Question about Hitachi 46F500 46" Rear Projection HDTV-Ready Television
Hitachi 46f500 I can't switch from ant A or B to vid 1 - 5 (with dvd) vis versa and only method to switch is by wiggerling the ant cox cable. No loose cables and checked by swapping cables as well. I did not have this problem until 1 month ago.
3 Suggested Answers
shaggyrat
  • 1224 Answers
SOURCE: hitachi ultravision 50v500
there should be 3 sets of video rca jacks on tv or receiver they might have put them on the wrong rca jack in which they just need to be moved over
usually the 3rd set of rca jacks are component jacks not for tv or video but for low output signals say like cameras and only one set of rca's can be used at a time svg on one of them rca's will over power the vid's. so have no picture
Posted on May 10, 2008
  • 13 Answers
SOURCE: Hitachi 46F500 turns off immediately
on/off sensor/switch went out
Posted on Feb 26, 2010
Change antenia settings
In the main menu will be a way to change inputs--antennas are on the set marked A,B etc. and are also usually on the original remote.
If you cannot resolve it tell me the model number and I would be happy to research it for you.
Apr 02, 2012 | Hitachi Televison & Video
Connecting up Digital TV, DVD recorder and VCR
You need to hook the VCR and the DVD recorder to the scart connections on your TV.
VCR to one scart on the TV
DVD recorder to the other scart on your TV
Jan 31, 2008 | Televison & Video
Hitachi DV-PF 2U dvd player works fine when hooked directy to TV (channel 3) but won't work when connected through the new COX digital cable box. TV is set to channel 4, dvd player turned on, disc...
If the cable box needs to be set to 4, the TV will need to be set to 4 as well as the dvd player. The hookup should be cable box to dvd player to the TV for your system to work. Let me know if you have any other questions. Thanks.
Dec 30, 2010 | Hitachi DVD / VCR Combo
My picture on the hitachi 46f500 is all small white line? when i try a dvd it is out of focus and all grren, blue, and red....
Ur convergence it dead.U know how solders?Buy a convergence kit use what in that kit.Tries Websites.Tv repair World.com,Tvrepairkits.com.
Dec 20, 2009 | Hitachi 46F500 46" Rear Projection...
My wife let the Wii remote and broke the front plexi-glass.
You can find a new Hitachi replacement protective screen and screen assembly for a model # 46F500 from a major Hitachi distributor at the following links:
Hitachi 46F500 Replacement Part Screen Assembly
Hitachi 46F500 Replacement Part Protective Screen / Ultra Shield
Feb 03, 2009 | Hitachi 46F500 46" Rear Projection...
Hitachi ultravision 50v500
Apr 14, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
No recption pass channel 12
judging by the year, this set should definitely be cable ready. check the front of the tv if it has a control panel for a switch that says catv/normal or something similar, if it does not have that switch, check the settings via the remote.
the channel a connector may require an adapter depending on the type of connector. i had an old tv that required an adapter in order to plug the cable coax into it, it resembled an rca connector and is used on some older tv's in place of a screw on connector.
if all else fails, your cable company should be able to provide you with a tuner/converter for free or minimal charge.
i hope this helps,
trin
Nov 16, 2007 | Hitachi 60SBX78B 60" Rear Projection...
Hitachi 46F500 46" Rear Projection HDTV-Ready Television Logo
16 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
