Question about Sanyo PRO-700 Cellular Phone
I am getting an error message when I try to activate voice dial on my sanyo pro 700 mobile phone "Heap Free Error" Then the phone restarts after a minute.
  • 316 Answers
Hello my friend,this a programming error,probably your phone software/firmware is corrupted.You should try to reinstall your firmware or take it to a repair shop.
Posted on Feb 06, 2010
Testimonial: "this is the second phone i have had the heap free error. Could it have something to do with connecting to a blue ant 3 hands free divice?"
  • marios basileiou
    marios basileiou Feb 06, 2010
    Look is not very usual but theoretically if the hands free is corrupted or it has problem and sending wrong commands and your phone is getting a memory leak and try to free the memory and leads to heap free error,yes it should done:)
My Pro 700 got water damage. I purchased a replacement PRO 700a, but I need to "flash" it for use with my Cricket number (voice and text only)
My phone once had water damage too. I would try <a href="http://www.rtcrestoration.com/services/restoration-and-disaster-response">water damage repair in Fort Collins, CO</a> to see if they can help you out.
Sep 29, 2013 | Sanyo Pro-700a Rugged & Durable Mobile...
How to upload from Sanyo Pro 700 to computer
Good morning
I would go about it like this. Choose the messages you want to transfer. Make a folder on desktop if you have have not got one already. Connect the phone and the pc with the cable with the usb. When the pc asks you what you want to do with the hardware that is ready to use you push "transfer text" or something to that effect.
I hope this will give you the idea.
kolbrun
Jun 07, 2012 | Sanyo PRO-700 Cellular Phone
Display an error message as "your internet setting must be activated for java applications, or try again later"
You need to activate mobile office,you will then get an service message with the configuraton. for Airel I guess you can dial *567*# to activate it.
Feb 11, 2011 | Cell Phones
Hi how do i setup my cell for voicemail
using your cell phone (make sure battery is fully charge) call voice mail and when prompt entered password if you have already set it....and listen to the voice (prompts) it will most likely say you don't have any messages, but do wish to set or change your outgoing message press the appropriate key when prompt and listen to the options to set
Nov 11, 2010 | Sanyo PRO-700 Cellular Phone
My battery life on my Sanyo Pro 700 doesn't last
may be but most probably ur ic may be damaged.....
Jun 08, 2010 | Sanyo PRO-700 Cellular Phone
Can boost mobile sim work in a pro 700
PRO 700 DOES NOT USE SIM CARDS! instead like the other sprint phones it uses the ESN/MEID number on the back. Just call sprint and tell them you want to do an ESN SWAP or SWITCH TO A NEW PHONE and they will ask you for the number under the battery. They will also walk you through activating everything including Direct Connect. It is as fast as Nextel traditional Direct Connect but it has a MUCH LARGER COVERAGE AREA FOR VOICE AND DIRECT CONNECT. Soon these phones will take control and the whole IDEN network Nextel uses will be converted to CDMA (sprints High Speed Network).
Mar 14, 2010 | Sanyo PRO-700 Cellular Phone
QTEK
Airtel Hack for Free GPRS All you need to have is
–>PC
–>Serial/USB cable/Bluetooth dongle
–>Any Browser(I suggest Opera as we can browse both wap and other sites)
Follow These Steps:
—>Activate Airtel Live sending a message MASALA ACTIVE to 121
—>Create a profile with the following settings in your data account under Data Communication
GATEWAY : 100.1.200.99
APN : airtelfun.com
USERNAME : blank
PASSWORD : blank
PASS REQ : OFF
ALLOW CALLS : AUTOMATIC
IPADDRESS :
DNSADDRESS :
DATA COMP : OFF
HEADER COMP : OFF
and then Under INTERNET PROFILES,
INTERNET MODE : HTTP or WAP (both works)
USE PROXY : YES
IP ADDRESS : 100.1.200.99
PORT : 8080
USERNAME :
PASSWORD :
–>Create a new dial-up connection on your pc after connecting the mobile to pc,using the NEW CONNECTION WIZARD as follows
ISP Name : Anyname
Phone Number : *99***1#
Username and Password : blank
–>Configure your browser to use the proxy 100.1.200.99 and port 8080.
–>Connect to the dial-up account. You will be connected at 115.2kbps
—>Now if you try to access any site on your mobile you ll get an error message like “Access Denied”
—>Open your browser, and start browsing and voila it opens the regular sites and if u beleive ull get a d/l speed of 5-6 kbps
Common Errors:
If you are getting any error wile dialing a dial up connection than go to
Control panel>> Phone and modem>>>select modem and click on its properties >>advanced
and enter the following initialization commands
CODE
AT+CGDCONT=2, “IP”,”airtelfun.com”,”",0,0
Now it should be connected without any error......!
May 26, 2009 | Lands Phones
SPRINT SANYO PRO 700
Hey! I just got the PRO 700. IT DOES NOT USE SIM CARDS! instead like the other sprint phones it uses the ESN/MEID number on the back. Just call sprint and tell them you want to do an ESN SWAP or SWITCH TO A NEW PHONE and they will ask you for the number under the battery. They will also walk you through activating everything including Direct Connect. It is as fast as Nextel traditional Direct Connect but it has a MUCH LARGER COVERAGE AREA FOR VOICE AND DIRECT CONNECT. Soon these phones will take control and the whole IDEN network Nextel uses will be converted to CDMA (sprints High Speed Network).
Apr 09, 2009 | Sanyo PRO-700 Cellular Phone
Sony ericsson mobile w610i
I have the same problem with my phone w610i , I think it is a common problem of this model . My first phone have this problem on the first day and I replaced with new one , after one week the sencond one have the same problem, and some times it shows an error message "Serious error occured,stop using phone contact sonyerricsson" then I need to restart the phone again to use , Only solution is get service from sonyerricsson, bcs it is new model and no spares and softwares awailable on the outside market .
Jul 24, 2007 | Sony Ericsson Mobile Bluetooth Car Kit...
Sanyo PRO-700 Cellular Phone Logo
206 people viewed this question
Top Sanyo Cell Phones Experts
Computer Repairing
Computer Repairing
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
270rexton
270rexton
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
