Question about Canon PIXMA iP3000 InkJet Photo Printer
Coloured printer with black not printing?
I ran out of the black ink, had the ink cartridge refilled, and the black would not print.
I questioned the fact that I refilled the cartridge, so I purchased a new cartridge (Canon Pixma 5 PGBK). But the new black cartridge will not work either.
Did I ruin the printer with refilled cartridges?
What difference does that make?
  • 164 Answers
Breath and Relax... this should resolve your problem.
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your ip3000 print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
Time necessary 45-50 minutes
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your ip3000 in new condition.
Happy Printing .
Posted on Feb 07, 2010
  • JM Alvis Feb 07, 2010
    Relax and Take a deep breath. Your going to be fine.
    Supplies needed:
    paper towels
    latex gloves
    warm water
    Happy Printing .
After refilling he black an coloured cartridge, i always get the error E 5 and the lights B and C are flashing orange. I already changed the cartridges several times.
Using refills and non-canon inks can cause issues with the printer. You can damage the print head and fill up the waste ink tank faster then needed..
Best of luck..
Dec 03, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
My printer will not print in black. It will use the other colors, but not black. When I try to print a black and white document, it prints in blue.
if u want to print selected document in black than open the document select print go to printer properties select grayscale printing
always print in black
go to printer properties than go to maintenance than go to ink cartridge setting select ink cartridge black only for balck and white printing only.
OR
CHANGE CARTRIDGE
Jun 18, 2010 | Brother MFC 240C All-In-One InkJet Printer
QUESTION FOR DON_FARR
whenever you print greyscale what actually happen is that the printer mixes the red, blue and yellow to give the output in gray scale. See if you mix red, blue and yellow ink in the right proportion it gives you very close to black. just try to print your greyscale with your black ink finished you will still get the same print quality as when the black has ink in it. Or find a way seal the nuzzle of the black in and print your greyscale. check what results.
Dec 12, 2009 | Canon PIXMA MP610 InkJet Printer
Coloured ink not registering
You can only refill those cartridges if you do it before the ink is empty. After that you need a new cartridge or a chip resetter to reset the chip on the cartridge so it will work again.
Oct 12, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printer wont print
Well, I'm sorry but the printer folks all hold us up on the ink cartridge rip off! Nothing you can do but buy the cartridge and pay the price. But you may be able to refill it, I've had some luck in this department but it's far better to just buy one. The machine won't continue to print with just the black cartridge...it uses some color ink to print a black and white copy. I really don't understand why someone can't build a sturdy printer with refillable ink that will operate for pennies and be make of metal so it won't break....! You might look around at some of the stores will sell you a new printer with ink for about the price of the cartridge.
Apr 20, 2009 | HP Photosmart C6280 Printer
Epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Apr 02, 2009 | Epson Stylus CX3200 All-In-One InkJet...
I have just put in both black and colour refills into my printer which is a Pixma MP150, it it printing both black and colour ok, however my Black Ink light still keeps flashing on and off, the coloured...
I think you printer cartridge as sensor which ink levels as it is failed in the black cartridge ,you can either clean the contacts the printer and cart with dry tissue paper and replace and set printer installing new cart or use it like this because the printer company doe not support refilled cartridges to be used .
Apr 09, 2008 | Lexmark X1240 All-In-One InkJet Printer
Can we print with other three Color ink cartridges when Black Ink cartridge is emptied?
hi,
as u have ran out of ink you cant print anymore... you have to replace a new ink cartridge.... this is because when u print something, the colors will get mixed to print the exact color.... even if u are printing only in black, some other colors wil get mixed to produce the black color on the paper... so u need to change the ink cartridge.... u cannot run with a blank filled ink cartridge.... and the selection of your printer is very good...
thanks and regards
agnel
Mar 19, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
My Xerox DocuPrint M750 printer will not print black text but will print colour
This is just a suggestion. I recently bought a Staples refilled cartridge and had to return it because it did not work. When returning it the Staples Rep said that 50% of the cartridges do not work and get returned. This was an astounding amount I told the rep. Means nothing to him but to you, you may need to return the black cartridge if it is or is not a refill and try it out again. Let me know if that works.
Cynthia Charczenko
Jan 15, 2008 | Xerox DocuPrint M750 InkJet Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
1,437 people viewed this question
old marine
old marine
