Question about Nokia 6300 Cellular Phone
Nokia 6300 my cell phone shows charging on screen but still not charging cell phone battery. can you suggest me solution of charging battery?
    President:
  • 1,561 Answers
I suggest you remove the battery and test it with another similar phone to see if it will charge, if it does, it means the battery is ok but if it did not, it means the battery is bad and need to be change.
But if the battery is good, it means the charging port is bad, all you need to do is to change your charging port because that is the next action place to check.
Looking at this two areas should profile a solution to your problem.
Thanks and wish you best of luck.
Posted on Feb 06, 2010
Nokia 6300 won't turn on or charge, battery is dead
It probably needs replacing. Batteries are generally the first component to go faulty on cell phones. It might be swollen -- this is a clear indication that the battery is useless.
Nov 15, 2012 | Nokia 6300 Cellular Phone
Nokia 6300 fake charging it shows charging.
there is no fake charging, maybe your batterie is bad...try to change the batterie and try again...plz vote and rate this solution!
Sep 24, 2011 | Nokia 6300 Cellular Phone
Nokia 6300 showing charging but not increasing battery charge level
Could be possible that the charger or the battery by itself is faulty as many of them gets reverse polarity in the cell. It will be ideal to swap and check with the same type from a friend which is most easy as many are around so as to confirm before you can invest.
Please clean the battery contacts and the terminals.
Apr 05, 2011 | Nokia 6300 Cellular Phone
Nokia 6300 charging not supported
When your phone shows charging not supported. First, you need to try a another battery on the phone, if it says the same thing, then try to use another charger, and if it shows the same thing, then you need to fix the charging port of the phone.
Before you do that, test, your battery and charger on another phone to see what happens, if they both work fine, then you need to fix the charging port of the phone.
Take care and good luck
Oct 13, 2010 | Nokia 6300 Cellular Phone
try to replace a new and tested one..if still fast drain your nokia 6300 is shorted and need to remove the shorted parts..thanks
Jun 10, 2010 | Nokia 6300 Cellular Phone
Bad contact charger
The charging port is bad, so you have to take it to a technician or get a universal or desktop charger to charge you battery.
Nov 03, 2009 | Cell Phones
NOKIA 6300 HAVING CHARGING PROBLEM
the battery was discharged change the battery
Apr 04, 2009 | Nokia 6300 Cellular Phone
Nokia 6300 does not boot up when started
Try this:
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know. You need someone to press the ON button.
Mar 26, 2008 | Nokia 6300 Cellular Phone
Nokia 6300 wont power on
check on that battery connector isnt damaged it looks like you middle pad BSI line its not connected properly
Feb 18, 2008 | Nokia 6300 Cellular Phone
Nokia 6300
Keep it on charge for whole night. Or else change the battery
Sep 03, 2007 | Nokia 6300 Cellular Phone
Nokia 6300 Cellular Phone Logo
131 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
