Question about BenQ DX 650 Multimedia Projector
As soon is turn on has horizontal lines and intermitent proyection
  • charlieflore Feb 06, 2010
    How do I check that?
    President:
  • 1,768 Answers
1. check the cable from the PC to the DLP
2. disconnect and reconnect and the re- sync the DLP to the PC
3. You may have to re install the DLP or update the drivers for the device
Posted on Feb 07, 2010
  • BenQ Master
  • 15,969 Answers
There is a color wheel that is in those units and there is also a decoder it could be either one. You can check the color wheel to see if it is damaged. THe bad thing is that they are expensive. Especially if it is the decoder.
Posted on Feb 06, 2010
What causes my RCA TV to turn off as soon as it is turned on?
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 13, 2014 | Televison & Video
I heard sound but not video see it and i unplugged and push the power button x one minute and it doesn't work either
you have a problem with signal or voltages tht goes to 3 proyection tubes ,are you tech?? if yes used a voltmeter to check voltages to high voltage horizontal power , you have problem with deflection area or maybe power supply
Jul 08, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Toshiba 36A50 sound, light line horizonally on black screen
It is my guess that you have some intermitent solder connections in the Vertical output circuit.
Hope this helps,
Skyassoc
Jun 23, 2009 | Toshiba 36A40 36" TV
Hi i have sony proyection tv kp53n74 i need a c 517 in uf
C517 is mentioned in below image of KP-53N74 schematics and its part number is as follows...
1-162-134-11 CERAMIC 470PF 10% 2KV
Good luck.
Apr 09, 2009 | Sony Televison & Video
CRT TV picture keeps getting horizontal line & loud cracking nois
the horizontal section is near collapse, the lines indicate a sort or leak. Soon, the set will go black. Shut off as repair will be cheaper now! Needs professional repair as High voltage section is dangerous.. Unplug to be safe!
Mar 13, 2009 | Toshiba CF27F30 TV
Lines on tv
Hi
this not horizontal this is vertical line. this means defective vertical output IC and 1.5ohms resistor, Replace the two parts then test run, and happy viewing!
Thanks!
Dec 26, 2008 | Sharp 25L-M100 25" TV
Blue shadows/ghosts
how old is the tv ??
if this tv is older than 5 years it may need to refill the liquid on the proyection bulbs and/or could have contaminats in the fluid causing the ghost and to fix that you will need a professional person to do it
Apr 03, 2008 | Toshiba TP55H60 55" Rear Projection...
TV Shuts Down
you may have vertical intermitance resold vertical ic or check connector to deflection yoke some time is intermiten..
Mar 23, 2008 | Mitsubishi VS-55707 TV
Green screen with almost horizontal zigzag lines
Is good that you hit it and it reacts,very likely you have loose conections in different places but for the distorted picture you need to check the horizontal driver transformer and flyback after that is corrected you need to check the complete chassis for loose conections.Take your time.Good luck.
Sep 07, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Horizontal lines
http://home.tiscali.nl/m.majoor/tv__matchline_service_mode.htm Sounds like you need go this site, enter codes and re callibrate your TV to the settings. If this does not work - then sounds like you need tv repair man replace caps or solder bad joint. Miyan sung, former philips rep man, Korea.
Aug 29, 2006 | Philips 32PW6506 32" TV
BenQ DX 650 Multimedia Projector Logo
46 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
