Question about GE Profile Spectra JGBP90 Gas Kitchen Range
I have a G E profile stove top gas , I would like to know if I can put the grates in my self cleaning oven ?The grates are gray in color and they are a pain to get all the black spots off . On the grates I have used oven cleaner but this is such a mess I was hoping they would be cleaned in my self cleaning oven
  • 61 Answers
You can find the grates here
Appliance Parts Solutions
you will need you part# or model#
Posted on Feb 10, 2010
Can you put the top oven grates in the oven while it is self cleaning
The top burner grates are designed to handle direct heat in excess of self clean temperatures.
You can put the grates in to the oven during self clean... but it will not clean them. The baked on residue needs some chemical reaction to break down the reside on them. I would suggest soaking them in an oven cleaner like easy off. Spray them down good then using rubber gloves put them into a plastic garbage bag, spray them again in the bag and close it up. Let them sit and soak for an hour or so then wash them off. This is best done outside so the odors will not be in the home in an enclosed area.
Apr 26, 2010 | GE Profile JGP636 Gas Cooktop
Getting stains off burner caps on ge
Gently use a steel wool - or you can put all of the grate assembly pieces on self clean in the oven, wipe when finished.
Oct 15, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Cast iron grey grates are hard to clean
Don't use oven cleaner! It isn't recommended by GE. Their book explicitly says to put the grates in a plastic garbage bag and pour a some ammonia into the bag. Tie the bag tightly so all the gas stays inside. Put in a garage in case it leaks because it can smell bad. Wait 24 hours and the stains will come off with a hose and some light rubbing. I didn't believe it at first but it works great! My wife loves our 'like new' oven.
Sep 09, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Badly stained gray burner grates for stove
Common problem, very frustrating...Use the self clean feature of your oven if available or you can place all of the grates and pieces into a black trash bag, spray them with oven cleaner and let the closed bag sit in the sun for a while, rinse and spot clean. You can get the tough stuff by "gently" using a steel wool pad - be careful, you could scratch the surface.
Aug 08, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Stained gas range burner grates
Hey y'all. I have the same lame GE profile gas cooktop with the gray grates and burner covers. I know this is the expensive way to go, but I use Easy-Off "self-cleaning oven" oven cleaning spray. For about $5, you get 3 cleanings. It is a pain to do, but I have better things to do than scrub these grates all the time. I don't know why, but the baked on crud just drives me crazy. I tried everything to clean them completely. I even tried to scrub the darn things with a kitchen pumice stone(sold at walmart)but it is impossible to get the curvy areas clean. Now the paint has started to wear off on the burner covers.
I do not use the oven cleaner on the cooktop itself. I use soft-scrub with baking soda, then cover the cooktop with a sheet of heavy duty aluminum foil and cut out holes for the burners. This keeps most of the spills contained, and helps with cleanup.
I visited to the GE parts web page, and they only sell gray grates and covers. I am going to buy black BBQ grill paint(spray can)from Home Depot and try it on the burner covers first. They are the least expensive to replace if it fails, and if it works, I will paint the grates with this high temperature paint. I will keep you posted on the results.
Regards,
Laura D.
Feb 14, 2009 | GE 30 in. JGP337 Gas Cooktop
Cleaning of the metal grates on top of the range
Sure, why not? They are in direct contact with the fire during cooking.
Feb 02, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Cleaning grates of GE profile gas stove
Sounds crazy, but this works. Soak the grates in warm to hot water with 2 dryer sheets (Bounce), let them soak for an hour or two. Unbeliveable how they came clean. I did have to use a Scotch Brite pad on the two that I use most, but it sure beats replacing them.
Jul 02, 2008 | GE Profile JGP636 Gas Cooktop
I also have the gray grates...I have found that putting them in my self cleaning oven does the trick.
Mar 18, 2008 | Frigidaire 30" Self-Cleaning Slide-In Gas...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
153 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
