoft will ask you to send the Xbox direct to them so they can fix the problem for you, it shouldnt take long to correct !
hope this helps
Oct 29, 2008 | Microsoft Xbox 360 Console
While playing, we get a no signal on TV and xbox starts over
Check that the wire in the back in secured properly there might be a fault with the wires
Oct 03, 2008 | Microsoft Xbox 360 Console
Game mode on tv
If you have a HDTV then you need to change the resolution to 720i or 720p to support the XBox 360 HD video. If you have a standard TV (non-HD) then you'll need to change your XBox 360's video settings to non-HD. The problem sounds like your mixing up HD video signal. I really need more info about your TV. Is it HD? Or regular?
Mar 25, 2008 | Symphonic ST420FF 20" TV
Xbox 360 - While setting up in menu the TV went black and msg. No Sync. Signal
First, make sure you select either TV or HDTV selector on the Audio Video Cable that came with the XBOX. Second, if you chose TV plug the Audio/Video Cable connectot that are red, white , and yellow in color to your TV. Now see if you can see the Start up on the XBOX360.
If you still dont get anything, try plugging it on another television and see if that fixes your problem.
Dec 09, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
43 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
