Question about Samsung SCH-U470 Juke Cellular Phone
I when i try to put my music its say "music player is being initialize try later..." and when i check my memory capacity its say 0.its been like this for about a week
3 Suggested Answers
SOURCE: Samsung Juke not able to put music in!! Need help!!
I had the same problem. I just called Verizon & they had me take the battery out of my phone & then put it back in, the music is working again. I'd say try that & if it doesn't work, call them & they'll help you out! Good luck!
Posted on Dec 02, 2008
I had the same problem. It happened when I deleted all the songs off. Here's what I did:
I took out the battery (leave it out for like a minute)
Turned on the phone
Plugged the USB into the phone....then into the computer
I then got to pop up to sync/view files
Then I unplugged it and was able to go to my music
Posted on Dec 03, 2008
My nokia express 5310 is not playin any music.whenever i try to play music it commands like not enough memory.pliz help me out with this problem.
Welcome to FixYa!
To have more storage capacity for your phone, delete unimportant SMS in your INBOX, OUTBOX and SENT ITEMS. Delete also unimportant pictures, videos, music and ringtones. The phone memory is relatively small and is shared to all data and other files that are stored in the phone. By deleting some of these will free you some memory.
Alternatively, you can also put in a Micro SD memory card (Memory Card model depends to what your cell phone is compatible of, Micro SD is a sample) to your phone which will also increase its storage capacity. A Micro SD Card look something like the picture below.
A 16GB Micro SD is available at AMAZON http://astore.amazon.com/doityousol-20/detail/B001L1H0SC
Thank you for using FixYa.
Have a great day.
Jas247
Jun 16, 2011 | Nokia 5310 Cellular Phone
Tip
FORMAT ERROR IN MP3 PLAYER
if You are experiencing "Format Error" messages when adding or accessing music/videos on your player. this could be as a result of a corrupt memory region or not having the required or supposed memory size of the player(actual memory)
what you do you should format:
formating Ensures that what you have bought, is of the actual memory capacity.
. 1. You will not lose any firmware/theme related files.
2. You will not accidentally kill your player whilst doing so (unless you unplug or disconnect your player during the format process).
follow the step below to guide you
STEP 1
Back Up All Your Data Before Proceeding! This Guide Will Clear Everything In Your Player's Memory Chip!
Install MP3 Utilities, any version will do. It usually comes on the CD with the player, or you can download version 3.68
Here, or version 4.03 Here, or version 4.05 Here. Any one of these will do. The Disk Tool Utility is the same.
STEP 2
Start up MP3 Utilities Disk Tool.
You will be shown a screen like this:
Ensure that you select LOW Format Type.
Next, go to the Partition and Encrypt tab as shown below.
Now, slide the Partition Slider all the way to the Right.
You will notice the "Setting encrypted disk capacity" increases, it is normal.IMPORTANT.IF YOUR MP4 PLAYER IS LIKE 2GB OR MORE MAKE SURE THE PARTITION AND ENCRYPT TAB WHEN YOU INCREASE IT SAYS YOUR PLAYERS MEMORY.FOR EXAMPLE.IF YOU HAVE A 4GB MP4 PLAYER AND YOU ARE SLIDING THE PARTITION AND ENCRYPT TAB MAKE SURE THAT WHEN THE NUMBER INCREASES IT SAYS SOMETHING LIKE 4000MB.IF IT DOESN'T DO THIS DO NOT REPEAT DO NOT DO THIS ENTIRE PROCESS.
*NOTE* Ensure That You Do Not Click The "Set Username And Password", Leave It UNTICKED.
Next, click on Start to begin the format and partition process. You will be presented with a dialog box like below, click on Yes to proceed.
It will take a few moments for the process to complete. You will notice that your player would disconnect from the computer, and then re-connect back again.
You will be presented with the "Complete setting disk partition!" dialog box like below.
STEP 3
Go to My Computer and check that now you will two memory drives for your player. You might need to click Refresh or press F5.
One of which would be small (about 17MB), and the other would be the remaining memory capacity.
Do not worry if it does not appear, just continue to with the guide.
then go back to the Partition and Encrypt tab.
Slide the Partition slider to the Left, and click on Start.
repeat the process and the "Complete setting disk partition!" dialog box would appear.
Check in My Computer that now you will only have One single memory drive for your player. Right click on it and select Properties, this is your actual real memory capacity.
Now check your player's Memory Info for the correct memory display.
To access this, go to your player's SYS TOOL >> MEMORY INFO.
Your player should display the actual memory size that you have just checked.
Check if the percentage is at 0%. If it is, you can skip Step 4 below, and continue to Step 5.
STEP 4
If your player's Memory Info does not show 0%, you will need to complete the below procedure.
Right click on your player's memory drive, and select Format.
Now a new windows format screen would appear.
Select FAT in the File System dropdown menu.
If after completing Step 3, your player really does have 4GB of memory, then you need to select FAT32 instead. As FAT only supports upto 2GB.
Click on Start to begin on the format process.
A warning will appear for the format, click on OK to continue.
Wait for a few moments while Windows formats your player.
When completed, check your player's Memory Info again, it should display 0% now.
STEP 5
Once completed, start copying music/video files to your player and enjoy enjoy your player
on Dec 19, 2009 | Audio Players & Recorders
When i play music player in 5130c-2, it gives error "not enough memory"what can i do for solve this problem...
Hello and welcome to FixYa!
Nokia 5130 c-2 phone uses phone memory as a "virtual memory" to create playlist in the music player. Almost 5MB free memory required to phone to start the music player. If the memory is not there then it shows error "not enough memory".
To resolve this issue, delete some data from phone memory or transfer it to memory card, when there will be free memory available to music player, this error will not display.
You can also easily resolve this issue after formatting the phone memory or restore your phone to "Factory Settings"
I hope this solution helps you
Thank you for using FixYa!
May 28, 2011 | Nokia 5130 Cellular Phone
My mp3 player keeps on saying waiting for music info
Following Instruction check:
1. Check Your MP3 player memory. If it's full- then it will show this message.
2. Remove your some unwanted music from your MP3 player.
3. Check your MP3 player Memory Capacity in your Emerson Manual.
Apr 04, 2010 | Emerson BAR900 MP3 Player
My mp3 is all ******** u know,whenever i put songs in it,FORMAT ERROR occurs when i play it,dont know what is ******* it up.if anyone can fix this problem please help.thanks.
STEP 1
STEP 2
STEP 3
STEP 4
STEP 5
Once completed, start copying music/video files to your player and enjoy enjoy your player. hope this helps
Dec 19, 2009 | Apple iPod nano
Memory card inserted not downloading music to the player
try putting a folder on the sd card name it Music then put your music on that
May 29, 2009 | iLO MP3 Player
Need a manual or instructions how to operate it
experimental status
ZEN mozaic player 2 GB
firmware 1.03
ZEN attached to USB 2.0
Windows XP SP2
Message "do not disconnect"
ZEN is not being recognized
Check ZEN memory setting
Memory ZEN is set to 0 in MENU>Etras>removable disk
Memory ZEN should be changed to maximum 1.5 GB
ZEN is recognized now
ZEN is ready to do the format command
ZEN can be written to for a maximum of 0.5 GB [internal memory !]
ALERT ! This 0.5 GB is the internal memory
The files written to the internal memory will be erased after
disconnecting !
access status
NO ACCES TO MY ZEN ?
1) Get access to ZEN by setting disk memory to maximum
2) ZEN should be recognized now
format status
1) FORMAT the disk
After formatting !
SET BACK YOUR disk memory capacity to zero [ 0 ]
for fully recovering the disk capacity
files presence status
FILES NOT PRESENT AFTER DISCONNECTING ?
- When set to zero you can use the full memory for
writing files to the player !
- When keeping the memory set to maximum you're using
the internal memory and written files are not saved
after disconnecting
updating + files presence status
UPDATING FIRMWARE ZEN MOZAIC = MAKING STANDARD MAPS
1) download the firmware that is suited for your computer
Operating System and your type of player from "CREATIVE"
2) Connect player to USB 2.0
and update with the firmware-update
3) Wait until the update is fully completed
4) After the update disconnect the player
5) Connect to USB 2.0 again
6) Check for the presence of the STANDARD MAPS for Music,
Pictures and Video
7) Files can be written into the STANDARD MAPS
8) Written files should be present after disconnecting
9) Files ready for mobile playing on ZEN mozaic now
CREATIVE support site for fimware / software / userguide
SUPPORT FOR ZEN MOZAIC ON THE INTERNET
http://support.creative.com/Products/ProductDetails.aspx?catID=213&CatName=MP3+Players&subCatID=214&subCatName=ZEN&prodID=17897&prodName=ZEN+Mozaic
May 10, 2009 | Creative Labs Creative Technology Zen MP3...
MP3 player wont play any songs
have you tried new batteries? mabye the san disk is scrached or it could not work you could have downloaded them wrong to
Jan 02, 2009 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Ipod 4gb error
I had the axact same problem and these instructions fixed it:
This guide is for you if:
1. You've bought a mpx player larger than 2 GigaBytes capacity (eg 4GB, 8GB, 60GB, etc). Not limiting to larger than 2GB, smaller capacity (eg 512MB, 1GB, etc) players are also subjected to possible memory hacks.
However, recently i've realised that the Actions chipset does support upto 4GB (2x2GB). Also, there were some unconfirmed news of genuine 4GB players.
2. You just bought a new player.
3. You are experiencing "Format Error" messages when adding or accessing music/videos on your player.
4. You are experiencing frequent Player Restarts (hanging on the hourglass) when playing certain songs.
5. Your player duplicates the music/video files that you add to it.
6. Your player does not allow you to move/delete files that you have copied to it.
If you fit any one of the above (or even all), then this guide is for you.
Why you should format:
1. Not formatting will only cause you ALOT of trouble and hassels in the future.
2. Not formatting increases the chance of killing your player in future, and you will need to perform the "Dead Player Recovery".
3. Ensures that what you have bought, is of the actual memory capacity.
4. If it is a gift for someone, you don't want them to come back to you with the above mentioned problems.
Common Myths regarding this formatting procedure:
On completion of this guide, should you end up with lesser memory than what you have paid for, it would be recommended to contact your seller for a full refund.
Also, take a minute to fill in an online petition against eBay, Paypal and fraudalent sellers who knows about this problem, but persists to trade with such fraud items for monetary gains.
http://www.mympxplayer.org/petition-stop...ay--vt3442.html
Every signature plays a significant factor, the more signatures we have, the better chance of eBay shutting down such sellers permanantly.
STEP 1
STEP 2
STEP 3
*note* it seems that some members reported that they do not see this extra drive appearing. Do not worry if it does not appear, just continue to proceed with the guide.
Now, go back to the Partition and Encrypt tab.
You will repeat the process and the "Complete setting disk partition!" dialog box would appear.
STEP 4
STEP 5
Once completed, sit back and start copying music/video files to your player and enjoy your stuff!
Dec 27, 2007 | iLO (2 GB) MP3 Player
Samsung SCH-U470 Juke Cellular Phone Logo
12 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
