Question about Konica Minolta magicolor 2400 Laser Printer
Paper jams, transfer roller
I can no longer print with my magicolor 2430 DL printer. It shows either a media jam in paper tray 1 or a transfer roller jam. the paper will not feed through. It's very frustrating, can i fix this myself? Thanks for your help.
  • 3 Answers
SOURCE: konica minolta 2430 DL paper jam
Place a few papers in the tray.
Open up the top, pull out the main (green handle) thingy.
In the very bottom you will see a bar with a single large round rubber wheel in the middle, and white gears on both ends of the bar.
Manually turn the right side gear toward you.
As you do this, you will see the paper lift up and as the rubber wheel turns you will see that it has a notch on the bottom side.
Turn the gear, and watch the rubber wheel until the notch on the rubber wheel is facing up and away from you (and the paper is fully engaged).
Then put the green-handle thingy back in, close the printer, and it should work.
Apparently this resets something.  I have done it a number of times - usually after a paper jam.
Posted on Oct 30, 2007
SOURCE: media jam transfer roller
Hello pp-helps,
This is very interesting. I do have the very SAME problem with my Xerox 6120 printer. I've been looking for the fuser roller all over without any sucess. The new fuser unit costs approximately the same as a new printer. I'm frustated at this time. I want to ask you the following: Are the mechanical components from the 2430 exactly the same as the 6120 as far as the fuser unit goes? if I find a roller replacement for the 2430 will it fit my 6120? do you have a p/n by any chance or know where can I get it?
I really really appreciate your help.
Regards,
Frank
Posted on Feb 18, 2008
  • 214 Answers
SOURCE: Minolta Magicolor 2430 DL
Fatal error code 2AH: Faulty memory data.
1 - Unplug the power cord and plug it in, then turn OFF and ON the Power Switch.
2 - Check Parameter Chip (PJ26) on PWB-A for proper connection and correct as necessary.
3 - Change PWB-A. (8314139-0101-15)
4 - Change Parameter Chip.
hope it helps
regards
Posted on Sep 17, 2008
APremkumar
  • 564 Answers
SOURCE: Konica Minolta 2430 DL sometimes cartridge, sometimes paper jam
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
PREM
Posted on Mar 23, 2009
Joed911
  • 4338 Answers
SOURCE: replace the tray 2 pickup roller assembly
The tray two pickup roller is a roller in the front of the tray. Remove tray 2 and place it on a level work surface. Locate and open the cover that is
next to the roller in tray 2.
Pinch the blue latch that is on the left side of the roller. Slide the roller off of the shaft.
Then you can slide the new roller back in.
CAUTION When you install this roller, make sure that it locks into place. Verify that the
roller is correctly oriented, and that the round, black spacer next to the roller is correctly
positioned against the locking pin on the shaft.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 16, 2009
Media jam fuser
replace the fuser unit. and replace the transfer roller and belt,
Jan 30, 2014 | Konica Minolta Magicolor 2530 DL Laser...
Media jam transfer roller
directly below the drum ensure transfer roller properly installed also check the drum unit
Jan 08, 2014 | Konica Minolta magicolor 2430 DL Laser...
Media jam tray 1
Here are a couple of links from the Konica website which provide somes illustrated instructions:
Media Jam Tray 1; Paper Pickup Roller replacement instructions.
Clearing Media Jams
Replacing the pickup rollers seems like a drastic first step. I would check to make sure that the paper being used is suitable for this printer and it is in good consition. You might try a different paper to see if it makes a difference.
Good luck in resolving your issue.
Dec 30, 2010 | Konica Minolta magicolor 2430 DL Laser...
PREM
Mar 23, 2009 | Konica Minolta magicolor 2430 DL Laser...
I get a Media Jam Message
Hey folks! This solution worked for my "media jam tray 1" problem! Just took out paper, pushed down @ back of tray, reloaded paper, and bingo! Now to use some air to blow out any dust.
Thank you
Mar 23, 2008 | Konica Minolta magicolor 2300DL Laser...
Minolta 2350 DL laser printer stuck paper in rear user roller
sry, dont understand, where is the paper jam, in the end at the fuser ? or some where else?
Feb 05, 2008 | Konica Minolta magicolor 2430 DL Laser...
We have a Xerox 6120 which is mechanically identical to the 2430. It was reporting media jams. We determined after removal and careful inspection that the fuser roller and fuser pressure roller had been damaged by what looked like someone attempting to clear a jam with a sharp object. I cannot speak re: the 2430, but the fuser in the 6120 is not a FRU. The construction of the fuser doesn't tolerate any flaws on either surface. There was more paper jammed in the fuser where we couldn't see it until we had the fuser out of the printer. We are shopping for a new printer as the repairs will cost more than we paid for the printer.
Dec 10, 2007 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta magicolor 2400 Laser Printer Logo
80 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
