Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Kenmore Elite bottom freezer refridgerator
My fridge will not cool. The freezer cools fine but the digital display to adjust the temp for both the fridge and freezer does not work. When I plug it in the fridge stays ambient temp while the freezer goes down to 3 degrees. I did replace the circuit board that sits inside of the digital display unit.
kenmoore model 76523 , ss bottom freezer. this unit is about 2 years old. suddenly the refrigerator completely stopped cooling but the freezer is fine, the lights work correctly but the digital display does not change temp control on any settings. I disconnected the power for an hour, i was then able to change all control settings but the refrigerator still not working. then after an hour the controls would not adjust anymore only display numbers and temp. would alarm .note; the freezer works but unable to adjust freezer controler. temp. did show as freezer cooling.all coils are frost free and clean.
any suggestions?
  • 5 more comments
  • ealves Feb 24, 2008
    It must be an end of life issue my Kenmore Elite just did the same thing yesterday. I am trying to figure out what it is myself
  • big bad mary Feb 24, 2008
    mine just did the same thing. looks like they got us again. time for a new one. freezer works, refer wont cool.
  • Anonymous Mar 03, 2008
    I am experiencing the very same problem. My fridge is about 1.5 yrs old. Very frustrating. I have unplugged and replugged (my version of reboot) :) it
    appeared that it was going to work as we could then use the control panel but that ended quickly and the temp never did get cooler.
  • MNRick Apr 05, 2008
    This must be a Kenmoore brothers Refrig is kaput as of yesterday, freezer works but not the refrig and when attempting to run the service test's the control board will not work/respond as well. What gives?
    Is there any way I can get a positive responce from the control board without getting out my A.E.D and jump starting this darn thing??
  • tdsippy Apr 16, 2008
    kenmore elite trio 76523 top not working bottom is fine. Controls light up but will not respond to attempted changes. I turned the unit off for 1 hour but this did not help. I let it stay on during the night but this did not change anything. I can not get the control to work at all.
  • Anonymous May 18, 2008
    The display unit is at 40% and will not adjust and therefore this is going to cause everything to defrost.... please help.
  • Anonymous Mar 31, 2014
    Fridge part not cooling, Freezer good holds temp, but some ice even though Frost Free, Every thing at back of unit nice clean and fans at back and in freezer are working. Please help to solve this problem Thanks
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Posted on Nov 23, 2008
I have the same problem with my. The bottom is cold and the top is hot...
Same issue with the digital control panel..
Going crazy here,
This fridge is about 1.5 years old also..
Posted on Jun 25, 2008
Repair sercice coming out tues. will post results
Posted on Feb 24, 2008
  • big bad mary Feb 26, 2008
    Sears came out and replaced the fan. Apparently it's a common problem. There was a little bit of frost on the back of the freezer, but everything else was still frozen. Guess just a matter of time before that defrosted. Anyway, $200. later it's fixed. Hope it helps!
2 Suggested Answers
  • 19396 Answers
SOURCE: kenmoore 76523 ss bottom freezer, freezer works, refrigerator does not
This is not my main field of expertise . However, as I see you are not getting more support I can address you to this link. It may help you
Posted on Feb 22, 2008
Fridge not cooling... Freezer is fine
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
This will help.Thanks.Helpmech/.
Sep 12, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a kenmore elite coldspot side by side refridgerator and it is not cold enough on the fridge side. How can i fix this?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
Jul 08, 2011 | Kenmore 56983 Side by Side Refrigerator
My kenmore elite freezer works but the refrigerator is not cooling
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Sep 09, 2010 | Kenmore 53642 / 53644 Side by Side...
Bought floor model of Kenmore 79737 fridge - it is in display mode (lights on no cooling) kids at store cannot tell me how to switch off manual does not address
My fridge did the same thing. I was told to:
Hold either one of the fridge doors open and press the fridge temp and ultra ice buttons simultaneously for 5 seconds. The temps came on and the fridge started working.
May 01, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refridgerator not cooling, but freezer is freezing
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 21, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Fridge not working properly on kenmore bottom freezer model 596.7
I have a similar problem, although I have no cooling in the fridge section. Had a repair man indicate that the electrical panal(pcb board) needs to be replaced. It is on order ($200). Sure hope that is the issue. To me, it appeared that the freezer fan(which cools the fridge) was not working. Whether that is the result of a faulty electrical panal is yet to be determined. Good luck!
Aug 12, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator not cooling
This could be that it is out of balance. Set the temperature settings to midway. This control can easily get the fridge temp out out of balance if over adjusted. If you already have the tmp control at midway then you need to make sure there are no obstructions to the duct that carries the cold air from the freezer to the fresh food section to cool it. Check for ice buildup or any kind of blockage. Let me know what you find.
Nov 16, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
1,094 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
