Question about Akai PTH5498 54" Rear Projection HDTV-Ready Television
Red outlines I have red outlines on everything on the screen. The Tv is kinda old, 2002 i think. Im just wondering if there is a simple solution, or is this gonna be something expensive
  • Joster Mar 24, 2008
    I think my problem is similar, but there is a red line on the left of the screen and everything to the left of that is green. There is also some doublevision going on. I don't have any exprerience at all. Any help would be greatly appreciated ! Thanks
  • 53 Answers
I'd say your convergence needs to be done. There is a user-level service convergence option, which will get your convergence good enough to be watchable. A really tight precision conversion requires a little more.
Also, turn off Scan Velocity Modulation. You probably need to go to the service menu for this.
DO NOT PLAY AROUND IN THE SERVICE MENU.
With your tv off, press mute, then one, then eight, then two, then power on. You should not be in the service menu. Using the channel down buttons (or volume down, I forget which) go down to the "video options" choice. There are four, and I think it's the second one. One of them has the option to set VM level. Select this with volume down, then when you can change it, set it to zero. Now, keep hitting the menu button until you are back to the first screen. Now press the mute button twice. Now turn your tv off and back on. Now switch it out of "dynamic" picture mode (never use it).
To properly calibrate your tv, buy a copy of Digital Video Essentials.
Posted on Mar 19, 2008
Grundig lcd tv standby stuck
Inverters use square wave voltage, which tends to stifle digital circuits. Leaving something stuck, or not working. Sure, the inverter will work for awhile, but then the rigid square wave eventually causes problems.
Feb 02, 2014 | Polaroid Televison & Video
Rca big screen 5-8 years old, power shut off this morning while watching then when I powered it back up now blurry and has a red and green outline around everything onscreen
If you have the original remote to that tv, click on menu, then select set up from the on screen menu, then select convergence. you might see auto convergence as well as manual for blue and red convergence.
If you see Auto, select it, this will line up your tubes.
If no auto convergence, you will have to select each one, and follow the instructions to aline your tubes.
Oct 09, 2010 | RCA R52WM24 52" HDTV Projection Television
It seems that I am watching my TV in 3D.
im joel a simple electroncis tech. try to adjust the settings but it does'nt work the i think 3 color inside ( red,blue,green) is one or two of them is deffective.so the best solution try to go the expert tech nothing else
Apr 12, 2010 | RCA P52926 52" Rear Projection Television
Red, green and blue colors don't match up on screen.
Please replace convergence out ICs (usually two) in TV.
If it is Hitachi 43UWX10B then its convergence out ICs are available in Part Store
Thanks.
Aug 24, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Too much red in the screen
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ...it may be also cathode ray tube... thank u.........
Jun 03, 2009 | RCA P52812BL 52" Rear Projection...
TV screen bouncing up and down
look for the horizontal hold.
Jan 26, 2009 | Akai PDP4206EA Television
Hey there. need a lil advise
check out . your tv focus is bad change it with new one
Oct 11, 2008 | Televison & Video
Double picture on Mitubishi WS-65511, Year 2002 TV
Your tv requires replacement of STK393-110 as it creates convergence problem and its available Parts Store here. If you want to do the job at your own, you need to know good soldering skills or get service of nearest TV repair shop.
Sep 13, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Wide black bar on bottom of screen
I you know how to repair electronics its not a hard fix. The worst case would be the vertical output IC but im thinking th its nothing more then a capacitor in the verticle sweep circuit The average cost to repair this should be around 75 to 125 bucks. Good Luck
Jun 01, 2006 | Toshiba 32A60 32" TV
Akai PTH5498 54" Rear Projection HDTV-Ready Television Logo
44 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
